Quick Alignment Question for a 1 inch front level on a 2021 SR5 Premium 4x4
Discussion in 'Suspension' started by thkbaron, Jun 9, 2021 at 5:13 PM.
  1. Jun 9, 2021 at 5:13 PM
    thkbaron
    thkbaron [OP] New Member
    Going to be leveling our 4runner as soon as it gets in to the dealer. Just want to toss the cornfed front spacers. We don't have a Toyota dealer in my town. What kind of alignment specs should I be looking for with a 1 inch front level and can the shop in town that's not a Toyota place do it?
  2. Jun 9, 2021 at 5:45 PM
    dcwn.45
    dcwn.45 New Member
    I just did the same thing on my 2020 and got an alignment at local shop
    I wasn’t sure if I needed it but they did have to make adjustments
  3. Jun 9, 2021 at 5:58 PM
    thkbaron
    Yeah do you have a picture of your alignment spec sheet
  4. Jun 9, 2021 at 6:59 PM
    dcwn.45
    dcwn.45 New Member
  5. Jun 9, 2021 at 7:12 PM
    thkbaron
    ahh yours is a limited. might be a bit different than mine.
  6. Jun 9, 2021 at 7:15 PM
    2018 SR5P 4WD
    Are you trying to fit bigger tires too?
    If not, any reputable alignment shop will know the specs.
    If they ask you for the specs, turn around and run!
  7. Jun 9, 2021 at 7:22 PM
    thkbaron
    nah keeping stock size just in a Toyo at3 with different wheels zero offset. just want to get rid of the rake a bit. nothing fancy.
    nimby likes this.
  8. Jun 9, 2021 at 7:44 PM
    dcwn.45
    dcwn.45 New Member
    No mine is an SR5 premium, they just wrote it down wrong on the paper.
  9. Jun 9, 2021 at 7:50 PM
    thkbaron
    oh ok. thanks!
  10. Jun 9, 2021 at 9:11 PM
    kbp810
    kbp810 New Member
    I sort of both agree and disagree with this… a competent tech should def know the specs… but I also feel like a good tech should ask as well (when it comes to dealing with a modified vehicle). Well, even modified stuff aside… Quite a few places I’ve found have lazy or poorly trained tech that will just do a toe and go, and whatever caster and camber fall is what you get, so long as it’s not too far out in the red. I feel like if I give them what I want, they’re more likely to at least try, lol.
    I tend to always provide specs. My ideal setup is is in the ballpark of 0 or slightly negative camber; caster at 3 or higher (4 if you have the upper control arms to help get you there), and slight toe in (1/16” in or slightly negative degree). I’d be happy with the sheet posted above by dcwn
    nimby likes this.
  11. Jun 10, 2021 at 6:08 AM
    2018 SR5P 4WD
    I get what you're saying. I provide the caster specs to my alignment shop because of my larger tires. I know what setting helps them clear.
    My recommendation was specific to the OP's situation and since he doesn't have larger tires, I don't think there's much of a reason to specify the specs.
    kbp810 likes this.
  12. Jun 10, 2021 at 6:27 AM
    thkbaron
    Yeah I was hoping there was a company out there that specialized in 4runners. Thuren Fabrication has specs specific to our Power Wagons which was handy. I'll bring that sheet that was provided and see if they come close.
