No spark help
Discussion in '3rd Gen 4Runners (1996-2002)' started by shake007, Nov 20, 2020.
  1. Nov 20, 2020 at 4:52 PM
    shake007
    shake007 [OP] New Member
    97’ Supercharged SR5
    Hey everyone I just changed my timing belt, head gaskets, and put some TRD headers on but now after getting it all together I'm having a no spark issue. I checked the igniter, coil packs, spark plugs, cam and crank position sensors, ground wires and can't find anything. I’m definitely getting fuel though so that’s good. Anyone got any ideas or tips on what to check next?
  2. Nov 23, 2020 at 7:28 AM
    How did you verify the crank position sensor is good?
  3. Nov 23, 2020 at 10:32 AM
    shake007
    Used a multimeter to check the ohms
  4. Dec 8, 2020 at 9:41 AM
    Did you figure this out?
  5. Dec 8, 2020 at 5:22 PM
    shake007
    I actually did. It was the stupidest thing. So when I bought a new crank position sensor it came with an o ring around the base, and I’m not sure if you’re supposed to remove it but mine wouldn’t seat all the way down so I removed it and she started right up.
  6. Dec 9, 2020 at 8:17 AM
    Nice to know! Thanks for replying!
    shake007[OP] likes this.
