Overheating
Discussion in '4th Gen 4Runners (2003-2009)' started by orange01z28, Jun 29, 2024.
  1. Jun 29, 2024 at 12:02 PM
    orange01z28
    orange01z28 [OP] New Member
    Andrew
    AZ
    2003 SR5 4WD 236k miles
    3" Icon Stage 3 Lift Metaltech rear control arms Metaltech bump stop extensions 35 x 11.5 Falken Wildpeak RT01
    After 20 years with no issues my V6 2003 started having issues on a roadtrip.
    Filling it with coolant from time to time got me all the way home. As long as I was moving it was fine
    Then I had it in a shop for a pressure test and a flush. There were no leaks but the fan clutch was replaced.
    this seemed fine until I took it out today, after a 1.5 hour drive it started getting hot again, then it had a full boil over and was staying hot. It dropped into normal range a couple times but finally got hot enough that I pulled over and am waiting for a tow right now
    The water pump has been replaced in its lifetime, but the radiator has not. I also noticed it getting much cooler than it should be when not under load, like a bad thermostat or something
    should I go ahead and replace the whole radiator or could this be a thermostat problem? It takes literal hours of driving to recreate the problem.
  2. Jun 29, 2024 at 12:35 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Replace the thermostat and see if that works?
    The thing that opens and closes to let's water flow through the engine from the radiator based on temperature might have gone out.
    Happened one time to a car I used to have.
    orange01z28[OP] likes this.
  3. Jun 30, 2024 at 4:56 AM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    Agree with thermostat replacement. Would also replace radiator cap if you have not done so in the last couple of years. Two inexpensive things you can do yourself. Also, make sure your engine coolant is the correct mix - Toyota Pink is premixed so if you are adding that you are good. Then see how it goes regarding radiator or water pump replacement.
  4. Jun 30, 2024 at 5:12 AM
    I would do radiator as well. You might have a restriction inside, like debris or residue over the years that has gone stuck and impossible to see.
  5. Jun 30, 2024 at 3:52 PM
    orange01z28
    Andrew
    AZ
    I'm definitely leaning this way, I might just do the water pump while i'm at it
  6. Jun 30, 2024 at 4:25 PM
    Lost Woods
    Lost Woods New Member
    Before you just throw money at a radiator, get an infrared thermometer and start spot checking. If you have an obstruction, you should have cold spots. Thermostat stuck open sounds about right for the symptoms assuming the fan is good.
    If you're paying someone to do this, just say overheating and the fan clutch is new. Don't ask for parts, it's not their responsibility to make sure something is defective before replacing it.
  7. Jul 17, 2024 at 9:49 AM
    orange01z28
    Andrew
    AZ
    At the end of the day, the thermostat falling to pieces was the likely culprit
    However, while I was at it, I had my shop put in a new radiator as well as rebuild the fan clutch by changing the oil they come with and putting in some thicker stuff along with optimizing the temp the clutch will start to move air.
    They do this with 80 Series a lot and it really helps
    Everything is running perfect now. I went wheeling last weekend and spent the whole day with teh AC on. Temp was always exactly where it was supposed to be
    RonT4R and gkomo like this.
  8. Aug 5, 2024 at 8:40 PM
    Vinchenzo
    Vinchenzo New Member
    Vinchenzo
    phoenix, az
    2006 SR5 4Runner
    Lift Bilstein 2" Front, Toytec springs 2" rear
    Didn't know you could mod the fan clutch. Will have to look into this as I replaced everything in my cooling system including multiple caps and this is my second fan clutch in 1.5 yrs.
  9. Aug 6, 2024 at 8:59 AM
    orange01z28
    Andrew
    AZ
    I see you're in the Phoenix area. I can send you a phone number of a shop that will do it if you don't want to tackle it yourself
  10. Aug 6, 2024 at 11:59 AM
    Vinchenzo
    Vinchenzo
    phoenix, az
    2006 SR5 4Runner
    Yes - would love to know of a shop that can do this in the Phx area.
  11. Aug 12, 2024 at 8:09 AM
    Vinchenzo
    Vinchenzo
    phoenix, az
    2006 SR5 4Runner
    FYUI My engine idles at about 650 rpm. Turning the AC on does not increase idle speed. Pretty sure the fan is not moving enough air at an idle. Going to look into that, but modding the fan clutch does sound like a good idea. Would like to know the shop that can do that.
  12. Aug 12, 2024 at 8:20 AM
    orange01z28
    Andrew
    AZ
    Check your PMs, I sent you a phone number last week
  13. Aug 12, 2024 at 8:29 AM
    Vinchenzo
    Vinchenzo
    phoenix, az
    2006 SR5 4Runner
    Got it - Thanks will pursue. Appreciate your help!
