OBD2 Scanner Users
Discussion in '5th Gen 4Runners (2010-2024)' started by rageandlove, Feb 6, 2023.
  1. Feb 6, 2023 at 2:07 PM
    rageandlove
    rageandlove [OP] New Member
    Hi. About 18 months ago I bought a OBDLink MX+ OBD2 scanner so I could watch temperatures while towing, etc.
    Worked, except for one small annoying thing - the OBDLink MX+ will just fail to connect to bluetooth periodically, and once that happens, your choice is to re-boot your phone (according to their support folks) or press the reset button on the scanner and re-set-up the bluetooth connection.
  2. Feb 6, 2023 at 2:12 PM
    kmeeg LionRunner
    Will scanguage work for your needs? I have the older scanguage 2. Now there is scanguage 3.
    rageandlove[OP] likes this.
  3. Feb 6, 2023 at 2:20 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    I use the Carista app and reader and have no complaints. It's been reliable and - as far as I can tell - accurate.
  4. Feb 7, 2023 at 6:51 AM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    I use the scanner that came with Carista and run the ODBFusion app and have never had the problems that you are having. I'd try a different ODB scanner. Also, I'm running the app on an Ipad mini but, I can't imagine that would make a difference.
    I don't think that you would need to rebuild the dashboards.
  5. Feb 7, 2023 at 8:22 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Yeah, I was close to getting Carista, looked like a great option and well regarded. Carista can do so much stuff, well worth it.
    But i ended up going with a new head unit that happened to give me some good data too.
  6. Feb 7, 2023 at 8:55 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    285/75r17 KO2, Bilstein 5100s in front, Dobinsons mid travel shocks in rear with ICON overland springs, P&P Sliders & skids, LFD front bumper, Warn EVO 10-S winch, ARB Dual Compressor w/ Bandi mount, Shrockworks Dual Battery Tray, Westcott roof rack, Kenwood DMX 8709
    What unit is that?
  7. Feb 7, 2023 at 9:09 AM
    Ripper238
    2019 TRD OR
    Kenwood DMX 1037s. I was blown away how much data this gives like tire temp and pressure for each tire. Plus you can reset codes. But yo do need iDatalink Maestro used in combo to get the data.
    ecoterragaia and 7385 like this.
  8. Feb 7, 2023 at 9:13 AM
    coryanderson
    Cory
    I dig it! How was install? I was getting ready to spend $150 alone just to get tire monitoring on my '18.
  9. Feb 7, 2023 at 9:54 AM
    Ripper238
    2019 TRD OR
    Not too bad with wiring kit. Though i did have a car audio shop do the majority of the head unit Maestro install (I did amps and speakers). Its definitely an investment, but our 4runners will last a while so its worth it.
  10. Feb 7, 2023 at 10:00 AM
    coryanderson
    Cory
    Care to share your purchase list?
    I have been wanting to upgrade my stereo system sooo badly. I did put in new door speakers, but they need amps and install the sound deadening material I bought 2 years ago.
  11. Feb 7, 2023 at 11:35 AM
    Ripper238
    2019 TRD OR
    I tried for about a year with stock then decided it was time to upgrade the stereo like i did back in the day. I really love music so it needed to be done.
    I went with Alpine R series component speakers up front, 6.5 Alpine R in back seats and 6.5 Alpine X in the rear. 6 channel Alpine 600 watt amp to power it all and the Kenwood DMX with Maestro for the best of sound quality. I didn't do a sub since i need the space and surprisingly the Alpine speakers produce some good low range.
  12. Feb 7, 2023 at 5:53 PM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    Nice. Does it provide transmission temps? I got the scangauge for towing, but that Kenwood has such a nice interface…
  13. Feb 7, 2023 at 6:05 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    Don't rely on the head units info to be accurate. I have the dash display, a head unit, and a SG3 in my Tundra and all 3 read differently.
  14. Feb 8, 2023 at 8:55 AM
    coryanderson
    Cory
    Really? I'm surprised by that. What units do you have specifically?
  15. Feb 9, 2023 at 7:42 AM
    2020 4Runner
    Fl
    My Tundra has the TPMS in the dash display. I also have a Pioneer head unit and a Scan Gauge 3. All 3 show different tire pressures. The battery is 1/2 volt lower in the radio compared to the SG.
  16. Feb 11, 2023 at 9:52 AM
    Ripper238
    2019 TRD OR
    It does not. Intake, EGT, load, breaking, voltage, 1/4mi, individual tire temp and tire pressure. You can customize some of them too.
    The interface it great and provides some really good info but its pulled from the OBD so its only as accurate as Toyota made it. Really good info even if its .5v or a few degrees different.
  17. Feb 12, 2023 at 9:01 AM
    Ripper238
    2019 TRD OR
    Sweet, ill have to check my options for Trans temp.
  18. Feb 13, 2023 at 7:00 PM
    Startrek
    Startrek New Member
    something is fishy here: T4R has no temperature sensors neither for engine oil, nor inside tire pressure sensors.
  19. Feb 13, 2023 at 8:24 PM
    rracraa
    rracraa New Member
    2008 and 2018 SR5 T4R
    My scanguage reads tpms temperature on my 4th gen, never looked at it on my 5th gen though
    Ripper238 likes this.
  20. Feb 14, 2023 at 7:55 AM
    Startrek
    Startrek New Member
    May be TPMS more sophisticated than I think. Good to know. Thanks. ("calculated oil temp")
