Need help - 2nd Gen Morimoto Fuses on 2022 ORP
Discussion in 'Lighting' started by mattb, Dec 9, 2021.
  1. Dec 9, 2021 at 2:15 PM
    mattb
    mattb [OP] New Member
    Hi all,
    Picked up my new 2022 Off Road Premium a few weeks ago, and installed my 2nd Gen Morimoto Amber DRL LED headlights yesterday. They look great, and perform well.
    However - when I activate high beams, nothing happens. I hear a "click", but the intensity doesn't change.
    - I've checked all my cables and confirmed connections are seated properly
    - I tried two different fuse locations; the EFI #2 slot (per Morimoto instructions) and the empty 10A slot used in 2014-2019 4Runners
    Any recommendations or ideas for me to problem solve? Anyone else with a 2020+ 4Runner run into the same issue?
    Thanks for the help.
  2. Dec 11, 2021 at 9:42 PM
    floresjuarez
    floresjuarez New Member
    This is happening to me too. Lmk if you hear anything or update
  3. Dec 11, 2021 at 9:59 PM
    jr3volution
    jr3volution New Member
    Johnnnie
    2022 4Runner SR5 Premium
    I’m also wanting to figure this out. Just installed it in the wife’s 22 and the high beams are the only issue
  4. Dec 11, 2021 at 10:14 PM
    floresjuarez
    are you having problems when you switch them into DRL mode only? Bc only the passenger side is turning on until I switch it to the clearance lights. Which is odd. I have them on the EFI 2 slot in the fuse box designated for the 22 model.
  5. Dec 11, 2021 at 11:29 PM
    jr3volution
    Johnnnie
    Everything on the lights are functioning well other than the high beams and having to adjust the projection pattern
    For the DRL fuse tap, I have it In the 10amp injection slot.
  6. Dec 11, 2021 at 11:52 PM
    floresjuarez
    Oh you didn’t try the EFI 2 slot? That’s what was recommended on the instructions so I figured I had to use only that one.
  7. Dec 11, 2021 at 11:57 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    I remember when I bought mine for my ‘19 it said something about 2021+ models needing some special adapter..did you guys get that? Not sure if that’s the cause of your high beam issue or not.
    jr3volution likes this.
  8. Dec 11, 2021 at 11:59 PM
    floresjuarez
    yeah, I used the adapters that it came with but no difference.
  9. Dec 12, 2021 at 7:15 AM
    jr3volution
    Johnnnie
    I follow Headlight revolutions instructions.
  10. Dec 12, 2021 at 7:21 AM
    jr3volution
    Johnnnie
    I see where you got the efi recommendation from
  11. Dec 15, 2021 at 4:30 PM
    Exmod
    Exmod New Member
    2022 White 4Runner TRD ORP
    Any resolution to this? I’ve installed the Morimoto Second Gen headlights on my 2022 TRD ORP and I also do not have high beams or DRL. I tried checking all connections as well as unhooking the negative battery connection for 4 hours.
  12. Dec 15, 2021 at 4:36 PM
    Exmod
    Exmod New Member
    Actually qick detail update on my end. Just moved to the EFI 2 slot and it appears the headlight DLRs are only working on my passenger side.
    Also when I turn on my lights it looks like very briefly my passenger high beams come on.
  13. Dec 15, 2021 at 4:41 PM
    jr3volution
    Johnnnie
    I too moved the fuse to efi2 and it didn’t resolve my issues
  14. Dec 15, 2021 at 4:46 PM
    floresjuarez
    Hey guys, so got in contact with morimoto. They stated that all three bulbs turn on as that is the new feature of that headlight model. If you switch to high beams it won’t necessarily change much & you’d only notice it if you test it out in front of your garage door.
    also, @Exmod i have the same exact issues & model of truck & they said I had the wrong adapters sent. They were nice enough to ship me the adapters for the trd pro & limited models instead. So As soon as I get them I’m gonna switch them out & see if that fixes it & let ya know
  15. Dec 15, 2021 at 5:12 PM
    Exmod
    Exmod New Member
    Thanks for the response @floresjuarez.
    I was testing the headlights up against a wall. I see them pop to what I think is high beams for a split second whenever I turn on the lights.
    I’m curious what adapter is wrong for you. Is it a situation where the plugs don’t fit or do they hook in correctly and just don’t work? All of mine hooked in well and it came with the adapter for the 2022 plug that doesn’t line up. How could you tell you had the wrong adapter?
    I’m also seeing only one light show DRL now that I’m in the EFI2 fuse. Did you see anything similar?
    I purchased my light through 4runnerLifestyle.
