Please help! I'm about flip my Sh*t lol
Discussion in '4th Gen 4Runners (2003-2009)' started by 07Limited4X4, Jul 1, 2022.
  1. Jul 1, 2022 at 5:51 PM
    07Limited4X4
    07Limited4X4 [OP] New Member
    Hey guys, weird stuff going on here headlights started dimming one night checked voltage while running voltage was at 13.5v engine running , low load, replaced battery checked again - voltage at battery 13.4v woke up next morning tried to start and nothing but clicking replaced with a 130 amp Duralast alternator(reman, lifetime warranty) installed it checked all grounds at frame cleaned with wire brush retightened added one ground from frame to engine blocked got everything together buttoned up fired it off putting out 11.9 volts my question is, is there another voltage regulator anywhere or I'm stumped what should I check?? Thank guys
  2. Jul 1, 2022 at 6:49 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Parasitic drain?
  3. Jul 1, 2022 at 9:14 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    V8, V6 or I4?
    13V from a 12V battery is pretty good meaning its just about fully charged. Your alternator should be putting out about 14.2-14.6V when running about 1500-2500 RPMs. So maybe you got a bad alternator or atleast one with a bad diode or regulator from DL but still enough to put out voltage. Have AutoZone test it. If its bad, atleast you got a lifetime warranty.
    Are you having any other electrical issues besides dim lights?
  4. Jul 1, 2022 at 9:45 PM
    07Limited4X4
    Yes, brake light traction control light 4x4 light and no radio or climate control at all could the starter have anything to do with it? I haven't replaced that I believe it's original
  5. Jul 1, 2022 at 9:50 PM
    07Limited4X4
    And also the alternator has four prongs where the plug plugs in but the plug only has three wires
  6. Jul 1, 2022 at 10:04 PM
    07Limited4X4
  7. Jul 1, 2022 at 10:04 PM
    07Limited4X4
    07 limited 4.0 L four wheel drive
  8. Jul 19, 2022 at 5:25 AM
    nickrick78
    nickrick78 New Member
    Could be a bad diode inside the alternator.
    Take it to a shop like Pep Boys, then can run a quick start/charge test for like $18 which includes checking the alternator diodes.
  9. Jul 19, 2022 at 6:57 AM
    Piney
    Piney New Member
    2021 Cement trail edition
    None
    Had a similar experience two different times over the years & the voltage regulator was the issue in both.
  10. Jul 19, 2022 at 7:32 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    #giggle
  11. Jul 19, 2022 at 8:53 AM
    Daddykool
    Does it have an aftermarket remote start?
