No Longer Stock
Discussion in '5th Gen 4Runners (2010-2024)' started by Grifter, Apr 18, 2018.
  1. Apr 18, 2018 at 2:47 PM
    Grifter
    Grifter [OP] New Member
    2017 4Runner TRD Off Road
    Icon Stage6 - Method Wheels - KO2's
    I've had my 4runner for just over a year, so for her birthday I put on a Icon Suspension, some Method wheels, and new tires...pretty happy with how she looks.
    Had some rubbing issues with the tires and front mud flaps so I pulled them off, but Id like to put them back on. Im open to ideas so if you have any please let me know. 4runner.jpg
  2. Apr 19, 2018 at 6:47 AM
    StormTrooper 1
    StormTrooper 1 New Member
    Buster
    Trd off-road premium 2018
    Wheels, tires, fender flairs, custom hood wrap
    I had the same problem with rubbing. I actually cut out some of the plastic that was causing the issue.
    I’m guessing that after your tires wear down this will diminish.
  3. Apr 19, 2018 at 7:35 AM
    Kinglos
    Kinglos New Member
    2018 4runner SR5 Premium
    N-fab side steps* windows tinted* blacked out emblems *more to come?
    Looks good n i had some Minor trimming done to the front fenders so no rubbing now n i still kept my mud flaps on n no rubbin there...
  4. Apr 19, 2018 at 8:18 AM
    JosephMehta
    JosephMehta New Member
    Zombocalypse
    Shrockworks Front Bumper, CBI Rear Swing Away with dual Jerry Cans and full size spare, Full Shrockworks Armor, Warn 9.5 Synthetic, PIAA Lighting on roof rack and front bumper, Rear lighting wired to vehicle's reverse gear, Dobisons dual slide out rear bay storage with sliding top and refrigerator tie-downs, Limb Risers, Gobi Rack w/mounted Powertank, Fire Extinguisher, Jack, Axe, and Shovel, 33" Nitto Grapplers (295/70/17), Body Mount Chop, Icon Stage 7 Billet w/S2 Stage 3 Secondary adjustable front suspension, 3.5 inch Icon Stage 7 Billet with Billet Upper and Lower Links, Icon Bump Stop, 3.0 inch Icon Overland Rear Coils, ARB Front and Rear Air Locker with ARB Differential Breather (relocated to engine bay), ARB Twin Compressor mounted in engine bay, 360 degree, 4-camera system with DVR with monitor mounted on the dash, Dual Rear Headrest Monitors w/DVD and gaming capability Future mods in 2019: Magnusson Supercharger w/Catback system and possibly an roof mounted, solar heated shower and water storage
    You didn't write the size of the tire but they look like 275s; it also looks like you don't have a suspension lift. With 3 inch lift you will have no rubbing with 275s.
  5. Apr 19, 2018 at 8:20 AM
    Kinglos
    Kinglos New Member
    My bad buddy i got 285/70/17 with just a Leveling kit 2.5
    Grifter[OP] likes this.
  6. Apr 19, 2018 at 8:24 AM
    Kinglos
    Kinglos New Member
  7. Apr 19, 2018 at 8:27 AM
    JosephMehta
    Zombocalypse
    Doing a suspension lift (I wrote 3 inches because that's where I started with mine) will give you plenty of space with no rubbing, probably with the 285s, too. On mine, it looks like the front would accommodate 285s with no rubbing (285s are just .4 inch more in height) but the back tires are where you may need to worry a bit (when off road) and you potentially bottom out the rear well. Stops will help there; having heavy duty coils can help a bit, too.
  8. Apr 19, 2018 at 8:28 AM
    JosephMehta
    Zombocalypse
    ...almost forgot, I have the same brand tire (K02s).
  9. Apr 19, 2018 at 9:06 AM
    Kinglos
    Kinglos New Member
    Yeah i know i havent gone off roading yet but im sure it will bottom out but for now its more for the look til i do Decide to do a full lift on it.. good luck on yours n let me know how it comes out n what u did ...
  10. Apr 19, 2018 at 9:20 AM
    JosephMehta
    Zombocalypse
    Thanks. Dropping it off at the shop tomorrow, actually. New front end (Shrockworks) and new back end (CBI).
  11. Apr 21, 2018 at 4:05 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    2017 TRD OFF RD PREM
    oh the list....!
    PICS,PICS,PICS!!!! We Wanna See!!
  12. Apr 21, 2018 at 4:32 PM
    Grifter
    The tires I have on now are 285's. The front shocks are adjustable so I have to get it brought up another inch next week (i didnt have the right tools). That will make it a 3in lift so we'll see if that solve the problem.
