Ordering adjustable coilovers?
Discussion in 'Suspension' started by Rngr188, Nov 8, 2020.
  1. Nov 8, 2020 at 4:29 PM
    Rngr188
    Rngr188 [OP] New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    So when ordering adjustable coilovers (King, Fox, Icon, etc.) do you specify the height you want from the vendor or set the height when you receive them? I know it can be changed after insall just wondering about how they come out of the box.
  2. Nov 8, 2020 at 7:33 PM
    06_dark_knight
    06_dark_knight New Member
    Mario
    06 sr5 in black
    Lights all around. IVD front standard travel
    When I got my icons they came out of the box at 2.5”. They settled a bit but I just adjusted them back up to about 2.75”
  3. Nov 9, 2020 at 4:24 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    2.5" Fox Suspension
    The short answer is no. Every vehicle is different and will require its own amount of preload to get the ride height you want. Often times people will search on the forums to see how much preload others are running to get a close idea. Keep in mind, preload does NOT equal the amount of threads showing on the shock body. If you go with Fox or King, I can let you know the max recommend height.
    Couple good articles that may explain it some more:
    https://accutuneoffroad.com/articles/tacoma-4runner-coilover-preload-faq/
    https://accutuneoffroad.com/oem-front-coilover-shock-setup/
    Thatbassguy and 06_dark_knight like this.
  4. Nov 9, 2020 at 5:47 PM
    06_dark_knight
    Mario
    06 sr5 in black
    ^^^ this is correct. I was referring to lift height not threads showing
    AccuTune Offroad likes this.
