No luck with Auxito LED for dome light, suggestions for alternatives?
Discussion in '5th Gen 4Runners (2010-2024)' started by canadian.bacon, Jan 6, 2021.
  1. Jan 6, 2021 at 3:28 PM
    canadian.bacon
    canadian.bacon [OP] H9 halogen is the best led bulb
    Snowland
    ‘22 Tesla Model Y
    The dome lights, which are listed as DE3175 or DE3022, do not take the Auxito brand. This applies to the 2020 4Runner TRD-OR and I suspect, the whole lineup, at least the 2020 and 2021; also they don't work in the 2021 Corolla hatchback, same dome light.
    The are a tad longer and thicker and do not fit the enclosure. See pic below.
    I am still waiting for the Yorkims, but at this point I am a bit worried those wont fit either.
    The OEM bulbs seems to be Toshiba 12V8WAT:04.
    What brands have you had luck with for the dome light? The Auxitos are cheap, the Yorkims more expensive.
  2. Jan 6, 2021 at 3:29 PM
  3. Jan 6, 2021 at 3:29 PM
    Rainier42
    Rainier42 New Member
    Johnny
    Bucks County, PA
    2020 Silver 4Runner Venture
    Sliding Cargo Tray, 265/70 R17 Falken WildPeak A/T3W tires, Interior Vled bulbs, LED Fog Lamps off of a 2020 TRD Pro w/Yellow Lamin-x film, Pedal Commander, TRD Pro shift handle, Subaru front tweeters.
    Am using Vleds, they are working fine in my 2020 4Runner's dome light.
    JET4 likes this.
  4. Jan 6, 2021 at 3:40 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    If I remember right the dome light was the biggest pain in the ass. Can you squeeze the ends with a needle nose pliers? Just for the hell of it. No harm in trying to manipulate it to fit if you can't return it.
  5. Jan 6, 2021 at 3:57 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    I was thinking about DD, hard to come by in Canada.
    They are not cheap, but I believe they are among the best in quality and durability.
    I got Yorkims for the Runner and Auxito for the Rolla, thinking out of the two, one will last longer.
  6. Jan 6, 2021 at 4:13 PM
    canadian.bacon[OP] likes this.
  7. Jan 6, 2021 at 4:35 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
  8. Jan 6, 2021 at 4:40 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    @kmeeg
    Maybe the yorkims are smaller, I have to check it out, but it says 31mm and I really tried to stick it in there, i pushed the enclosure up, out of its socket, I bent the metal clamp a bit (fixed easily), but the damn bulb wont go in.
    On the DD site they state 29mm festoon for the dome and regular 31mm for the cargo area.
  9. Jan 6, 2021 at 5:27 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    @kmeeg
    confirmed, the cargo bulbs 31mm fit just fine, they have longer metal brackets and there is a bit of play, however, i pinched my fingers again and the dog learned how to swear while i tried to fit the 31mm in the dome housing. You either have the correct bulb, or you really bent the heck out of the contacts.
    thats it, im getting the DD 29mm. hopefully they ship to canada.
  10. Jan 6, 2021 at 9:43 PM
    That's strange, I was able to fit them easily on my 2018 and 2019. Dome and cargo had the same size.
  11. Jan 6, 2021 at 10:33 PM
    davisi
    davisi New Member
    Too funny, I just struggled to install that exact auxito bulb in my 4runners dome light earlier today. I ended up blowing a fuse trying to install it using small pliers. Spent way to much time on it. In the end I found it was possible by without using pliers. I had to insert the auxito bulb sideways, inserting the passenger side tip first then the drivers side tip and then twist bulb so led's were pointing down. hope this makes sense. Problem with the auxito bulb is the points arent very defined, so its hard to get them into place. Good luck. unplug the battery so you don't blow the fuse like I did lol.
  12. Jan 7, 2021 at 5:16 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Well, officially they don’t fit:
    Hi,
    Thanks for your reply and sorry to hear that. After checking, we just have 31 mm DE3175 bulbs at the moment, so they may also not fit for your car. Really sorry. Hope your understanding.
    Sincerely apologize again.
    Regards,
    Jessica
    Hi,
    Thanks for your reply. Yes, you car take DE3175 or DE3022 bulbs for your dome light (ceiling).
