Rago Fabrication Molle Panel Install
Discussion in 'General 4Runner Talk' started by eaglescout, Nov 19, 2018.
  1. Nov 19, 2018 at 2:20 PM
    eaglescout
    eaglescout [OP] 2018 SR5
    Middle Tennessee
    2018 Magnetic Gray Metallic SR5
    FN FX PRo Wheels Matte Dark Bronze. Nitto Ridge Grappler 285/70/17/load C 3" Dobinson Coil Lift Blackout Kit Raptor Style Grill LED C4 Fab Lo Pro Winch Bumper LFD Offroad Skid Plate Shrockworks Sliders Rago Molle Panels Extreme LED Ditch Lights Ecotechne Roof Rack Detours Offroad Swingout Tire Carrier
    I just installed the Rago Fab. Modular Storage Panels in my 2018 SR5. I watched the install video on You Tube and at about 9:30 on the video,he talks about Toyota part # 58460-35012 Luggage Hold Belt Cargo Area. This is a rubber coated D ring to use instead of the stock plastic hook that comes on the 4R. Well I found that rubber coated D ring on Ebay and they want $19.05 each, there would be one on driver and one on passenger side, 2x $19.05= $38.10!!!!! So I just made a couple of them using some orange ratchet strap, a couple of D rings I already had, and some #10 cup washers (Hillman#490702 @ Lowes). I have less than $3.00 spent on material and think this will do as good as the Toyota parts.https://www.ebay.com/itm/GENUINE-OE...LT-CARGO-AREA-D-RING-58460-35012/163242193750
    https://www.youtube.com/watch?v=bP6YouGT0AU
    Cowboy59, WallyT4R and GoXplore like this.
  2. Nov 19, 2018 at 3:19 PM
    GoXplore
    GoXplore New Member
    Nashville, TN
    2018 4Runner TRD Off Road Premium - Barcelona Red
    Nice! I suspect whatever marginal "advantage" the Toyota part could conceivably have is more than offset by the fact that you could have made twelve of these for the same price as one of the Toyota part. :)
    WallyT4R and eaglescout[OP] like this.
  3. Nov 20, 2018 at 8:53 PM
    MattMo
    MattMo Life's too short not to!!
    Matt
    Nor Cal
    2019 TRD ORP KDSS Magnetic Gray
    TRD Cold Air intake system Pro-Comp Vertigo with BFG LT285/70R17 KO2 ICON 0-3.5" Suspension System - Stage 2 (Tubular) ICON Rear shock shin guards ICON Adjustable track bar RSG METALWORKS Angled sliders with a kick RSG METALWORKS KDSS Skid plate Metal Tech Rear Bump Stop Drops RAD RUBBER DESIGN Nitrile Rubber Engine SPLASH GUARDS Body Armor BackBone Hitch Skid AVS Hood and Window vents Front windows and Moon Roof Tinted Pedal Commander Wet Okole seat covers LED lights in and out RAGO Modular Storage Panel System Driver and Passenger RAGO Low Profile ditch light brackets with Baja Designs Squadron Sport Driving/ Combo LED Lights RAGO Ditch Bracket Antenna Extension for the Go Pro RAGO Antenna Mount - Stainless Steel Secondary Air Pump replaced the foam to a Uni Filter UP-107 1” clamp-on breather. Fog Lights changed to Xenon Depot Xtreme LED Pro H16 Yellow Bulbs Lamin-X protective film in Yellow C4 Fabrication Rear Diff Skid Plate Lamin-X door cup clear scratch protectors Diode Dynamics Tail as Turn Kit (Tail as Turn™ Module +Backup Module) with XP80 LED Cool White for old turn signals GOBI ladder Overland Equipped Bolt-On Steps RotopaX Ladder Mount Brackets for RotopaX Fuel cans SDHQ ABS Speed Sensor Guards Smittybilt Element Ramps ArcLight LEDs Icarus Hatch Lights eXtreme ARTEC INDUSTRIES Toyota 5G Venture Roof Cross Bars Silver Wing Clam Shell Rooftop Tent Anytime Backup and Front Camera Full Kit (Camera and Switch) ARB Differential Breather Kit Diaz Fabrication Devil Horns clear anodize Pro-Comp LED Rock Lights ARTEC INDUSTRIES 5G Venture bumper with Smittybuilt winch ABB 2500 awning GOBI Stealth full w/moon roof (ARB and Shovel Axe mounts) On order:
    Great idea, my Rago Fab. Modular Storage Panels will be here this weekend and this is exactly the route I'm going, Thanks for the post and details
    eaglescout[OP] likes this.
