OEM TRD Pro Grille for 2022 TRD ORP?
Discussion in '5th Gen 4Runners (2010-2024)' started by Exmod, Nov 27, 2021.
  1. Nov 27, 2021 at 6:54 PM
    Exmod
    Exmod [OP] New Member
    2022 White 4Runner TRD ORP
    I want to change out the grille on my 2022 TRD Off Road Premium for the TRD Pro Heritage Grille. Looking on Toyota part websites I don’t see any 2022 grilles listed. The latest year is always 2021. Calling a Toyota dealer, I was told that Toyota is now requiring a VIN number to make sure you have a pro before getting this grille?
    Looking online I’ve seen various aftermarket versions but reviews claim the letters can be off and that the grille doesn’t fit well.
    My main question is what OEM version of the TRD Pro Grille will work with my 2022 Off Road Premium? I’ve heard TSS sensors have moved with the 2022? Any help with this is much appreciated! It’s quite hard to get solid info.
    Thanks!!!
  2. Nov 27, 2021 at 7:47 PM
    Pavo
    Pavo New Member
    It moved down if you have the front camera (multi terrain management) if you don't have the front camera then it stays in tbe same location
    Bob likes this.
  3. Nov 27, 2021 at 8:13 PM
    Exmod
    Okay so I don’t need to worry about the TSS sensor moving down then as I do not have the front camera.
  4. Nov 27, 2021 at 8:20 PM
    Exmod
    I guess I could have put the parts in question. I’m mainly curious if these will fit my 2022 TRD ORP before I buy them and take my truck apart to find out :)
    Bar and Lettering
    PZ323-35058
    Grille
    PZ327-35056
  5. Nov 27, 2021 at 8:49 PM
    lunar_t4r
    lunar_t4r New Member
    2022 Lunar Rock ORP
    yes 2020/2021 grille will work on the 2022.
    Green4Runner likes this.
  6. Nov 27, 2021 at 9:14 PM
    Exmod
  7. Nov 27, 2021 at 10:54 PM
    Green4Runner
    Green4Runner New Member
    Vannack
    2022 Military Green TRD Off Road Premium
    heres my 2022 with 2021 OEM TRDP grille and valance. No issues with anything. Note- my car did not come equipped with the MTM.
    Chucklehead and Dabigono like this.
  8. Nov 27, 2021 at 11:12 PM
    Exmod
  9. Nov 27, 2021 at 11:15 PM
    lunar_t4r
    2022 Lunar Rock ORP
    the ORP already has the valance, just silver. the SR5s do not have valance from factory, which is why he had to make some modifications in the video. if you are going from an OR/ORP, it's just as simple as swapping the valances.
  10. Nov 27, 2021 at 11:18 PM
    Exmod
    Oh man that’s so obvious now. I remembered watching this video when I first started researching 4Runners and remembering the dremeling but not the why. Thanks!
  11. Nov 27, 2021 at 11:24 PM
    Green4Runner
    Vannack
    Correct! I watched the same video and was prepared to drill but was pleasantly surprised to see everything was ready to go!.
  12. Nov 28, 2021 at 2:13 AM
    suaveflooder
    suaveflooder New Member
    Almost all of the pro grills will fit any model. Some just require a little trimming. Don’t let that stop you. I did a ton of it when I was young. I feel like people aren’t willing to do a little extra work any more. I’m cheap :notsure::notsure::notsure:
  13. Nov 28, 2021 at 7:56 AM
    Cobra1965
    Cobra1965 New Member
    FYI- the black pro lower valance can go of the front of a OR easily without removing the front bumper. 13 clips hold the silver one on.
  14. Nov 28, 2021 at 8:02 AM
    Exmod
    @Cobra1965 thats good to know. I was mentally preparing to remove the front :)
    Buying all four parts now along with a black chrome tail pipe tip.
    M3buzz likes this.
  15. Nov 30, 2021 at 3:55 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Did you happen to see if there was anything connected to that blank plate below the TSS? Or is it something that could possibly be removed?
  16. Dec 14, 2021 at 9:05 PM
    Exmod
    As an update. I was able to install the OEM Grille on the 2022 TRD Off-road. It fit perfectly.
    I was also able to install the OEM Black Valance. The only note on this is when I removed the front I found that on the 2022 the fog lights have one connection on the driver’s side instead of what most videos show which is unplugging both fog lights.
