Overland Torque Tune (OTT) by Overland Tailor
Discussion in '5th Gen 4Runners (2010-2024)' started by JustDSM, Sep 23, 2022.
  1. Jul 21, 2025 at 9:35 AM
    #301
    The throttle will no doubt be more sensitive on the medium and spicy tunes, but you get used to it in 5 minutes or less and your brain adjusts your foot and how you apply pressure to the pedal. The 2023 we had tuned is my wifes daily, i rarely ever drive it. I daily a 2008 4R that has "perfect" tuning, it feels great and everything is really nice about it. When i do hop in the wifes and move it i'll spin the tires on the gravel the first time and then say "whoops" and almost automatically my brain changes the throttle application and foot pressure applied to the throttle without even noticing it. Once you take off a time or two your foot wont smash the pedal 10% just to get you moving anymore.
    We have spicy, the super spicy i would only recommend for 34-35" tires and or a lot of weight. We have 305/50-20 and the tune drives like a dream now but it will chirp the tires on pavement if you are not careful.
    Lc200[QUOTED] and JustDSM[OP] like this.
  2. Jul 21, 2025 at 11:24 AM
    #302
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I found (OTT) the initial tune it was too aggressive, especially after being used to the 4Runner’s stock set up. I already had a throttle controller (Ultimate 9) which I only used to disengage the gas pedal for overnight parking (as part of layered anti theft approach). I ended up with the mild OTT flash, and I use the throttle controller in the Ecomode at its highest setting. Take off is smooth and a gentle to a little laggy, but I’m focused on fuel savings and ease on drivetrain. I also liked when some slow paced offroading dropping the Eco setting more to not have hard sections spin out
  3. Jul 21, 2025 at 6:12 PM
    #303
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Thank you for the explanation. It's like any other ECU tune then.
    I guess I will have to see if I can drive one that has this tune to see if it works for me.
  4. Sep 21, 2025 at 5:49 AM
    #304
    AR1978
    AR1978 New Member
    2015 4Runner Trail Premium
    I have a 2015 4Runner. Is there an update on when the OTT Tune is going to update the transmission and not just the ECU?
  5. Sep 21, 2025 at 7:19 AM
    #305
    This question has been asked pretty much for the last 3 years since this thread was created in 2022, with no definitive answer to date. What's interesting is the list of all the other vehicles, all with transmission tuning included, during and prior to the 2013-2019 run of the 4R, which doesn't include it...
  6. Sep 21, 2025 at 1:37 PM
    #306
    JustDSM
    JustDSM [OP] New Member
    Justin
    4wd??
    Please keep an eye on our socials for an update posted here in the coming weeks. ;)
    The difference is that the TCU calibration data on the vehicles, which we currently do not list transmission support for, have the calibration data for the TCU stored on a seperate chipset on the ECU board. All the tools on the market only pull data from the chipset which contains the 'engine calibration' data leaving the data on the 2nd chipset (TCU) untouched.
    Getting the data from that 2nd chipset is the challenge. As mentioned above please stay tuned to our socials in the coming weeks and expect a post here.
    Charlievee and Nubes like this.
  7. Sep 22, 2025 at 12:33 PM
    #307
    AR1978
    AR1978 New Member
    JustDSM - yes my 2015 4Runner is a 4WD Trail Premium and I'll keep watching to see if OTT makes an announcement.
    JustDSM[QUOTED][OP] likes this.
  8. Oct 3, 2025 at 6:27 PM
    #308
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    Searching on your website. I noticed you dynod both a 5gen 4runner and a 2010+ fj. How did the fj put down a decent bit more power and torque then the 4runner?
    JustDSM[OP] likes this.
  9. Oct 3, 2025 at 8:45 PM
    #309
    JustDSM
    Justin
    Our web developer mixed up the charts.
    Thanks for pointing that out, we'll get it corrected. The numbers are the same between the FJ/5G 4Runner (in automatic transmission trim)
    hossler1788[QUOTED] likes this.
  10. Oct 7, 2025 at 9:53 AM
    #310
    JustDSM
    Justin
  11. Oct 7, 2025 at 10:30 AM
    #311
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Nice.
    Question for you... can you eliminate the check engine light from adding headers to 2020 4runner
  12. Oct 7, 2025 at 10:31 AM
    #312
    JustDSM
    Justin
    Can we? It's possible, but we don't defeat emissions in our calibrations.
    NB4x4 likes this.
  13. Oct 7, 2025 at 10:32 AM
    #313
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    I dont have emissions testing. Does adding headers require a custom tune?
    NB4x4 likes this.
  14. Oct 7, 2025 at 10:33 AM
    #314
    JustDSM
    Justin
    We don't turn off CEL's, which is a form of deleting federally mandated emissions components.
