RCI Skid Plate and Oil Change
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Jan 15, 2022.
  1. Feb 3, 2022 at 11:03 AM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    I ordered mine last month and it showed up in one week.
  2. Feb 3, 2022 at 12:12 PM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Bilstein 5100 2” front Bilstein 5100 rear w/ 1” Cornfed spacer Sherpa Crestone roof rack RCI Skids and sliders Ironman UCA’s
    I ordered mine around Black Friday at the same time I ordered sliders. I called after 7 weeks to check the status, and at exactly 8 weeks I was told I could pick everything up. I’m sure I would have received my skid plate sooner if I hadn’t ordered it with powder coated sliders.
  3. Feb 4, 2022 at 2:24 PM
    Saitama
    Saitama New Member
    Steve
    San Francisco
    Stock 20 ORP
    Prinsu Full Length Rack, BFG K02's, Midland MXT275
    I can also confirm the drain tool being awesome. Allows enough drainage when removed for no spillage and just pour out cleanly.
  4. Feb 4, 2022 at 3:33 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Spoke too soon, just got my shipping confirmation today!
  5. Feb 4, 2022 at 3:33 PM
    spyder918
    2019 TRD ORP MGM
    The Fumoto valve? Yep I got one too.
  6. Feb 4, 2022 at 3:52 PM
    polyguy79
    polyguy79 New Member
    LA County
    2021 White Runner ORP
    RCI aluminum skids (front, trans, TC, and gas), RCI steel sliders 20 degree no plates with kickout, Treaty Oak recovery points, LFD stainless crossbars, Greenlane ladder, Toyo Open Country AT III, Bilstein 5100s, OME (front 2” lift) and Eibach (rear 1”lift) coils
    Glad to hear you got your shipping confirmation!! Also, there is an oil filter drain valve that makes replacing the filter much more clean and you don’t have to use those stupid plastic tools that come with the filter anymore. That is also worth the $15 or so that it costs.
  7. Feb 4, 2022 at 3:59 PM
    spyder918
    2019 TRD ORP MGM
    Oh where did you get that at?
  8. Feb 4, 2022 at 4:09 PM
    Marchy
    Marchy New Member
    Sean
    Seattle
    2021 4 Runner Venture
    Just wanted to chime in that I also have the RCI skids, with the camry metal oil filter housing and Fumoto drain valve and oil changes have never been easier. Only reason I had to take my skid off in the last oil change was I needed the room to put on the fumoto drain plug.
    glwood54 likes this.
  9. Feb 4, 2022 at 4:27 PM
    polyguy79
    LA County
  10. Feb 4, 2022 at 4:41 PM
    spyder918
    2019 TRD ORP MGM
    Ah thanks! How do you keep this thing clean after you use it? Do you just wipe and keep it in a ziploc or something?
  11. Feb 4, 2022 at 4:47 PM
    polyguy79
    LA County
    The tubing isn’t very stiff. You can squeeze it clean mostly and then just flush with some water and dawn. I have a shelf that I just put it on and it’s fine. No ziploc
    spyder918 likes this.
  12. Feb 4, 2022 at 8:21 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I don’t wash it. Just wrap it in a rag and hang it for a day to let gravity clear it out.
