Rattling Sound
Discussion in '5th Gen 4Runners (2010-2024)' started by NZgamers, May 26, 2024.
  1. May 26, 2024 at 12:26 PM
    NZgamers
    NZgamers [OP] New Member
    Hi All,
    I am new to the forum and need some advise. 2018 4Runner making rattling noise on front passenger side whenever there are bumps etc. mostly whenever the body rocks it makes this sound .
    Any advise what it can be
    Thanks
  2. May 26, 2024 at 1:48 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    You either need to be a bit more descriptive or post a video. It could be many different things.
  3. May 26, 2024 at 4:10 PM
    ualfltdispatch
    ualfltdispatch New Member
    2023 TRD Off Road Premium
    Sounds like your radio isn't loud enough. Try that 1st.
  4. May 26, 2024 at 4:15 PM
    broken-giver
    broken-giver BFD
    Most likely the glass on passenger side.
  5. May 27, 2024 at 6:06 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Definitely your splash guards on the inner wheel well. Super common issue.install some ARK splashguards and you’ll be good.
  6. May 27, 2024 at 6:36 PM
    I second this, it's an easy thing to fix and check. Don't agree that you need to replace them though, all you need to do is put a zip tie around the factory fastener to add extra tension on it, then it will not rattle.
  7. May 27, 2024 at 7:29 PM
    Startrek
    Startrek New Member
    check ALL heat shields over exhaust
  8. May 27, 2024 at 7:31 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    lol $120 for a pair of rubber splash guards….
  9. May 28, 2024 at 2:44 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    lol. I’m not the one with a rattling vehicle :)
    LT Smash likes this.
  10. May 28, 2024 at 5:56 AM
    Yobruhitsme
    Denver
    Solved it with reinstalling new plastic fasteners.. got a whole box of them for $20 Or buy $120 new liners … :)
  11. May 28, 2024 at 6:34 AM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    Eibach Stage 2, JBA UCA’s, K02 - 265/70, Ark guards, Sony XAV9500ES
    Good job with the economical solution. :woot:
    You may find the liners will need to be replaced eventually. The material they are made of becomes brittle over time and they will begin to tear/break up. Yes, pricey but with the Ark guards it’s a buy once, cry once situation. The material is far more durable/superior than the paper thin rubber/plastic used from the factory. Just my $.02.
