My quest to find the rattle/chatter.....
Discussion in '3rd Gen 4Runners (1996-2002)' started by Ol'Blue, Jun 7, 2014.
  1. Jun 7, 2014 at 1:26 PM
    Ol'Blue
    Ol'Blue [OP] New Member
    "Not all who wander are lost"
    Alright,
    As much as it pains me to do this I'm out of things to think of at this point. As the title says I'm still hunting down the chatter sound in my truck. It is random but if I hit a bump it will come and go and you can definitely hear it even in the cab at 60mph. There is no speed it comes on at or when you turn left to right. All the pulleys, belts, timing components are new to include the water pump and the fan bracket pulley. The only thing on the front of the engine that has not been changed out is the fan and the fan clutch.
    This last Thursday I had it on a lift and took the front wheels off thinking that maybe the pin that hold the CV axle nut/ nuts had come off and it was rattleing around in there. Nope all is good and snug as a bug. It is defiantly in the front half of the truck and that is clear as day. I have to be at speed going down the road for it to come out also. I tried just rev. the engine and nothing ever came up. I wish I had an all wheel drive dyno to put it on and run it at 70 MPH so I can find this SOB.
    I found a few things loos and fixed all that this last go around and still no luck. I thought it might be my transfer case low on fluid, Nope all good ( Although I did find out that I need a front and rear seal for it, I now have the OE seals in hand)
    The only other thing that I have found loose is simple. The hood latch has a broken bolt on the left hole. I need to tap and dye that thing out. Any one what size I will need for that one? Any help at this point wold be welcomed.
    PS- I have also checked for rocks in the skid plates. All good on that one too.
    Blue
  2. Jun 13, 2014 at 6:30 PM
    Bob
    Bob Member Staff Member
    Bob
    Any updates Blue?
  3. Jun 13, 2014 at 7:37 PM
    Ol'Blue
    No,
    I'm still looking. It sucks because I'm just out of ideas. I'm at the point I'm going to pull the CV's and look at them next. After that I'm going to go after the Trans. I hate to even think that but it is just not going away.
    Blue
  4. Jun 16, 2014 at 12:24 AM
    FlipStyle54
    FlipStyle54 New Member
    Delaware
    Exhaust heat shields? One of my bolts rusted off and it would vibrate on bumps at speed.
  5. Jun 17, 2014 at 5:44 AM
    Kryptoroxx
    Kryptoroxx New Member
    98 3rz 4x4 5spd
    99 coils, monstaliner, headers, exhaust, intake, CB, inverter, auto mirror
    Now that's a pretty good idea. I know I have an exhaust rattle every once and a while on a big bump but I did my own exhaust so it probably has more flex than the stocker. Exhaust noise could radiate up to the front and seem like it's coming from there too. Also could be right below the exhaust manifold.
  6. Jun 18, 2014 at 7:03 AM
    Ol'Blue
    Nope checked that too. I changed out the stock to a Flowmaster Supper 44.
    Blue
  7. Jun 20, 2014 at 5:40 AM
    rayray767
    rayray767 New Member
    Ray
    2000 4Runner limited
    3" lift
    Heat shield back behind the engine
  8. Jun 20, 2014 at 1:43 PM
    Ol'Blue
    Interesting. Tell me more or even picture would help.
    Blue
  9. Jun 20, 2014 at 7:19 PM
    rayray767
    Ray
    3" lift
    I really can't get no picture because it's behind the motor but if you look back behind that motor against the firewall you will see it. Sometimes one of the corners bolts rust off and that will cause a rattle at a high rpm range.
  10. Jun 22, 2014 at 7:35 PM
    Ol'Blue
    Ok, I'll look into this..
  11. Feb 21, 2015 at 7:22 AM
    Ol'Blue
    Update...
    After I did a anglinment. The adjustment nuts were loose on the control arms. Since I have not heard the rattle. We will see what happens I still need to replace one more because it just is not working as it should.
    Blue
