Pros and Cons to changing from 20" to 17"?
Discussion in '5th Gen 4Runners (2010-2024)' started by cchopan, Feb 14, 2021.
  1. Mar 3, 2022 at 6:19 AM
    I changed from BFG KO2 265/70R17 Load C to BFG KO2 275/70R17 Load E with stock Toyota suspension. I thought my wife would not notice as its the same tire but the ride quality was very noticeable. I tried to adapt but with lot of complains I had to switch to Load C. I was set tire pressure to 32-33psi.
    0wh9oRmgdXIGhHbZa3_5jxgp3Tg4xMCCq9utCqWU_774d6dc1392fa26e358876944941c95f907509e9.jpg
    sUtBP-eK3F0HjtRP67bQ4cdn6qwvKqOetWvf1bOj_9634434c8bd3c899e3bc4e96f0ed683ba6760bd6.jpg
    Before pic for proof-
    rIn9BIXVFY_eZ5E7EtKU0-bQbXaSlvrP-rUkklXv_506ec419ee085e032997b2b6ceb80958bdd3581c.jpg
    daH-AuoXoTPHmJ8U0aDkOLVtUQ1_rJxtwI-JXzgb_ab9d6235453bad50763f992c22d7b1361d38b996.jpg
  2. Mar 3, 2022 at 6:29 AM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Right, this was a problem going 17" SL or C Load to 17" E Load. That makes sense. Point I'm trying to make and that is responsive to the subject of this thread, is that the weight and stiffness impacts of going E Load are largely offset by also going from 20" to 17" rims.
    My total wheel and tire weight seems to be the same. And while the E Load sidewall is stiffer, there's also more of it.
    17" rims on a Limited make a lot of sense because:
    a) much more tire choice. way more.
    b) XREAS means you still have a good ride and great resistance to body roll/brake dive no matter what kind of tire you put on there.
    c) your saving a ton of weight on the rims, so have more room to go with heavier tires for AT or wtvr.
    kmeeg[QUOTED] likes this.
  3. Mar 3, 2022 at 6:38 AM
    Mikey8
    Mikey8 New Member
    Looks like going from a 20 inch to a 17 inch is a better choice? Thats what i did and i have the E load. I have the xreas on my trd sport as well.
    Seems like the car is shorter in height, but maybe because of the looks of the smaller wheels?
    Singleminded[QUOTED] likes this.
  4. Mar 3, 2022 at 11:03 AM
    This just struck me as so sad. It’s like thinking of a horse with a sharp stone stuck in it’s hoof.
