Outside door trim
Discussion in '4th Gen 4Runners (2003-2009)' started by Rsmith99, Mar 8, 2017.
  1. Mar 8, 2017 at 8:52 PM
    Rsmith99
    Rsmith99 [OP] New Member
    Ron
    2004 4Runner
    None
    I have a 2004 4Runner.
    The right rear door got damaged. I removed the plastic panel and had it repainted. When I removed the panel, some of the plastic clips stayed on the panel, some stated on the door.
    I have new plastic clips. Do I install them on the plastic panel, or on the door? I'm sure there is a correct way.
  2. Mar 9, 2017 at 4:24 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    When I repaired my 4Runner I installed them on the trim piece and snapped them in, Either way will work. Guess it is what is easiest for that particular panel.
  3. Sep 18, 2024 at 4:12 PM
    Brijoy91
    Brijoy91 New Member
    2005 Toyota 4Runner
    Can you go over how you removed the panel? My panel is about to fall off and I want to replace the clips but I’m not certain where to get the clips and how to remove the panel without breaking something. Your help is appreciated
  4. Sep 18, 2024 at 9:55 PM
    4R777
    4R777 New Member
    Factory Repair Manual Guide for 4th Gen 4Runner
    • Outside molding components
    • Removal
    • Installation
  5. Feb 25, 2025 at 10:11 AM
    ASK03SEV8
    ASK03SEV8 New Member
    Hello!
    It's been some time, but checking to learn your process of reinstallation as I am about to do this and would like to know how you did it.
    Thank you!
  6. Apr 28, 2025 at 4:12 PM
    Jose2004Runner
    Jose2004Runner New Member
    Yesterday
    Jose
    2004 Toyota 4Runner 4.7L V8
    I need to replace both the front door and back right door in my 2004 4Runner. Parts are not cheap.
