Need advice on replacing passenger door
Discussion in '4th Gen 4Runners (2003-2009)' started by thunder92, Dec 16, 2015.
  1. Dec 16, 2015 at 8:26 AM
    thunder92
    thunder92 [OP] New Member
    Jack
    2006 4runner/Limited/V8
    Ok, my wife bent the REAR DRIVER door backwards while exiting the garage. The entire door needs replacing. I've already found one off the same color I just need to install it. I'm sure I can stumble my way through most of it but i'd love real advise from someone who has actually done it. The used door I got came with the hinges still on.
    by the way we just got this truck 6months ago and love it! Think I want one too!
    Thanks for any help!
  2. Dec 17, 2015 at 6:58 AM
    thunder92
    Jack
    alrighty. Guess I'm alone on this.
  3. Dec 17, 2015 at 12:55 PM
    thunder92
    Jack
    I'm sure you'll be able to do it man! Just take your time. Good luck.
    Bob likes this.
  4. Dec 17, 2015 at 12:55 PM
    thunder92
    Jack
    Thanks for the message thunder I'll sure try.
    Bob likes this.
  5. Dec 17, 2015 at 3:08 PM
    Bob
    Bob Member Staff Member
    Bob
    :rofl:
    It's possible no one here has had to do this before so they have nothing of value to contribute. If you could follow up with how it went (and any pitfalls) that would be helpful for the next guy!
  6. Dec 17, 2015 at 4:43 PM
    drunner
    drunner New Member
    Danny
    Anaheim
    07 SR5
    5100s, 885s, Toytec 2" rear, Camburg UCAs, 255/75/17 Duratracs
    I don't have much to contribute other than Good Luck! If I had to guess, there's going to be connectors for the wiring but whether they're inside the door itself or under the dash is anyone's guess. Shouldn't be too hard though. Disconnect the wiring, remove the door, put new door on, connect wiring, line it up, tighten it down.
  7. Dec 17, 2015 at 4:54 PM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    There is not much to it. I imagine you can find wiring plugs (power windows and locks) behind the plastic pillar trim. A ratcheting box-end wrench would make quick work of the hinge bolts in the tight area of the door jamb. Fish the wiring out first and then unbolt the door with an extra set of hands to help out.
  8. Dec 17, 2015 at 7:05 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    as others have said, take your time and check gaps, it should be pretty easy to bolt in and go and have it look right, but sometimes parts aren't totally perfect and may need some adjustment
  9. Dec 18, 2015 at 5:31 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    If the hinges didn't get tweaked, I would unbolt the door from the hinges, not the hinges from the jamb. The replacement door should line right up. This is how I swap my full doors and tube doors on my 1st gen, just unbolt them from the hinges.
  10. Dec 18, 2015 at 6:44 AM
    thunder92
    Jack
    Awesome thanks guys. Ya the hinges did get bent unfortunately. Thanks for the advise will be trying tomorrow.
  11. Dec 18, 2015 at 7:04 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Please take pictures....some of us have wives too!!!:anonymous:
    drunner and ajohnson like this.
  12. Dec 18, 2015 at 8:01 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    Oh well no biggie. Mark the locations of the hinges before you pull them, this may help line up the replacement.
    ThatFenwickGuyFromTW likes this.
  13. Dec 31, 2015 at 7:23 AM
    thunder92
    Jack
    Way easier than expect guys. The hard thing for me was removing the outer door molding since it was one year off and didn't match(was to small). New clips just arrived for that. Also swapped out the inner door panel which was simple. Basically if the door is closing to low then loosen the bolts a bit and move up. Then tighten. Easy. Probably why there is nothing on it. Simple. 4 bolts and a plug which is in the chassis not the door.
  14. Dec 31, 2015 at 7:29 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    I knew you could do it :cheers:
  15. Dec 31, 2015 at 10:34 AM
    ThatFenwickGuyFromTW Hillbilly
    Fenwick
    Chesapeake, VA
    2 2nd Gen T4R's, 96 Tacoma 5 Lug
    Work in progress!
    I have two second gens, but no 4th gen, so there wasn't much for me to contribute.
    But I found your conversation with yourself very entertaining. :laugh:
