Need help getting 96 going again
Discussion in '3rd Gen 4Runners (1996-2002)' started by jasonbays, Feb 16, 2019.
  1. Feb 16, 2019 at 5:12 PM
    jasonbays
    jasonbays [OP] New Member
    jason
    96 3rd gen 4r
    First post and in desperate need of help. 4runner broke down a few weeks ago and has been setting and ive been driving my wofes ride. Well my luck struck again and her motor went out.
    The 4runner started fine after work one day and i was coasting down parking garage and it died. Tried starting up and just cranked and cranked. Changed fuel filter and pump and got it to fire up when pumping/holding gas but wont idle and runs very rough and backfires/gush of air through intake. Buddy said he thought it was out of time so i replaced the timing belt....same thing. Heard a continuous clicking noise and tracked it down to the iac valve and replaced that. Still nothing. Has cel but now obd2 reader says communication error. Please help i need to get it goingto get to work monday
  2. Feb 16, 2019 at 10:35 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Get that obd2 reader to give you codes hard to tell without that. Sounds like timing to me as well though. Check to make sure your getting air, fuel, and spark if you have all of those then it’s either compression or timing that’s the issue.