    Since these bulbs (31 mm) a little longer and not fit your car. Could you please retrun these bulbs through Amazon and get a full refund?
    Waiting for your reply.
    Regards,
    Jessica
  13. Jan 7, 2021 at 6:08 AM
    This is what I use in my 11 and 18 4Runner
  14. Jan 7, 2021 at 6:52 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Diode Dynamics has 2 different sizes for these bulbs for '10-'20:
    29mm dome - https://www.diodedynamics.com/dome-light-led-for-2010-2020-toyota-4runner-one.html
    31mm trunck - https://www.diodedynamics.com/trunk-light-led-for-1996-2020-toyota-4runner-pair.html
    Bending the hell outta the connectors is a no go for me, my OCD kicks in for a job poorly done, not to mention it might damage the housing (mine popped up "inside")
    The Vleds are 30 mm, not 31mm and adding their thickness at the ends, 1mm probably is the diff between it works and it doesn't: https://www.vleds.com/shop-application/interior/3022-24-b.html
    All this study about vleds and DD makes me spend money...
  15. Jan 7, 2021 at 7:00 AM
    getwiser
    getwiser New Member
    PDX
    2021 TRD Off-Road
    wdsteven likes this.
  16. Jan 7, 2021 at 7:14 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    @getwiser
    that map light idea is pure sex
    you know you need to post a few pics, right?
  17. Jan 7, 2021 at 7:20 AM
    getwiser
    getwiser New Member
    PDX
    2021 TRD Off-Road
    For sure! Only complaints I’ve heard about the rear dome light “to bright”. Not worried about that.
  18. Jan 7, 2021 at 7:27 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    yea, and i have too much money
  19. Jan 9, 2021 at 5:27 PM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    The Precision LED bulbs will fit. I fought this fight a few times.
  20. Jan 9, 2021 at 5:42 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    i ordered the DD ones already. By reading about their products, they seem pretty pros.
  21. Jan 9, 2021 at 6:07 PM
    wdsteven
    wdsteven New Member
    getwiser likes this.
  22. Jan 9, 2021 at 6:10 PM
    Here's how my Yorkim 31mm looks.
  23. Jun 18, 2021 at 8:13 AM
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    I had trouble getting these to stay in as in this photo, so I gently tapped them a few times with a small hammer to blunt the ends to 2mm. Now at 29mm in length, they fit perfectly and don't fall out.
    21TOR likes this.
  24. Jun 18, 2021 at 8:31 AM
    Doubleduty
    3rd gen ltd and 5th gen SR5
    That dome light IS a PITA. Was, until I located my 10" forceps. Then it was a piece of cake.
    Got mine from Amazon. The brand is Autogine. Kit with tool was $25.00. They carry a 2 year warranty. So far, so good!
  25. Jun 20, 2021 at 2:22 PM
    Just letting you all know that these 31mm does not fit 2021s dome light.
    (They fit on my 2018 & 2019 as shown on above video and pic. But when I try today on my 2021 TRD Pro it does not fit)
  26. Jun 20, 2021 at 3:22 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    I stuffed the 31mm in our 2021 but was a challenge and was not sure how long till they would fall out, so far been there for six months.
  27. Jun 20, 2021 at 3:27 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    Good idea, another if it don't fit hit it with a hammer guy, like the way you think......if/when I have to change mine out ill take a hammer to the bulb.
  28. Jun 21, 2021 at 5:57 AM
    VentureTRD
    I wasn't kidding about tapping them lightly with a hammer to flatten 1mm off of each end, reduced the length from 31mm to 29mm. It blunts the ends enough so they fit perfectly into the hole and spring hole.
    There was no way this was going to fit in there out of the bag. The spring clip just won't compress enough to grab it and it will keep falling out. I had the same issue with my FJ Cruisers.
    kmeeg likes this.
  29. Jun 21, 2021 at 8:49 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Depending on how much metal or solder there is at each end, you can also file off a little to reduce the length. This way you don’t shock the internals too much with hammering.
  30. Jun 21, 2021 at 10:02 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    ...or you can just buy the proper size bulb :)
    Doubleduty likes this.
