Over tightened oil filter
Discussion in '5th Gen 4Runners (2010-2024)' started by vancetrack, May 10, 2019.
  1. May 10, 2019 at 9:52 AM
    vancetrack
    vancetrack [OP] New Member
    Doug
    2018 limited
    I have a 2018 4runner that I changed oil on at 5k dealer (Toyota) did at 10k. Yesterday I attempted to change my oil again at 15k, drained oil and went to remove oil filter with metal Toyota filter wrench and end up breaking off one of the metal tabs on the filter which left a pin hole in canister and still could not budge loose. I used a 18 in breaker bar with 3/8 drive and all I could do is strip out the inside of the 3/8 drive. I then had to call a tow truck to take 4 runner back to dealership (20 miles) where they got the damaged filter off, install new one and fill with oil. $195 plus $175 towing bill.!!! I asked the mech. how he got it off and they use a 64mm Bluepoint steel 14 facet socket with 24 in breaker bar. I think that’s how they install them too. My Question is, I thought those filters should only be 12 ft. lbs tight. They also said they get about 2 to 3 of these problems a week.$$$$$ I really thought if I took my car to authorized dealer I would be much better off then the discount oil change store. Has anyone of you that do you own changes run into this problem?
    TN_FunRunner likes this.
  2. May 10, 2019 at 10:08 AM
    Nope. Problem is you let someone else change oil dealer or not.
    ManBeast, WallyT4R and Backslider like this.
  3. May 10, 2019 at 10:09 AM
    4X4Runner
    The left coast
    Lube techs are your fresh off the street employees with more than likely, minimal knowledge on how to properly do the job.
    Be happy they didn’t drain the transmission and overfill the engine
  4. May 10, 2019 at 11:51 AM
    WallyT4R
    WallyT4R New Member
    Funny how the dealer states they run into that problem 2 or 3 times a week since they are the ones gorilla tightening the filters/filter covers in the first place. Total BS, hope you get your money back.
    scottalot and Thatbassguy like this.
  5. May 10, 2019 at 3:19 PM
    Hans Moleman
    Hans Moleman New Member
    SF Bay
    So it sounds like we should be using this socket instead of the ones with slots for the tabs
    [​IMG] [​IMG]
    vancetrack[OP] and ManBeast like this.
  6. May 10, 2019 at 4:08 PM
    vancetrack
    Doug
    2018 limited
    yes!!!! I totally agree, all the others available on Amazon are a wast of money. $25 spend another $5 and get the one the idiots who over tighten them you’ll be able to get off. yes
  7. May 10, 2019 at 4:26 PM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Or spend 40
    Doglover2003 likes this.
  8. May 10, 2019 at 5:33 PM
    The one with the slots are 10x better. It grabs the tabs and it also has the flutes or whatever you call it to grab the rest of the housing.
    Or the one I do does.
    WallyT4R likes this.
  9. May 10, 2019 at 5:37 PM
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    Is there a metal housing just like the Tacoma?
    Disclaimer I have not been up under the truck yet to see.....
    scottalot likes this.
  10. May 10, 2019 at 7:33 PM
    2016Pro
    There is zero reason to change synthetic oil every 5,000 miles
  11. May 10, 2019 at 9:27 PM
    4X4Runner
    The left coast
    ipnpulz[QUOTED] and scottalot like this.
  12. May 10, 2019 at 9:30 PM
    4X4Runner
    The left coast
    Unless you’re in stop and go traffic every damn day. Takes two hours to go 20 miles here. Shit, I’m at 40k and looking at replacing brake pads soon.
    ipnpulz and WallyT4R like this.
  13. May 11, 2019 at 3:34 AM
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
  14. May 11, 2019 at 5:18 AM
    ipnpulz
    ipnpulz New Member
  15. May 11, 2019 at 6:57 AM
    57HotrodVW
    57HotrodVW New Member
    Eric
    '18 Cavalry Blue TRD Pro
    TN_FunRunner and WallyT4R like this.
  16. May 11, 2019 at 7:18 AM
    vancetrack
    Doug
    2018 limited
  17. May 11, 2019 at 7:27 AM
    57HotrodVW
    Eric
  18. May 11, 2019 at 7:46 AM
    ipnpulz
    ipnpulz New Member
    That website can be very very dangerous
  19. May 11, 2019 at 8:25 AM
    57HotrodVW
    Eric
    Not to your brain, but maybe to your wallet...
    Ideas galore!
    ipnpulz[QUOTED] likes this.
  20. May 11, 2019 at 9:06 AM
    ipnpulz
    ipnpulz New Member
    Yes indeed maybe even more so than my 17 TRD Off-Road mods
  21. May 11, 2019 at 9:53 AM
    2016Pro
    Still no reason to change at 5000
  22. May 11, 2019 at 11:17 AM
  23. May 11, 2019 at 1:57 PM
    lyodbraun
    lyodbraun New Member
    Northwest Ohio
    2018 4RUNNER
    Cause Amazon is dumb LOL
  24. May 11, 2019 at 5:06 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    sorry for your loss .. you should have called the dealership and tell them that they over torqued the filter cap and it is now leaking . I hope you have your paper work on their free oil servicing ..if they do not give back your loss then post this dealership on facebook and here so others will stay away from the idiots that work there.
    I never had any problems changing my oil , cap comes off easy .. ya 12 ft lbs and oil on the cap O ring NO problem..
    surprised you did not mention they broke the pan bolts.
  25. May 12, 2019 at 7:12 PM
    Tuco S.
    Tuco S. New Member
    Seen way too many threads like this. And it's not a Toyota thing, it's a dealership thing. Go to any manufacturer's forums and you'll read the same horror stories about dealership oil changes.
    I owned VWs for years and learned how to do nearly all of my own routine maintenance because of botched dealership oil changes.
    I'm not even going to bother with that Toyotacare BS.
    j cat and WallyT4R like this.
  26. May 13, 2019 at 1:58 PM
    BCMUSA
    BCMUSA New Member
    Sin City
    2019 4R TRD OR
    I am going to take mine in for the services, but will tell them I am doing my own oil changes.
    I don't want some high school kids touching my car.
    With my luck they'll fill the windshield washer fluid reservoir with oil lol...
  27. May 14, 2019 at 4:56 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Still on the fence about dealer doing anything I brought it in for the 5,000 "check" but that didn't include oil. I did do oil somewhere around 5,000 miles just because I always will synthetic or not but a garage I like to use did it.
  28. May 14, 2019 at 5:37 AM
    ipnpulz
    ipnpulz New Member
    Getting ready for DIY stuff in the next few days....
  29. May 14, 2019 at 5:45 AM
    Agent_Outside
    Built 2011 T4R Limited
    Well that’s strange.... when I look up recommendations directly for the 2016 4Runner you own, the manufacturer gives multiple reasons/conditions that you should change it every 5,000 miles. I’m sure the engineers that designed it don’t know what they are talking about though.
  30. May 15, 2019 at 4:24 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