  15. Oct 7, 2025 at 2:37 PM
    #315
    BADCLOWN
    BADCLOWN New Member
    NKY/Cinci
    2017 Cement T4R TRDP
    Toytec, Alpharex, updated TRDP wheels, URD, Alpine, Canvasback, OEM+
    Got a call from my local OTT rep who did the ECU tune on my 2017. He said the TCU tune is done and more info will be available soon in order to schedule for the software to be installed.
    boostedka likes this.
  16. Oct 7, 2025 at 2:47 PM
    #316
    Charlievee
    Charlievee Not new member.
    If we do decide to get the transmission parameters adjusted (guessing that's what this is alluding), it will require the whole ecu to be done... So, another full price tuning session?
  17. Oct 7, 2025 at 4:44 PM
    #317
    BADCLOWN
    BADCLOWN New Member
    NKY/Cinci
    My tuner stated that the TCU update will be free of charge since I already paid for the ECU tune
  18. Oct 9, 2025 at 9:09 AM
    #318
    JustDSM
    Justin
    Overland Tailor Tuning is proud to release a world-first — full TCU tuning for the 2013–2019 Toyota 4Runner, in both 2WD and 4WD configurations.
    babaki1, boostedka and Nubes like this.
  19. Oct 9, 2025 at 9:29 AM
    #319
    20 Venture/17 Taco
    :spending:
    CA4runner likes this.
  20. Oct 9, 2025 at 9:30 AM
    #320
    JustDSM
    Justin
    Free update for existing customers
    Does not require the whole tune to be reflashed. As mentioned in another post I made earlier, the TCU calibration is contained on a separate chipset than the engine calibration. So we can update the TCU independently of the engine calibration.
    ChessGuy[QUOTED] likes this.
  21. Oct 9, 2025 at 10:58 AM
    #321
    What is the difference between the 2010-2012 and the 2020+
    What makes the 2013-2019 different? Are you doing trans tuning on the 2010-2012 and 2020+? I have a 2023 done and i am pretty sure we talked and the 2023 did not get any trans tuning.
  22. Oct 9, 2025 at 11:02 AM
    #322
    JustDSM
    Justin
    2010-2012 & 2020+ have the TCU calibration data embedded within the engine calibration on 1 chipset. We have the ability to tune it directly with one single flash. We have always had the TCU updates "embedded" into our tuning for these vehicles.
    The 2013-2019's do not (as explained above) and require a 2nd flash for the TCU chipset.
    If OTT tuned your 2023, it most certainly has the TCU calibrated. It's designed to be seamless and not jump out at you, so it's doing its job, :) I promise you. If we put it back to "stock," you'd notice the difference. ;)
  23. Oct 18, 2025 at 9:10 AM
    #323
    CarloM213
    CarloM213 New Member
    CarloM
    2019 Magnetic Gray 4runner
    4.88 gears 35s
    I just got the TCU for my 2019 4runner. It holds the gearing for all power band 1st to 5th with no struggle and shifting is smooth. No more uphill battle with throttle. Feels like im driving a stock 4runner with 35s.
  24. Oct 18, 2025 at 10:34 AM
    #324
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    I too have a 19 but im on 32s and have been thinking of getting the tune since now the TCU tune is avail.
  25. Oct 18, 2025 at 12:43 PM
    #325
    CarloM213
    CarloM
    4.88 gears 35s
    You should get the tune even if you have stock gears and 32s. You will enjoy every minute you drive specially going uphill.
  26. Oct 18, 2025 at 4:53 PM
    #326
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    Nice! Enjoy it and reach out if you need any adjustments. It’s $free.99 for updates.
    It makes a huge difference. Find your local tuner and get it done.
  27. Nov 2, 2025 at 7:55 PM
    #327
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Does your 2020+ 4r tune offer gearlock?
  28. Nov 3, 2025 at 7:19 AM
    #328
    BortisYeltzen
    SLC, UT
    2021 T4R ORP
    In-Progress
    VF tuner did release an EROM a few years back that allows a gearlock function in S-mode. It’s been a while since I played with it, but it did work at one time. If it is still working, it may only work on 2020+ 5GT4R’s as those are the only years VF has TCU access and the EROM capabilities.
    @JustDSM is this something that can be added to the current tunes? We can retest it in mine if needed.
  29. Feb 17, 2026 at 9:33 AM
    #329
    JSP127
    JSP127 New Member
    Just got the OTT done yesterday now that the TCU is unlocked for the 2013-2019 years. Absolutely fantastic tune and I highly recommend it. Paul from PNW Tuning was great and a super nice dude. Shifting is worlds better, especially up hills. Throttle response if awesome (went with Spicy). Takes a little getting used to in stop and go traffic, but its a blast to drive now. If you are on the fence, just do it.
    BortisYeltzen likes this.
  30. Feb 17, 2026 at 9:47 AM
    #330
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    So in stop and go traffic, the throttle is very sensitive and makes the car jerky/jumpy?
    I hate that about these tunes. Good out on the highway or hills etc but miserable in slow moving city traffic.
