p0171
Discussion in '3rd Gen 4Runners (1996-2002)' started by rmz489, Apr 20, 2016.
  1. Apr 20, 2016 at 7:49 AM
    rmz489
    rmz489 [OP] New Member
    Austin
    2001 forest green sr5 4runner
    3 in' lift,atermakret wheels, intake, flomaster exahaust, tundra adjustable front shocks
    Hey guys, I figured I would go at this a second time with a little more educated a post. I'm throwing a lean code p0171 on my 03 4runner. The code fired after I had taken the truck out in the desert for some fun for the first time. The Mass airflow sensor was really dirty, so I cleaned that, cleared the code, and the code fired again. anyone have advice on where to proceed ? possible 02 sensor, vacuum leak?
  2. Apr 20, 2016 at 3:26 PM
    irishfury
    irishfury New Member
    Sean
    Birmingham, Alabama
    1999 Black 4Runner Limited 4wd
    I've seen some posts about two wires inside the mass airflow sensor that need to be cleaned. Did you happen clean those? There are some other troubleshooting tips in the following link such as checking for leaks in the vacuum tubes.
    rmz489[OP] likes this.
  3. May 19, 2016 at 2:43 AM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    Did you get this fixed?
  4. May 19, 2016 at 5:35 PM
    rmz489
    Austin
    The light actually turned off on its own and has been off since
