RCI Rock Sliders - Grip?
Discussion in '5th Gen 4Runners (2010-2024)' started by spyder918, Feb 3, 2022.
  1. Feb 3, 2022 at 3:07 PM
    spyder918
    spyder918 [OP] 501st Unit: GGG
    2019 TRD ORP MGM
    I'm considering getting these sliders. Those of you who have these with the filler plates, how is the grip especially in the rain? I wish RCI had an option of Line-X or some sort of grip tape type of texture for the filler plates. Gotta make sure Mom & Dad don't slip when they visit.
  2. Feb 3, 2022 at 3:18 PM
    TRDLE
    TRDLE New Member
    Duluth, MN
    '22 TRD Pro
    I'm planning to get the same ones, I was wondering the same and also if they stick out enough to operate as a decent step.
  3. Feb 3, 2022 at 3:30 PM
    billum v2.0
    Flyover Country
    2020 Trail
    ToyTec 2.5" lift with RCI/filler plate sliders. I intentionally step over them, but wife uses them as a step with no issues. She said she hadn't noticed them being slippery, but followed up with a "I know there's no grippies (might want to Webster that) and act accordingly".
    They fall into that "there if you need them" (as a step) category without being "no choice". They do tuck in pretty well.
  4. Feb 3, 2022 at 5:47 PM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Bilstein 5100 2” front Bilstein 5100 rear w/ 1” Cornfed spacer Sherpa Crestone roof rack RCI Skids and sliders Ironman UCA’s
    I’ve used mine as a step while it was snowing, and there was no issue with grip on the powder coating. As far as whether or not they’re good as a step, I think most people visualize you’d use them like an actual step with your foot perpendicular to the vehicle, but in reality your foot really needs to be sideways to comfortably enter the vehicle. My foot may bump the rocker sometimes while using them, but I find there’s plenty width for my foot. I prefer to just hop over them thought. My wife prefers the step because she’s short.
  5. Feb 3, 2022 at 10:46 PM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    The grip is not an issue. The RCI sliders do not offer the same depth in the front like a running board to step up. But it can still be used with part of the foot if you are in decent physical shape. With the kickout in the rear you have a good step to access the roof and rear seats.
    Doglover2003, roc and 7385 like this.
  6. Feb 3, 2022 at 11:15 PM
    You could get some wing walk paint used on aircraft and coat the area that you wish to use as the step.
  7. Feb 4, 2022 at 5:34 AM
    roc
    roc New Member
    Michigan
    2021 4Runner TRD ORP
    I bought the bare metal and painted.
    Not slippery even with smooth paint.
    Not much of a step for the front but the dogs use them for getting into the rear.
    Doglover2003 and polyguy79 like this.
  8. Feb 4, 2022 at 5:41 AM
    TRDLE
    TRDLE New Member
    Duluth, MN
    '22 TRD Pro
    I just ordered mine! They should arrive a week or two after my truck does, so after my kids don't get a step for a couple weeks, it'll be a definite improvement
  9. Feb 4, 2022 at 8:23 AM
    spyder918
    2019 TRD ORP MGM
    Interesting never heard of wing walk before. Have you used it before? Easy to apply? Is it similar to Line-X/bed liner texture?
  10. Feb 4, 2022 at 8:46 AM
    I would look on aviation supply website.
  11. Feb 4, 2022 at 3:32 PM
    spyder918
    2019 TRD ORP MGM
    damn this looks like mandalorian stuff right here!
    2Toys likes this.
  12. Feb 4, 2022 at 4:39 PM
    polyguy79
    polyguy79 New Member
    LA County
    2021 White Runner ORP
    RCI aluminum skids (front, trans, TC, and gas), RCI steel sliders 20 degree no plates with kickout, Treaty Oak recovery points, LFD stainless crossbars, Greenlane ladder, Toyo Open Country AT III, Bilstein 5100s, OME (front 2” lift) and Eibach (rear 1”lift) coils
    If you are using the sliders as a step, then using a bedliner may be ideal. I have the RCI 20 degree sliders with no plates. I don’t use these as a step except when loading my roof rack. With this setup I would advise to NOT use anything abrasive like that because you will rub your legs raw in the summer if you wear shorts. I used hammered Rustoleum matte black paint and they came out real good. Rattle can paint makes for easy touch ups. Bed liner tends to rip and chip in chunks and touch ups are a little more work and not as clean loooking. Personally, a good paint job properly primed will do the trick at a fraction of the cost
    7385 likes this.
