Oil filters mixup - 04152-YZZA1 vs 04152-YZZA5
Discussion in '5th Gen 4Runners (2010-2024)' started by redfield, Oct 31, 2022.
  1. Oct 31, 2022 at 8:03 AM
    redfield
    redfield [OP] New Member
  2. Oct 31, 2022 at 8:08 AM
    My guess is that the shorter filter will allow some oil to circulate without being filtered.
    If it was me, I would replace the filter with the correct one. You don’t need to replace the oil, but may need to add a little.
  3. Oct 31, 2022 at 8:25 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    Much agree with Post #2. I think I read that the A1 filter is for the RAV4 and similar engines. You need the A5. This seems to be a somewhat common mistake when purchasing Toyota filters. Keep the empty A5 box on your shelf as a reminder when the next oil change comes due.
    Slopemaster and redfield[OP] like this.
  4. Oct 31, 2022 at 8:36 AM
    redfield
    Thanks for the answers
    Can I at least drive to a store? :)
  5. Oct 31, 2022 at 9:01 AM
    2020 Venture / 2017 Tacoma
    I don't think it is a big deal to drive with the short one. Now, most of us know the sound of our vehicles when they are idle, try to hear it and see if you notice something different than before. If you do, then go ahead and replace for the correct one. My guess is that you are ok this time, but don't do it again! Good luck.
  6. Oct 31, 2022 at 9:21 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    As I recall this was an issue from Toyota during the pandemic and they replaced the one for the other. If Toyota replaced it, I wouldn't worry about it and next oil change I'd try to find the OE filter that was intended for it, if they are available.
    On average, your oil will circulate roughly 12,000x through the filter over about 3,000 miles. I'd say its safe to say that a slightly shorter filter will not affect overall filtration.
    What is the difference in height between them?
  7. Oct 31, 2022 at 9:28 AM
    redfield
    It's hard to know - the old one is already recycled and the new one is already inside
  8. Jun 29, 2024 at 7:36 AM
    M.C.AUTOWORKS
    M.C.AUTOWORKS New Member
    MARK
    LEXUS IS250
    ZERO
    I JUST USED A YZZA1 IN MY 2010 LEXUS IS250 WHICH CALLS FOR A YZZA5--YES THE ZZA1 IS A LITTLE SHORTER BUT THE A5 WAS SLIGHTLY SQUISHED WHEN REMOVED--I PUT FILTER INTO ENGINE BLOCK AND FILTER HOUSING AND DETERMINED IT WOULD WORK FINE WITHOUT BEING SQUASHED SLIGHTLY--
  9. Jun 29, 2024 at 8:29 AM
    Why are you YELLING?? :confused:
    The size of the filter is determined by the length of the stand pipe.
    kolter45 and Rocko9999 like this.
  10. Jun 29, 2024 at 8:56 AM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    Well damn, I just bought two and they are the A1 filters.
    Used my vin and everything when buying from the dealership online
