Peeling head lamp?
Discussion in '5th Gen 4Runners (2010+)' started by RingSteel, Sep 4, 2019.
  1. Sep 4, 2019 at 1:40 PM
    RingSteel
    RingSteel [OP] Smooth trigger finger and she'll not let you down
    Texas Eagle-Ford Shale area dodging crazy truckers
    14' 4Runner Trail Edition Premium Nautical Blue 4wd
    Weather Tech visors and floor mats
    Question here are some pics of the top of the lens and it looks like it is peeling.
    Anyone seen this before?
    Will it get worse and need replacements?
    Not really an issue for me, but it's my honey's 4Rnr and anytime I do any work on it she's my QC inspector...lol.....anyways will stop by later see what you folks come up with.
  2. Sep 5, 2019 at 12:03 PM
    rrod
    rrod New Member
    2016 MGM 4Runner SR5
    Im having the exact same issue. I was gong to ask the dealer if that should be happening so soon.
  3. Sep 5, 2019 at 12:27 PM
    jerodsand
    jerodsand New Member
    Jerod
    Central Texas
    2018 4runner TRD Off Road Premium | 1997 Toyota Tacoma
    3" ToyTec lift,
    Is that peeling on the inside of the light?
  4. Sep 5, 2019 at 12:59 PM
    rrod
    rrod New Member
    mine is happening on the outside. BTW, I'm in the Texas extreme heat- wonder if that's got something to do with it.
    Sanchezamed.as@gmail likes this.
  5. Sep 5, 2019 at 2:23 PM
    RingSteel
    Peeling from the outside for sure, can feel it when running a fingernail over it.
    I see, others with similar issues.
    Let us know what dealer tells you.
    Mine is out of warranty for sure, at this point not ready to decide which direction to go.
    Thanks for chiming in everyone. maybe a root cause and solution can come forth.
  6. Sep 5, 2019 at 7:31 PM
    DrewMan
    DrewMan 2016 4RTP
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    Curious are you running Stock/OEM bulbs for headlights? … I own a 2016 and mine is not doing it yet.
  7. Sep 5, 2019 at 8:34 PM
    RingSteel
    All OEM but for tires, floor mats, vent visors.
    It's hers so, it's a I like this way don't touch but take care of it....lol.....
    So yeah no additional heat from after market lamps. Good question indeed.
    DrewMan likes this.
  8. Sep 6, 2019 at 4:29 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    I always keep the plastic lenses waxed helps keep them nicer longer and down the road it'll delay the inevitable hazing. Usually just hit them with Griots Garage spray wax now and then.
  9. Sep 6, 2019 at 5:47 AM
    RingSteel
    Yup normally apply a polish to all plastic components as well.
    The lens have no hazing at all in this case. Just a bad case of sunburn? peeling or shedding of top layer of its skin.
  10. Sep 6, 2019 at 2:35 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    looks like someone sprayed a lamp lens coating on it.
    since it looks bad wet sand it with 600 then 1000 then 1500 .. then use meg plastex lens polish with a foam pad
  11. Sep 7, 2019 at 12:32 PM
    RingSteel
    Hmm interesting. Did not know a dealer would apply such product, since it was never mentioned. But will look at where to get the product you suggested. Looks like a easy project in the shop when it cools down to 90....lol......
  12. Sep 7, 2019 at 4:36 PM
    DrewMan
    DrewMan 2016 4RTP
    Middle Tennessee
    I see and understand; well that rules out possibly over heated lights … next question, has the vehicle ever been in a wreck that where the front and/or hood had to be repainted because it looks like over spray from a clear coat …
  13. Sep 8, 2019 at 11:30 AM
    RingSteel
    Nope no wreck just lots of those love bugs melted into the clear coat.
  14. Sep 8, 2019 at 3:37 PM
    DrewMan
    DrewMan 2016 4RTP
    Middle Tennessee
    Hmmm, I can’t think of anything else but that freakin bites to know what’s going to happen after 5 yrs of ownership … guess I would try “J Cat’s” recommendation … good luck
  15. Sep 8, 2019 at 4:25 PM
    RingSteel
    Yeah I hear yah...do appreciate all the input though. Plus interesting to see others have this issue as well.
    Soon as it drops down to a balmy 80 degrees or will get the wet sand paper and give it a go.
    Thanks everyone.
  16. Sep 9, 2019 at 6:32 PM
    Davidpsalt
    Davidpsalt New Member
    David
    Atlanta GA
    2014 4runner Trail
    TRD 17" Black Wheels, BFG AT KO's 275/70/17, Leather Seats w/ heat - planning a 2.5" lift
    Have the same issue on my 2014 ... no hazing and doesn’t effects the lights in one bit - just looks kind of crappy. I may try sanding and polishing per the earlier recommendation.
  17. Sep 10, 2019 at 12:59 PM
    RingSteel
    Well this is interesting lol....looks like a few others as well have noticed this.
    Next time I'm in town will dive to the dealer and ask the SM what's up. Thanks for the info.
