Needed: Rear End for an '02
Discussion in 'Marketplace - Other' started by WWI Flying Ace, Nov 14, 2015.
  1. Nov 14, 2015 at 12:06 PM
    WWI Flying Ace
    WWI Flying Ace [OP] New Member
    02 LTD
    Hi, I need help locating a rear end for my rig. I've exhausted my internet search capability with no luck.
    2002
    4x4
    6 cyl
    16" wheel
    ABS
    4-10 ratio
    Thanks, Brad
  2. Nov 15, 2015 at 7:00 AM
    ramonortiz55
    ramonortiz55 New Member
    Ramon
    you mean a rear axle? by rear end on the thread title i understood as rear bumper
  3. Nov 15, 2015 at 7:27 AM
    WWI Flying Ace
    02 LTD
    Thanks for responding Ramon. The rear dif housing is leaking with no way to repair so I do need the whole rear axle, dif, housing etc. I actually may, late yesterday, have found a place to buy one but will take any advice. Thanks, Brad
  4. Nov 15, 2015 at 7:40 AM
    ramonortiz55
    Ramon
    Is it a 4x4?
  5. Nov 15, 2015 at 7:59 AM
    WWI Flying Ace
    02 LTD
    Yes. Forgot to put that in the description! Just added it. Thanks
  6. Nov 15, 2015 at 8:14 AM
    ramonortiz55
    Ramon
    Make sure the differential ratios are the same
  7. Nov 15, 2015 at 9:11 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    Where is it leaking? I assume the diff cover is rusting through, which is common. Barnes4wd makes a diff cover that welds in place after the old cover is cut off. Lots of people have used JB Weld to patch rust pinholes. How much does this place you found want for the axle?