  4. Nov 21, 2018 at 12:27 PM
    What is the purpose of this Rago Molle?
    Will you be transporting criminals in the back of your 4Runner?
    WallyT4R likes this.
  5. Nov 21, 2018 at 12:47 PM
    4X4Runner
    The left coast
    I prefer the term “baddies”
    It’s for storage. Attaching molle comparable accessories like IFAK’s extinguisher mounts, tool pouches, etc
    WallyT4R and MattMo like this.
  6. Nov 21, 2018 at 2:36 PM
    Ah, I see. Thanks :cheers:
  7. Nov 21, 2018 at 5:05 PM
    MattMo
    Matt
    Nor Cal
    I questioned my sanity but after downsizing from a larger SUV the storage and easy access to the ETC.. ETC.. made sense. The folks @ Rago are pretty cool. See anything on the site your'e interested in call and see if any blemished items are available. $ave $ome...
  8. Nov 21, 2018 at 7:14 PM
    eaglescout
    Middle Tennessee
  9. Nov 21, 2018 at 7:53 PM
    Huntr12
    Huntr12 New Member
    Brian
    Dallas, TX
    2017 4Runner 4x4
    Fox 2.5 front and rear. Icon delta joint uca's. Shrockworks sliders
    Love my Rago panels. Will have to add this now
  10. Nov 21, 2018 at 8:59 PM
    WallyT4R
    WallyT4R New Member
    Mine is usually close to empty until I go on a trip because where I work would frown on knives or hatchets, etc, in your vehicle. But I have my Ultimate Camping Mod switches mounted to the drivers side. Red button opens the back door from the inside when the power is out. The rocker switch opens and closes the rear window with the power off. Love this mod! when camping inside the vehicle
    jgcaps, eaglescout[OP] and MattMo like this.
  11. Nov 21, 2018 at 10:12 PM
    MattMo
    Matt
    Nor Cal
    Now that's something I never considered and probably won't stop thinking about! Any chance you have instructions for this?
  12. Nov 22, 2018 at 5:04 AM
    WallyT4R
    WallyT4R New Member
    jessetoedtman@gmail.com
    You can research this mod and do it yourself.....or.... I contacted Jesse (email link above) and he made me a harness to fit my application. He calls it the ultimate camping mod. He includes instructions, the harness, zip ties, all you need including extra clips for the interior panels if you happen to break one pulling off the panel. Great customer service and only about $50.
    jgcaps, MattMo and eaglescout[OP] like this.
  13. Nov 22, 2018 at 9:54 PM
    MattMo
    Matt
    Nor Cal
    Thanks for all the info!!
  14. Nov 23, 2018 at 5:34 AM
    WallyT4R
    WallyT4R New Member
    You are welcome!:thumbsup:
  15. Jan 25, 2021 at 4:23 PM
    maxrunner2018
    maxrunner2018 New Member
    Hi guy's, a friend of mine as sold is runner and i bought from im those molle pannel but he as lost the bolt and spacer. Does any one as the spacer lenght and bolt pattern of the mounting bolt. Thanks
  16. Jan 25, 2021 at 7:12 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    I don't know about the spacer, but I'd contact Rago if you can't find it yourself. I've heard they're accommodating to people who need to buy spare parts.
