Question about installing a new radio
Discussion in '3rd Gen 4Runners (1996-2002)' started by RussToy, Oct 21, 2015.
  1. Oct 21, 2015 at 8:54 AM
    RussToy
    RussToy [OP] New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    Hello Guys..I'm getting ready to install a new radio in my rig. I purchased the radio through Cruthfield, who gave me the wiring connecters to install the radio. My question is...do I leave the factory "amp" in and plug into it? Or do I remove the amp and plug into those wires? If it helps this is what I bought...
    http://www.crutchfield.com/p_113KDCX998/Kenwood-KDC-X998.html?tp=5684
    Right now I'm just installing the radio, but in the near future I'll be adding an amp, new speakers and what not.
    Thanks for all the help guys...
    - Russel
  2. Oct 21, 2015 at 10:30 AM
    Ol'Blue
    Ol'Blue New Member
    "Not all who wander are lost"
    Oh you will love this KW. I have the model just under it and I LOVE IT!!!!!! The Bluetooth works great also.
    Blue
  3. Oct 21, 2015 at 12:21 PM
    MStudt
    MStudt New Member
    Eugene, Oregon
    01 SR5 4runner
    3" Toytec/Eibach, OME 891's, Custom Skid, Falken 285/75/16
    Remove it. The wiring you received shouldn't even connect to it.
  4. Oct 22, 2015 at 1:27 AM
    RussToy
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    @Ol'Blue thank you for the great review on my Kenwood deck!! So glad to hear the Bluetooth works so great...that's one of the main reason I picked this unit
    So...did you wire your radio into the factory amp?? Or just pull the amp?? Thanks..
    Thanks @MStudt for the response! Awesome...if I can get rid of the factory amp and wiring...that will save me a ton of space. Actually, that'll make more than enough room for my aftermarket amp...lol!!
    Thanks again Sir
    Ol'Blue[QUOTED] likes this.
  5. Oct 22, 2015 at 8:19 AM
    tbird
    tbird New Member
    Randy
    1999 4runner limited
    Tundra front brakes 17 inch wheels and after market radio
    Hey RussToy: I see you're changing the radio. I have a 99 limited that I changed and used the factory amp. The problem was that I had a single 15 pin connector which all the sites said I didn't have. I finally found it at best buy. Just remember to wire the antenna and amp power together and mine works great. If the radio you bought sets deep in the dash the rca connectors will hit the heater box. But you can get 90 deg adapters for this application from jap shack or parts express. I cut no wires doing this was simple and the factory amp was ok for me.
  6. Oct 22, 2015 at 9:59 AM
    RussToy
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    @tbird this is what I was wanting to know. Did you want to use the factory amp? Or did you have to use it to make all the wiring work...after you got the 15 pin?? I personally want to get rid of the amp. But if I have to use it....so be it. Sounds like I need to make a trip to Best Buy...get that 15 pin adapter. I'm already using a 90* adapter. I got rid of my stock antenna...I'm using a splitter and that allows me to share the CB's antenna...but thanks for the heads up!
    Thanks again
    - Russel
  7. Oct 22, 2015 at 12:46 PM
    Ol'Blue
    Ol'Blue New Member
    Russel-
    Oh no I shit canned the factor amp man. They run off different Oms so with out the factory head unit they are junk pretty much. I pulled all the speakers also and I run Memphis in it.
  8. Oct 22, 2015 at 5:46 PM
    RussToy
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    Sweet!! That's awesome the hear!! This is definitely what I'm going to do...dump that amp. I too am looking at changing out all my speakers...I'm looking at going with Hybrid Audio speakers. I've heard real good thing about them. Thanks @Ol'Blue your input/help!!
    - Russel
  9. Oct 23, 2015 at 7:11 AM
    Ol'Blue
    Ol'Blue New Member