  13. Feb 4, 2022 at 6:24 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Skateboard tape.
    So grippy it’ll take the skin off her legs.
    Ironguy and polyguy79 like this.
  14. Feb 4, 2022 at 6:31 PM
    auspilot
    auspilot DustRunner
    2020 TRD OR
    Dobs IMS, lots of small stuff
    You shouldn't use that -- It clearly says "For aerospace use only"!! :D
  15. Feb 19, 2022 at 9:37 AM
    SnakeDoc
    SnakeDoc New Member
    Eric
    Doglover2003 likes this.
  16. Feb 19, 2022 at 2:10 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I have the RCI 0 degree sliders with the step plates. I ordered in bare metal and painted with Raptor Liner spray on bed liner. The Raptor Liner provides a good grip but the sliders are marginal as steps in front due to the width. The bump outs in the rear make reasonable good steps for the rear passengers…
    Cheers,
    Bob
  17. Mar 15, 2023 at 8:37 PM
    airup12
    airup12 New Member
    How far do these sliders stick out by front doors? Anyone install with kdss and have issues?
  18. Mar 15, 2023 at 9:08 PM
    Why not RSG sliders with the grip top plate? No tape needed.
  19. Mar 16, 2023 at 1:20 AM
    steelevo
    Utah
    As others have stated, the sliders are not really wide enough to be like a running board step but they do work. I’ve used my RCI sliders in the rain and snow with zero slip issues. The holes have the edges turned up and create plenty of grip. The service at RCI is also top notch. Jason at RSG is also amazing. You can’t go wrong with either slider.
  20. Mar 17, 2023 at 2:51 PM
    Metalsaber
    Metalsaber New Member
    I sprayed my with Rhino liner instead of paint.
  21. Mar 17, 2023 at 3:41 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Just go the local skateboard shop & buy grip tape. It’s way cheaper
  22. Mar 17, 2023 at 6:13 PM
    I suggest you live with your sliders for a little while before trying a grip pier coating or tape. Those coatings can be stubborn when it’s time to clean them. I have RSG sliders with the non-grip top plate and slippage hasn’t been an issue.
  23. Mar 17, 2023 at 6:14 PM
    @Zaphod
    You said “Spousal Unit”!
    :goingcrazy::goingcrazy::goingcrazy:
  24. Mar 17, 2023 at 6:17 PM
    I have RSG angle sliders with no bump out and they are not slippery.
  25. Mar 17, 2023 at 7:59 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I would have to put a tape measure down to see how far they stick out. I installed mine by myself with kdss - it wasn't easy and would recommend a friend if you have one. Apparently I don't :(
    Practically, I'm just under 6' and don't use them as a step (I'm lifted about 2.5-3" with 285/70s). My shorter "spousal unit" uses them to get in front because she hates my "monster machine". I've noticed with her small feet she turns her foot parallel to the vehicle because it isn't wide in the front. My 6 yr old daughter uses the kickout as a step for the rear without issue but I usually hold her hand getting in/out when it's wet for safety reasons.
    Edit - that being said, I've used smaller front and kickout to get to the roof rack and don't have issues. The front isn't wide but (at least when it's dry) is enough to step on perpendicular to the vehicle to reach the roof rack if you have strong toes
    airup12[QUOTED] likes this.
  26. Mar 17, 2023 at 8:41 PM
    airup12
    airup12 New Member
    Ha I’ll keep that in mind for install! do you mind putting the tape measure down to see? Are yours 5 or 20 degree rci sliders?
  27. Mar 17, 2023 at 9:09 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    I have 5 degrees. It's dark so hard to see the full tube but here are front/back pics from the rocker panel with doors open:
    And pics from the usable space under rocker panels (could have more/less room depending
    on shoe/boot thickness):
  28. Mar 18, 2023 at 4:47 AM
    airup12
    airup12 New Member
    Thanks that helps a lot!
