One brake light stopped working
Discussion in 'Lighting' started by SunnyRunner, Apr 29, 2024.
  1. Apr 29, 2024 at 9:36 AM
    SunnyRunner
    SunnyRunner [OP] New Member
    Andre
    2010 Salsa Red Pearl Limited
    I noticed on Friday my left brake light was out. I put a new bulb in and it still wasn't working. Tried a second new bulb and no go. Then I swapped the whole bulb and holder to the right side and it was working fine. The bulb and holder from the right side stopped working when installed in the left side.
    Taillights work fine. Just not the brake light on the left side.
    Any thoughts? What should I check? The fuse is good, obviously.
  2. Apr 29, 2024 at 11:23 AM
    steelevo
    Utah
    Welcome.
  3. Apr 29, 2024 at 12:20 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Those "buckets" pickup their ground from a point right behind them. They rend to develop corrosion rather badly. Might want to pull the whole left "bucket" out, and check it's ground point. Check the ground for corrosion, dirt build up, loose bolt, whatever.
    Pat☺
    2Toys likes this.
  4. Apr 29, 2024 at 1:56 PM
    SunnyRunner
    Andre
    Thank you!
  5. Apr 29, 2024 at 1:56 PM
    SunnyRunner
    Andre
    Thanks! I'll check it out when I get home.
  6. Apr 29, 2024 at 1:58 PM
    SunnyRunner
    Andre
    Do the taillight and the brake light not share a ground?
  7. Apr 29, 2024 at 2:01 PM
    steelevo
    Utah
    They share the same ground point but may be individual cables. Have you tested the voltage from the connector or wire? I would check there first, both the positive and ground.