    I really appreciate you following up and I look forward to hearing if you can resolve the issue.
  16. Dec 15, 2021 at 5:47 PM
    floresjuarez
    Yeah purchased mine thru 4runner lifestyle too. i got in contact with the morimoto directly, explained & showed videos of what was going on. I had sent them pics of the adapter I received & they were like “yeah I think you got the wrong ones”. But everything was plugged & connected well. So we’ll see if this switch up helps & np.
    also yeah, when I’m in the efi2 slot, only the passenger side turns on when I’m switched to DRL & then both turn on when I switch to clearance lights which is weird.
    Exmod[QUOTED] likes this.
  17. Dec 15, 2021 at 5:59 PM
    jr3volution
    Johnnnie
    I too purchased from 4runnerlifestyle.
    do you mind sharing a picture of your adaptor?
  18. Dec 15, 2021 at 6:20 PM
    Exmod
    Exmod New Member
    Oh wow, thank you @floresjuarez. It’s comforting to know we have the same exact symptoms. I’m diving into this without any experience so I was worried I messed up :)
    I’ll contact Morimoto as well and potentially reference this thread.
  19. Dec 15, 2021 at 9:22 PM
    floresjuarez
    FA62F1A2-8DA7-45E7-B151-9F38AA78A728.jpg 20890C6A-45A5-416B-8F44-D38453EDD5EC.jpg
  20. Dec 15, 2021 at 9:30 PM
    Slimwood Shady
    Slimwood Shady New Member
    Linwood
    San Antonio, TX
    ‘22 T4R Pro Lime Rush, 996TT
    I had this exact issue on my ‘22 Pro (high beams were always on). I know with the pro there is a different harness, bit my problem was that the harnesses were left and right side. I swapped them and was good to go. My right side (passenger) harness only had one wire for the high beam connector. I wonder if yours is the same….88A2CDD3-D39C-4188-8E11-5855F6A298D8.jpg
  21. Dec 15, 2021 at 9:35 PM
    floresjuarez
    yeah I switched mine around but it didn’t help. The morimoto guy did say the adapters for the pro version are side specific so yeah makes sense
  22. Dec 15, 2021 at 9:50 PM
    T-Runner
    T-Runner New Member
    Honolulu, Hawaii
    22 Army Green TRD Sport
    Not sure if my fix will be your fix. I purchased mines thru theretrofitsource.com with Limited/TRD Pro adapters. I had an issue with the DRL staying on in the off position and startup sequence coming on randomly after arming. My fix was running the setup without the DRL tap harness and works perfectly fine and normal is it should.
  23. Dec 15, 2021 at 11:02 PM
    Exmod
    Exmod New Member
    I read this and immediately ran out to my garage, yanked out the adapters and swapped their sides. Nothing changed but I was excited for a second there :)
  24. Dec 16, 2021 at 4:05 PM
    Slimwood Shady
    Linwood
    San Antonio, TX
    :rofl:
  25. Dec 17, 2021 at 11:32 PM
    floresjuarez
    Yo, so I finally got the new adapter that is specific for the trd pro / limited models & it works great. The high beams and the DRLs. I guess it was just a matter of switching the adapter
    hope this helps
    Slimwood Shady and Exmod like this.
  26. Dec 18, 2021 at 6:58 AM
    Exmod
    Exmod New Member
    Thanks for following up. That’s great news! Did you call Morimoto or email? I’m going to get on this.
  27. Dec 18, 2021 at 8:25 AM
    floresjuarez
    i did both! Call during the week for faster response
  28. Dec 19, 2021 at 12:59 PM
    mattb
    Hey everybody. Got this resolved. After working with my dealer and Morimoto, it appears that all models for 2022 need the TRD Pro/Limited lighting harness. As soon as I installed those, headlights functioned as expected. Low beam, high beam, and DRL, all operating as they should. Don’t forget to move the fuse to EFI 2.
    Slimwood Shady, jr3volution and Exmod like this.
  29. Dec 22, 2021 at 5:16 PM
    floresjuarez
    Ay, so is anyone having trouble with the DRLs turning on randomly for like 30 sec or so?
    i have the add a fuse on the EFI 2 slot. But I just find it odd it’s turning on randomly. The truck is also off so idk why it would turn on.
    Probably happens every 10 min or so.
  30. Dec 22, 2021 at 5:26 PM
    Slimwood Shady
    Linwood
    San Antonio, TX
    I remember reading the efi2 fuse gets power randomly, that is why why I tapped a fuse in the cab. I couldn’t find one that was a true acc power.
    floresjuarez[QUOTED] likes this.
