radio screen damage
Discussion in '5th Gen 4Runners (2010-2024)' started by johannek, Nov 12, 2020.
  1. Nov 12, 2020 at 6:59 AM
    johannek
    johannek [OP] New Member
    2016 black 4runner limited
    hello
    I have a 2016 4runner limited jbl radio with XM. The tactile screen got buster and I cannot use it anymore. is there a part I can order in canada that will replace the screen as the radio still works via the steering wheel. Thank for you help much appreciated as I do not want to replace the entire unit
  2. Nov 12, 2020 at 7:16 AM
    Welcome to the forum.
    deltabravo and johannek[OP] like this.
  3. Nov 12, 2020 at 7:28 AM
    ForRun
    ForRun 4Runner
    2020 orp
  4. Nov 12, 2020 at 7:31 AM
    ForRun
    ForRun 4Runner
    2020 orp
    I do not remember cost but heard the replacement is ridiculously expensive in the thousands.
    Best bet would be post a wanted to buy both here and another large 4runner forum. Lots of people go aftermarket.
    If that doesn't pan out, junk yard or it may be cheaper to go aftermarket.
    Good luck
    Toy4X4 likes this.
  5. Nov 12, 2020 at 8:03 AM
    johannek
    thanks
    I know the radio is 1500 CAD wish I could only get the front as the radio still works.
    the plate that is shattered is replaceable for 150 us
  6. Nov 12, 2020 at 10:09 AM
    Old Red
    Old Red New Member
    Washington
    It's a long list...
    You will need to replace the digitizer panel that lays over the touch screeen. Google Toyota 4Runner 6.1” digitizer JBL replacement. You should find the part you are looking for. Shouldn’t cost more that $100 and can be done yourself in an hour.
    johannek[QUOTED][OP] and A&P like this.
  7. Nov 12, 2020 at 4:15 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Good info, thanks. Maybe it's the 2020 radios I read about are stupid expensive
  8. Nov 13, 2020 at 2:12 AM
    Welcome from Wisconsin! About the radio... ya, I heard they were stupid expensive when we bought a '17 Tacoma, so we put "extended warranty" on the truck, luckily never a mishap with the radio, so now with the '20 4Runner my thought is, if you could fix it for a little.... fine. If not.. aftermarket would be the ticket. Old Red has the answer in post #6, very cheap fix considering the alternatives.
  9. Nov 13, 2020 at 3:33 AM
    beachT4R
    beachT4R New Member
    2016 Silver SR5
  10. Nov 13, 2020 at 2:13 PM
    Charlievee
    Charlievee Not new member.
  11. Nov 19, 2020 at 11:13 AM
    beachT4R
    beachT4R New Member
    2016 Silver SR5
    I don't think so, there are several youtube videos on replacing it though
  12. Mar 15, 2023 at 8:30 PM
    Mtbpsych
    Mtbpsych New Member
    Just wanted to revive this old thread. I recently fixed the digitizer on my unit as it cracked and was unusable. $20 part from eBay, 30 minutes later it’s fixed and working properly. Inexpensive repair for an expensive unit.
    7385 likes this.
  13. Mar 15, 2023 at 9:55 PM
    4runningMan
    4runningMan New Member
    New Mexico
    How much of the dash do you have to un-install? Is is just the plastic surrounding the screen?
  14. Mar 16, 2023 at 9:59 AM
    Mtbpsych
    Mtbpsych New Member
    Yeah the head unit itself is attached to the whole control panel which is held in by 4 bolts, and then just unplug all the wiring in the back. Takes about 2 minutes to get the head unit out of the vehicle.
