Need Help with LED Fang Lights
Discussion in 'Lighting' started by Joesav19, Dec 30, 2022.
  1. Dec 30, 2022 at 1:16 PM
    Joesav19
    Joesav19 [OP] New Member
    Joe
    2021 Lunar Rock TRD Pro 4Runner
    I was gifted the non Aiden James fang lights from 4runnerlifestyle. They don’t come with instructions and I can’t seem to find a video for installation either. I installed myself and the blinker aspect works but the regular LED lights don’t turn on at startup or when DRL are on. Am I missing something? Does anyone have experience installing these? I searched the sub but can’t find anything. Thanks for any help.
    Bluejay likes this.
  2. Jan 12, 2023 at 3:47 PM
    tennisace
    tennisace New Member
    I got those as well for X-mas! And have exact same issue. Only thing I could find is on their website at the bottom of the description area. Says..
    Red- Run this to positive (Run to the INJ fuse position to get it to turn on when the car turns on)
    White- Back up positive wire (We do not recommend this but you can choose to run this one and it will keep the lights on all the time)
    Black- Run to ground
    Yellow- Runs to the turn signal to allow it to change when the turn signal is on.
    Nothing about how to take off front end or grill, etc. I've removed my front end previously to install light bar, so I'm pretty sure I'll be able to figure it out.
    There is this from some guy in the review section..."I had to search for a while on a wiring diagram". (wish he had included the link). I can't find anything.
    I reached out to 4RLifestyle and their response was..."We do not yet have a video for those!" Nice.
    Good luck.
    djwantke likes this.
  3. Jan 12, 2023 at 3:56 PM
    Joesav19
    Joe
    I finally figured it out! The add-a-fuse needed a second fuse inserted. Let me know if you need any help.
  4. Jan 12, 2023 at 5:04 PM
    HazOpRed
    HazOpRed 22' TRDOR
    The ones in my profile pic?
  5. Jan 12, 2023 at 10:25 PM
    Bluejay
    Bluejay New Member
    I've been struggling with mine as well! They turn on but I am unsure as to how or what I am supposed to tie the yellow wires into? Do I need to tap into the yellow wire on my turn signal so they turn on when my blinker goes on? I've searched and found the same articles you have but I am still struggling to get this last part connected!
  6. Jan 13, 2023 at 3:01 AM
    Joesav19
    Joe
    Yes! Tie them into your blinkers. Tie into your yellow blinker wire on the driver side and the light blue blinker wire on the passenger side.
    djwantke and Bluejay like this.
  7. Jan 13, 2023 at 3:51 AM
    Bluejay
    Bluejay New Member
    Perfect I'll do this today thank you so much!
  8. Dec 16, 2023 at 2:53 PM
    4RunnerRiss
    4RunnerRiss New Member
    White 2020 4Runner SR5
    Installed these yesterday but having some issues with my fog lights now! I have raptor lights and t-tapped my fang lights into those in the INJ slot, both are working but now my fog lights aren't. Even when I unplug the fang lights, fogs still do not work. I checked the fuses, all are good. Any ideas? I didn't think the INJ fuse slot had anything to do with the fogs, since they fogs have a separate fuse slot in the cabin.
  9. Jan 17, 2024 at 9:28 PM
    WhiteRhino4R
    WhiteRhino4R New Member
    White4Runner
    Yea, I have the issue of the left blinkers activating the right fang lights and the right blinker is activating the left fang lights.
    Any one have any advice on this?
  10. Mar 16, 2024 at 7:50 PM
    Missbang
    Missbang New Member
    Lacey
    2022 4Runner SR5
    Fang Lights, Rear Ladder (widdle wadder), Custom Rood Rails, Interior Curtain, Interior Color Changing Lights
    Having the same problem - the fangs light up but are not sequencing with the turn signal. 4Runner Lifestyle hasn’t responded to my inquiry. Wondering if anyone has tried upping the amperage? Or putting the blue wires together and the yellow wires together versus the opposite? Would love to have advice before I tear my grille apart again
  11. Mar 17, 2024 at 1:59 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey all
    So I've successfully installed sequential fangs from 4RunnerLifestyle. No manual really included, like many aftermarket parts it's limited info, and Google and YouTube are the manual lol :mad:
    1. @WhiteRhino4R I didn't have the issue regarding opposite side blinking, that's odd - because I'm assuming you tied each fang into the colored wires on each side so how are they operating opposite I wonder
    2. @Missbang upping the amperage? I didn't do that I don't think
    Or putting the blue wires together and the yellow wires together versus the opposite? Also, didn't do that and both may or may not be a bad idea. I believe I heard LED's can draw as much current as you afford them, which can blow em.
    I went off of these instructions, and here's photographs of some fog wiring and engine bay grounding.
  12. Mar 17, 2024 at 3:56 PM
    jmofunk
    jmofunk New Member
    2015 TRD Pro Inferno
    Hello all- I'm installing fang lights today as well and have run into a different issue. I recently installed Alpharex Luxx headlights, and have that fuse tap in the INJ spot. Does anyone have a suggestion for a secondary fuse location for the fang lights (since I already have a fuse tap in the INJ location)?
  13. Mar 17, 2024 at 3:58 PM
    wingo
    wingo *****
    2020 Venture
    I connected the white wire to my puddle light. It (fang white lights) comes on when I approach the vehicle and when I unlock the doors. Connected the red wire (with inline fuse) to the ignition so when I start the vehicle, it comes on and acts like the DRL lights (do not connect directly to DRL system, light will stay on). Yellow wire to each of the turn signal lights (left and right). Black wire to the ground (not the battery on something metal).
  14. Mar 17, 2024 at 6:35 PM
    jmofunk likes this.
  15. Mar 18, 2024 at 12:44 PM
    jmofunk
    jmofunk New Member
    @djwantke So you tapped into the cabin fuse box, rather than the engine, for the fangs?
  16. Mar 18, 2024 at 12:54 PM
    So yes, I tapped into the cabin box because originally when tapping into engine bay fusebox INJ it tripped my ECU and for whatever reason the truck din like it.
    But that was one of my first "automotive electrical" mods, so now after becoming much more educated and experienced, I believe I made a mistake(s) when drawing from engine bay fuse. There is multiple fuse slots there that should be fine.
    As for your 2015, and my 2016, the lid cover/fuse slot layout may be different from this photo. I couldn't open my hood last night quickly to snap a photo
    T in Texas and jmofunk[QUOTED] like this.
  17. Mar 18, 2024 at 12:58 PM
    Try INJ or INJ No. 3 (I probably messed up on the fuse and add-a-fuse orientation)@jmofunk
  18. Mar 18, 2024 at 1:04 PM
    I just found this yesterday during a deep 4R. com website Search. Where has this been my whole life lol
    T in Texas likes this.
  19. May 18, 2024 at 9:06 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
