Plug wires on a 3.4 question
Discussion in '3rd Gen 4Runners (1996-2002)' started by MrT54, Jan 5, 2021.
  1. Jan 5, 2021 at 1:12 PM
    MrT54
    MrT54 [OP] New Member
    I'm about to order wires and plugs; looked at the buyers guide and got numbers.
    Bosch 09444 or NGK 4412 or OEM 19037-62010 (now using -62050).
    When I pull up the wire set it looks like there are three wires. do I need to order two sets? I get that the motor shares coil packs but this is new to me.
  2. Jan 5, 2021 at 3:32 PM
    Sumitomo....
  3. Jan 5, 2021 at 4:07 PM
    MrT54
    negusm likes this.
  4. Jan 6, 2021 at 8:36 AM
    Yeah. OEM or OEM supplier only for these. There is literally nothing better.
    The coil packs feed the plugs on the passenger side of the engine. The wires just go from each pack across to the driver side plugs.
    Coil packs rarely go bad and are easy to diagnose and change if they do...so I don't recommend replacing those as the OEM ones are expensive and the aftermarkets are garbage.
    Use Dielectric grease for all contacts too.
  5. Jan 6, 2021 at 5:37 PM
    MrT54
    Thanks for the info. Ordered the sumitomo set and ngk plugs for next week.
    never seen a case where the coils are shared- That’s some trippy chit!
  6. Jan 6, 2021 at 5:49 PM
    It’s ahead of its time....
  7. Jan 6, 2021 at 8:00 PM
    Uhhh....most cars used to have a single coil only.
    You only need 1. But it's actually simpler if you add more.
  8. Jan 11, 2021 at 7:05 AM
    MrT54
    I’m referring to this particular motor and coil setup, not all motors. But thanks for the history lesson.
    4scooter19 likes this.
  9. Jan 11, 2021 at 10:21 PM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    Sorry these guys convinced you to spend an extra $40. NGK 4412s work great. But ya, its coil on plug for 3 cylinders, then extension wires to the other 3.
  10. Jan 12, 2021 at 7:26 AM
    No problem. Your post said you've never seen a shared coil and I was kind of shocked as that's how all cars started.
  11. Jan 12, 2021 at 12:21 PM
    MrT54
    dedicated coil for each plug sure but this was new to me
  12. Jan 16, 2021 at 12:29 AM
    Ambush
    Ambush New Member
    AJ
    99 Black Limited (Kitt) 99 Tan limited (Desert Storm) 2001 Silver SR5 (Silver Surfer)
    Never used that brand before. Either NGK or Denso for my Japan made vehicles. They never failed me and the prices were right (rockauto.com).
