Pillar Lights
Discussion in 'Lighting' started by MtnKris, Mar 20, 2024.
  1. Mar 20, 2024 at 3:36 PM
    MtnKris
    MtnKris [OP] New Member
    22 Trail
    Hi.
    I was curious if there was a way to make the pillar lights just turn & brake only? I would prefer to not have them on as rear lights. I've been told by several people that my brake lights are difficult to see, so they just look for my 3rd brake light. Was hoping the pillar lights would help with this.
    Thanks!
  2. Mar 20, 2024 at 3:44 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Why are your tail lights hard to see? OEM 4Runner tail lights are very bright and easily seen if they are not modified or tinted.
  3. Mar 20, 2024 at 3:47 PM
    MtnKris
    22 Trail
    They are not OEM. They are the Alpha Rex. They go fro. 70% brightness tail to 100% brightness brake. The pillars go from 80% to 100%, so not too much difference.
  4. Mar 20, 2024 at 3:53 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I personally find the Alpharex to not be a safe aftermarket option. From behind, they are very hard to see compared to OEM or other aftermarket options. Switching to OEM or other aftermarket option would be a safe bet and limit liability to you and other drivers.
    Can you help me out with what pillar lights are? Do you have a link?
  5. Mar 20, 2024 at 3:59 PM
    MtnKris
    22 Trail
  6. Mar 20, 2024 at 4:03 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Depending on how the pillar lights are wired will determine how they are activated. You'd have to find out how those lights are triggered to determine how to disable the running light.
    Ultimately, the unfun answer is to ditch the Alpharex, and go back to stock. The Morimoto tails are also on par with OEM.
  7. Oct 22, 2024 at 4:15 PM
    LJrunner
    LJrunner New Member
    Has anyone installed these successfully? I have tried three different vendors. All three "wobble" and won't sit flat as they are supposed to. I think they are held away from the sheet metal on the back hatch by the plug around the wires in the center of the unit.
