onboard CO2 tank instead of air compressor
Discussion in 'General 4Runner Talk' started by eaglescout, Aug 21, 2018.
  1. Aug 21, 2018 at 10:29 AM
    eaglescout
    eaglescout [OP] 2018 SR5
    Middle Tennessee
    2018 Magnetic Gray Metallic SR5
    FN FX PRo Wheels Matte Dark Bronze. Nitto Ridge Grappler 285/70/17/load C 3" Dobinson Coil Lift Blackout Kit Raptor Style Grill LED C4 Fab Lo Pro Winch Bumper LFD Offroad Skid Plate Shrockworks Sliders Rago Molle Panels Extreme LED Ditch Lights Ecotechne Roof Rack Detours Offroad Swingout Tire Carrier
    Anybody use CO2 tank instead of onboard air compressor? What are Pros and Cons of each?
  2. Aug 21, 2018 at 4:22 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    I've used a a co2 tank. Air nozzle, run a die grinder, re inflate tires. Was pretty cool. Buddy of mine used a small lb one, to run his air locker. Got many trips outta it before needing to refill. Which, brings me to the CON part of tanks. Refilling, while fairly cheap, could be a bit of a drag.. I used a soda plant/filler local...
    eaglescout[OP] likes this.
  3. Aug 21, 2018 at 5:32 PM
    Ric
    Ric New Member
    Ric
    well I will give my experience, Ive been wheeling now for about 15 years, Ive had CO2 and the air compressors. There is only 1 compressor that is as fast as a freshly filled CO2 tank, and that is the Oasis compressor but you're looking at aver $1000.. I promise it IS as fast as a CO2 tank, we tested it side by side, with exact same tires/size at about 10,000 ft.
    OK this is just my opinion, if you can do both, DO IT.... CO2 runs out, CO2 is FAST. BUT unless you have a Sifon tube installed in the bottle you will have to make sure the bottle/tank is standing upright when filling tires.
    IIRC my sifon tube cost about $30 to have installed, nothing to bad but you're able to lay the bottle down and bolted never having to take the tank out. Really nice.
    Once others see you have CO2 they will, ask if you will fill their tires lol.
    Oh,, when you do run out of CO2 you will have to get it re-filled, thats money, also most place will just swap your tank, with a used tank. So if you decide to go this route, make sure you buy a used tank lol. UNLESS you find a place that will re-fill YOUR tank.
    Compressors, well with a tank or two, they are just so convenient, you will never be without air.. right now Im running a viair with a 2.5G tank and the tank is not big enough, I will be adding a couple more tanks where the stock spare tire went (I have a tire carrier now)
    Another benefit of a compressor is, when you camping you can stock the campfire lol yes it works...
    Compressors price range is huge, do your research on Duty-Cycles and what you want and how often will you go 4wheeling..
    In the end, Im very happy with the compressor route, but will also be getting a 20# CO2 tank as a back up.
    I hope this helps.
    eaglescout[OP] and SlvrSlug like this.
  4. Sep 18, 2018 at 8:28 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Tanks are SUPER fast.... but also a PITA to have to get refilled. And that is here in So Cal with plenty of locations. Seems like half the time they want you to drop it off and come back. I don't have time for that. Fortunately I was only borrowing my buddy's tank to test it out and get it refilled. I gave it back to him and he agreed, getting it refilled is a PITA. IMO it really sucks to have to add yet another errand that I need to do on my time off so that I can be prepared to go wheeling.
    I had an ARB Twin Air on my jeep. Worked great but it was mounted on the jeep and I let it go with the jeep when I sold it. I have since picked up an ARB Single that is portable and mounted in a plastic tool box. Only slightly slower than the Twin, cheaper, lighter, mobile so I can use it with any vehicle. I am very happy with it. YMMV. Good luck.