  13. Apr 23, 2018 at 6:38 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    Yea but now you are getting into reverse rake. Anything over .85 and you will have reverse rake unless you raise the rear. This is why I would never run 285's, it is just not worth it. The weight you added lone is not worth it. Now you are going to max out the shocks also, not a good idea.
    I wish you the best fixing the rubbing. I would recommend doing it right and not just raising the front. Reverse rake looks so silly, be careful and gets advice on the forums.
    Grifter[QUOTED][OP] likes this.
  14. Apr 23, 2018 at 9:31 PM
    Grifter
    The rear end is raised, you can't really tell in the picture but my rear end is noticeably higher right now. I'm bringing my front end up to 3" to level it out a little bit. The front is adjustable up to 3.5" so I won't quiet be maxing out the shocks. I'm not really a fan of the reverse rake look either nor do I know what the point of it is. I'm pretty new to this so I'm learning as I go.
    Since I wasn't really specific in my first post this is what I did:
    Replaced rear shocks and coils, upper and lower trailing arms/links whatever you want to call them, rear track bar, front shocks, and UCA's. and then I put on 285/70R17's
  15. Apr 30, 2018 at 9:53 AM
    JosephMehta
    Zombocalypse
    Sorry for the late reply, I've been in Italy for the last 10 days and that, I figured, is a really good excuse for not replying. With respect to pictures on the truck, I will post some most likely next week. The truck is at the AV shop as I write, getting a four camera (360 degree) system with monitor installed. As well, I'm having them put in headrest monitors and the CB. After the work (in the next two days), it goes back to the 4x4 shop (High Country 4x4 in Colorado) for the final touches, which are simply finishing up the PIAA lights wiring. From what they've told me, all other bits of work are complete: Shrockworks front bumper, with winch, and two PIAA light; CBI rear bumper (swing away); 1.25 inch wheel spacers; and some other goodies.
  16. May 1, 2018 at 3:23 PM
    JosephMehta
    Zombocalypse
    Update on my build: the A/V shop just finished the install of the 4 camera, 360-degree-view system w/dash mounted monitor; and the install of the headrest monitors (for the kiddos). They've delivered the truck back to High Country 4x4 so the 4x4 shop can finish the build (4 PIAA round lights at the front of the GOBI rack), and some minor detailing. I am supposed to have it back Thursday (today is Tuesday). When I have it, I will post the pics of the build which includes:
    1) ARB Snorkel
    2) ARB Rear Locker
    3) ARB Rear Differential Breather re-locate
    4) ARB Twin Compressor mounted in engine bay
    5) Shrockworks front bumper
    6) Warn 9.5 Winch w/synthetic line
    7) Two PIAA Lights on the bumper
    8) CBI Rear Swing Away w/full size spare and two gas cans
    9) Rigid lights in rear bumper
    10) GOBI Rack w/4 PIAA lights mounted at the front
    11) 3" Toytec Boss Coilover lift w/Heavy Duty Superflex rear coils
    12) Dobinson two drawer storage (that's one heavy box!)
    13) Rago rear windows (left and right) Molle panels
    14) 275/70/17 BFG K02s
    15) Custom mounted CO2
    16) Mounted fire extinguisher
    17) 4 camera/360 degree viewing system w/separate dash mounted monitor
    18) Dual headrest monitors
    19) 1.25" Spidertrax wheel spacers
    20) and...an oil change
    Already thinking of future additions:
    1) Magnusson supercharger
    2) 6" Fabtech lift
    3) 35x12.50 tires w/the lift
  17. May 11, 2018 at 7:53 PM
    TN_TRAIL
    TN_TRAIL New Member
    Noel
    oh the list....!
    WOW!! wish I had your disposable $$ ! pics, please. What kind of cameras? What type of Shrockworks bumper did you go for? I went with the single hoop. Like I said. PICS!! congrats!
  18. May 12, 2018 at 7:03 AM
    JosephMehta
    Zombocalypse
    See pics.
    Grumpy Uncle likes this.
  19. May 12, 2018 at 7:08 AM
    JosephMehta
    Zombocalypse
    Another
  20. May 12, 2018 at 7:12 AM
    JosephMehta
    Zombocalypse
    Zoom in in the frontal pics. You can see the back of the mounted monitor for the 360 degree, 4 camera system.
  21. May 12, 2018 at 9:46 AM
    Grumpy Uncle
    Grumpy Uncle New Member
    Pat
    2018 Limited MGM, hers. 2016 Tundra CM BLK, mine
    Grey TRD Wheels, Nitto Terra Grapplers, 3"Toytec Eibach
    Looking good!
