OEM LED Headlight Bulb Replacement
Discussion in 'Lighting' started by HondoX10, Dec 31, 2023.
  1. Dec 31, 2023 at 2:52 PM
    HondoX10
    HondoX10 [OP] New Member
    Tyler
    2023 Silver TRD OR Premium
    Is anybody swapping out their OEM LED headlight bulbs for another LED? Talking specifically about bulb swaps, not the entire housing.
    Just curious what/if there are better LEDs out there than what comes stock on the newer model Runners.
  2. Dec 31, 2023 at 3:01 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro, 2023 Tundra Platinum Hybrid
    Someone correct me if I'm wrong, but I'm pretty sure those OEM LED housings aren't user serviceable and the entire headlight housing must be swapped if you want different bulbs.
    icebear and kmeeg like this.
  3. Dec 31, 2023 at 3:06 PM
    My understanding also. If new LEDs have problems be prepared for a big fat parts price from Toyota parts department or start your search on FB market place for take off OEM LED Housings. :facepalm:
    Then pray you don't break anything removing the bumper or fit perfectly after installing. :drunk:
  4. Dec 31, 2023 at 3:09 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    What do you not like about the oem leds?
    Trail Runnah likes this.
  5. Dec 31, 2023 at 3:29 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    While the specific housings are newish to the 4Runner, the LED system Toyota uses has been around for at least 6 years in other Toyota and Subaru models. I'm sure they're reliable.
    kmeeg[QUOTED] likes this.
  6. Dec 31, 2023 at 3:31 PM
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    I thought the OEM LED headlights were really nice? Have to be better than the halogen ones.
  7. Dec 31, 2023 at 4:00 PM
    Mod bug has bitten..
  8. Dec 31, 2023 at 5:41 PM
    HondoX10
    Tyler
    I'll have to peak under the hood tomorrow, I've never heard of that before. I was in a Gen3 Tacoma until 2 weeks ago so still figuring things out on the Runner.
  9. Dec 31, 2023 at 5:45 PM
    HondoX10
    Tyler
    No complaints yet, just asking around to see what's what. Still new to the Runner, coming from a '17 Tacoma so I'm used to having to make some upgrades, especially lighting
  10. Aug 27, 2024 at 10:10 AM
    RojoRunner
    RojoRunner New Member
    2014 4Runner
    Bump here, as one of my headlights went out this week and I'm trying to replace the bulb. Are y'all trying to tell me that is not an option on a 2014 4Runner?
    This is what came out of it:
    Seems like this bulb should fit, no? https://www.amazon.com/Lights-Bulbs-Approved-SEALIGHT-Xenon/dp/B079NSBTF8
    If no, what are my options?
  11. Sep 3, 2024 at 6:40 PM
    This thread is about the 2021+ (maybe 2020?) factory standard LED low-beam headlights.
    (I personally would like to swap in a warmer color temperature to be a little less harsh to everyone around me but I digress)
    For you, others can correct me but your 2014 likely came with halogens factory but I’m assuming the previous owner swapped those out for LEDs.
    If it’s the original housing, know it’s generally not good to have aftermarket LEDs in housings means for halogens as the light scatters differently and can mean more glare for other drivers. I don’t know if that’s for all LEDs across the price range though.
    Bagman likes this.
  12. Sep 4, 2024 at 10:29 AM
    RojoRunner
    2014 4Runner
    Is it? I don't see anything about years in the OP? That was my 1st post here, so still trying to figure out navigation.
    I'm guessing the LED were OEM because the housing the bulb goes into is 90 degrees off and points directly to the side of the vehicle. Have never seen that w/ a traditional bulb. Also, the outer lens is kind of frosted(?) and I've never seen that w/ a traditional bulb either.
    Either way, the linked LED bulb seems to be working just fine so far.
  13. Sep 4, 2024 at 11:53 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    Only the 2021+ (or maybe the 2020, I can't remember when they switched) come with OEM LED housings.
    If you want great LED's for your specific year, stick to reputable vendors. My experience with VLED's, DDM, and Diode Dynamics has been great. I'd shy away from Amazon specials.
  14. Sep 4, 2024 at 4:55 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    2014 4R came with halogen bulbs not led's
    What headlight bulb for 2014 4runner?
    "); display: inline-block; height: 24px; width: 24px; transform: rotateZ(180deg);">
    2014 to 2021 Toyota 4Runner - Headlight Bulb Sizes (Low & High Beam)
    Position Bulb Type
    Low Beam Headlights (dims)
    H11 Halogen
    High Beam Headlights (brights) 9005 Halogen
