Overdrive won't engage on 93 4Runner
Discussion in '2nd Gen 4Runners (1990-1995)' started by Stwalk2, May 8, 2021.
  1. May 8, 2021 at 8:59 AM
    Stwalk2
    Stwalk2 [OP] New Member
    Steve
    93 4 runner
    4wd was changed to 2wd by somebody who didn't finish the job
    It turned into a project with burnt valve, dead Catalytic Conv., and a transmission that wont shift to overdrive. Heads were fun with that intake but got past that. Cat is ready to install but still struggling with the overdrive. I've replaced both of the water temp sensors. The cold start seems to work fine but the overdrive still wont engage. I've disconnected the trans solenoids at the transmission and it defaulted to manual 1st, 3rd and overdrive just like it's supposed to which leads me to signal not getting to the trans from the computer. Am I correct in assuming that the sensor must be working if the cold start is working?
    Some introduction, eh?
  2. May 8, 2021 at 9:17 AM
    Welcome!
  3. Mar 26, 2025 at 12:15 PM
    taiter
    taiter New Member
    Tait
    Fort Collins, CO
    1993 4Runner
    3.4 swap, solid front axle, front and rear locked
    I hate to try to revive an old thread but did you every solve the transmission issue? I'm having the same issue with my '93.
