Power station question
Discussion in '5th Gen 4Runners (2010-2024)' started by ToyotaRDie, Apr 14, 2025.
  1. Apr 14, 2025 at 5:42 PM
    ToyotaRDie
    ToyotaRDie [OP] New Member
    Hello I haven Eco flow Power station. It’s rated as 65v 10a max. I don’t know anything about electricity, but wanted to purchase some solar panels. will these work? I was looking of getting two of these. How many watts you think I’ll pull from this panel? Is there a better panel for the Eco flow? Any electrical wisdom will be appreciated. I’m sure there are plenty of people on this form with a lot more experience with this than I am. Thank youIMG_0982.png
  2. Apr 15, 2025 at 11:08 AM
    rockdoc4x
    rockdoc4x New Member
    '24 ORP
    Looks like these panels put out 11 amps max each so you'd likely need some sort of controller. Or maybe the 10 amp Max DC Input of your Ecoflow means that it will only be able to use 10 of the 11 amps (optimally) available to it so you'd just lose a little efficiency. Best to ask Ecoflow or over on the DIY solarpower forum.