    I also installed Morimoto Headlights as well. Only issue is my brights aren’t working. Need to try unplugging battery for 4 hours.
    thanks for the info everyone!
  17. Dec 16, 2021 at 8:37 PM
    peaceloveandtattoos
    peaceloveandtattoos New Member
    ‘22 Army Green ORP
    Trd pro skid plate, roof rack, wheels, tires and lift, predator tubes
    Looks good!
    Exmod[OP] likes this.
  18. Dec 16, 2021 at 9:28 PM
    Exmod
    Ha! Thanks! I’m quite happy with it. Just gotta find the time to add the black out emblems, rear valance and black chrome exhaust tip!
    I also have and old man emu 3” lift with SCS 17x9 -38mm Ray 10s to get installed. Ive been hemming and hawing on if I should go to the 17x8.5 -10mm Ray 10s for less cutting.
    Thanks for the comment!
    peaceloveandtattoos likes this.
  19. Dec 17, 2021 at 4:09 AM
    slixx1320
    slixx1320 New Member
    That's what also confused me when removing the bumper. I unplugged both the fog lights only to find out only the main harness needed to be unplugged. Also the TSS plug needs to be disconnected as well.
    Looks good! Planning on blacking out the hood scoop as well?
    Keep your stocks. Don't sell them. You may want to go back to the OEM.
  20. Dec 17, 2021 at 5:41 AM
    cuse93
    cuse93 Ice Station Zebra
    Quick question fellas.... is there are part # for just the black front valance? I don't mind the grill on my ORP, but I really would like the valance to be black instead of silver.
    Same thing with the rear valance.... is there a part # for that?
    thanks!
  21. Dec 17, 2021 at 5:44 AM
    slixx1320
    Front # 53901-35250
    Rear # 52169-35120
  22. Dec 17, 2021 at 6:06 AM
    cuse93
    THANK YOU!
  23. Dec 17, 2021 at 6:16 AM
    cuse93
    Hoping for a confirmation/clarification...... the front valance can be swapped very easily without removing the front bumper and grill, correct?
    Also, I haven't been able to find anything on the rear valance install. Does anyone know if it can be swapped without removing the bumper in a similar manner?
    thx, really appreciate it!
  24. Dec 17, 2021 at 6:25 AM
    slixx1320
    The front bumper you can but most of the screws you loosen to access the backside has to come loose anyways (example, the bottom and sides). A few more bolts/clips behind the grill and the entire bumper comes off. Remember depending on which year you have, you will need to unplug a few harness to the folights/tss etc.. Best to just remove the entire bumper and remove those clips from the back vs pushing the bumper out to gain access underneath to those clips. Doing this, you risk popping, possibly breaking/stressing the grill/bumper.
    As for the rear, you'll need to remove it. It's easier than the front as there are no wires to unplug if I can remember. There's a few video on youtube. Just watch them and you'll have an idea.
    cuse93 likes this.
  25. Dec 17, 2021 at 10:20 AM
    Exmod
    I haven’t thought about it but I did get hit with the sun glare recently. I’m sure now that you said it, it’s going to be stuck in my head :)
    slixx1320[QUOTED] likes this.
  26. Dec 17, 2021 at 10:25 AM
    slixx1320
    Blacking the scoop out is pretty simple. Just buy some vinyl and some knifeless tape, lay it down then voila.... also the hood bulge in the front :thumbsup:. You could either just buy new and replace the hood bulge or wrap it in vinyl like how I did.
    Exmod[QUOTED][OP] likes this.
  27. Dec 19, 2021 at 7:12 AM
    mac1usa
    mac1usa New Member
    I wonder if a dealer would install an oem grill on mine. I like that look but my chrome accent running boards would probably not look good with grill. Hmm
  28. Dec 19, 2021 at 7:15 AM
    Exmod
    It really isn’t too hard to install the grille. You don’t have to take the front off. This is a great video:
    https://youtu.be/yPhC12kxmlE
    Ordered the two OEM parts and did it pretty quickly.
    Oh when I called the dealer they said something about not adding pieces from other models but that may vary dealer to dealer.
  29. Dec 19, 2021 at 7:19 AM
    mac1usa
    mac1usa New Member
    Thanks! That is a good video
  30. Dec 19, 2021 at 8:27 AM
    Exmod
    Oh when you peel off the adhesive backing and tape it up make sure you go passed the little lips that it could get stuck on when you go to pull it off :)
