My idea to run 255/75-17... More 6112/5160 on a Pro talk.. Long winded :)
Discussion in '5th Gen 4Runners (2010-2024)' started by SendInTheCavalry, Jul 17, 2021.
  1. Jul 17, 2021 at 7:46 AM
    SendInTheCavalry
    SendInTheCavalry [OP] New Member
    M
    Ohio
    Trd Pro
    After about a year of research and looking at many options and talking to MANY guys around here and also major retailers. I think what's best for me and my driving style is a set of Bilstein 6112 with 600lbs spring, and 5160 with the Eibach +1" rear spring.
    I was leaning heavily towards BP51s or a 2.5" Radflow setup. I think suspension is a deep rabbit hole it is is very easy to trapped. especially with all the super sweet rigs on Insta and YT!
    My truck, 2018 Pro, mostly stock, rock sliders and (soon)gobi rack, its a family hauler and vacation mobile. I go down a lot of fire service type roads to get to hiking trailheads or primitive car camping sites. Maybe twice a year I try to get to a off road trail system. Usually Unmaintained County Roads in my state. They are everything from gravel to full on King of the hammers... lol. Seriously there are many that I am just not comfortable with mostly because of deep off camber ruts and 2-4' rock faces. Like I mentioned it is also the vacation machine. Mostly to Nothern OBX (Corolla, NC). 650 mile highway drive then airing down to 18-20psi and 2-4 mile beach drive each day for multiple days.
    One thing I want to address by replacing the suspension is better load handling; remove the squat when loaded. I sometimes use a hitch mounted cargo carrier(should end once the Gobi arrives) When there is 100lbs that far back from the rear axle it really squats. Not to mention the cargo inside, passengers, and dog. That is why I choose the Eibach +1" spring. that should help maintain a slight forward rake, hopefully slightly less than OEM and from what I understand they are a slightly heavier spring than stock.
    I use a set of AirLift helpers currently. I love them and they work great! I take a fender to ground measurement, inflate them to max psi (35), that usually gains me 1"-1.3". I load up the truck and then bleed air out to get back to the height when I was empty. I will still use the bags in the next set up for just in case. I am hoping to not have to inflate them as much. It might make for a more plush ride.
    The other thing I wanted is increased ride hight and clearance for a slightly taller tire. I have chosen to go 255/75. Its mainly a stock truck, and the 1/2" gain over stock and Load Range C will be nice. Ive compare to 285 because "that's what everyone does". Have you looked at the weights of some 285s? A Wildpeak 285 Load C is over 60lbs! yikes. Not only would that drastically rob power and decrease MPG, it would be a huge hassle to wrestle with it to change a flat. It also wouldn't fit easily in the spare location. Remember this is also a DD for me, Wife also often drives to run errands.
    The K02 255/75 is 32.1" diameter, 10"w Load C at 46lbs. That is only 6lbs more than the factory Nittos.
    There are less variables on the front. Ill use 6112 with 600lbs spring. I am on the fence wether to go with the 2" or 2.5" setting. My logic is, if the Pro is already +1" from OEM, a setting of 2" would net me no lift? As long as the 6112 2.5" setting is truly 2.5" I think that would be great. That will get me a gain of 1/2" more than I am right now(stock Pro). It is important to me that I am able to use the factory UCAs.
    Someday I plan to mount an on board ARB single. and maybe some other things. At that point ill reevaluate, maybe go up to the 650lbs spring?
    Wrapping it up, I decided to go this route because of budget. Not that I had a tight budget, is just a matter of dollars and sense... :) There is now doubt that the higher end stuff is AWESOME! For me the fact that it is easily double the price of the 6112/5160 and it would need constant (albeit easy) maintenance and off the truck rebuilds is what turned me off.
    Also the road salt they spray in the winter time pretty much ruins everything. I fear that even when it came time for a rebuild the bodies and exposed shafts would probably not me salvageable.
    With the 6112/5160 I can just toss them, Ill probably be able to reuse the springs.
    Anyhow, thanks for sticking with the long read..lol. its been a long journey...
    What are your thoughts?
  2. Jul 17, 2021 at 8:12 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    My '18 SR5P has 5100's, Toytec/Eibach 1.6" front coils and Eibach 1" rear coils. It could use some air bags for our loaded travels, but is has reduced brake dive and some highway sway. I was running P-255/75 DuraTrac's, but have decided to keep those as winter tires. They are awesome in the snow, but they are definitely on the loud side. About a month ago I put on some 255/75 KO2's in C load and I am impressed. Much quieter than the DT's, with less of a MPG hit (weird, but the numbers don't lie) and more importantly, the truck is much more solid on the road with a lot less wandering and steering vagueness compared to a P-metric.
    SendInTheCavalry[OP] likes this.
  3. Jul 17, 2021 at 8:27 AM
    SendInTheCavalry
    M
    Ohio
    Trd Pro
    awesome! Sounds like my exact setup! Any photos? Are you on factory UCAs? How’s the steering feel if you are?
  4. Jul 17, 2021 at 9:59 AM
    Mtbpsych
    Mtbpsych New Member
    Sounds like you got it all squared away! Just some advice though, you probably won’t need UCA’s but it’ll all depend how good of an alignment tech you get and also anything more than 2” will be a hit or miss. The pro is 1” higher upfront than a non pro only because of the suspension. Since you’re switching out the pro suspension, 2” of lift will be 2”. The pro doesn’t have anything that automatically makes it sit higher than other 4runners other than suspension. A 600lb spring should be plenty for all your needs, unless you plan on adding armor such as bumpers, skids, or sliders. It looks like you load up your rig, and add that rear cargo tray. I’d maybe consider a stronger rear spring as the one you mentioned might not be strong enough and you’ll end up nose high. Just my thoughts but I’m not sure how much weight it is you’re hauling.
  5. Jul 17, 2021 at 10:08 AM
    That setup sounds quite practical and not terribly expensive to begin with. Possibly in the future you may decide on a more aggressive suspension but for your needs it sounds good.
  6. Jul 17, 2021 at 10:09 AM
    Deuxdiesel
    SE MI
    '18 SR5P
    Thanks to Firestone, who flattened one of my alignment cam tabs, I am stuck at around 2 degrees caster. I just had it welded for reinforcement, and my next step is to install the JBA high caster UCA's that are sitting in my garage. I am hoping to get 4 degrees without much difficulty, but mine has been one of "those" 4Runners that run on the low side. Steering feel is fine as is, but a little better tracking would be nice. BTW, I am just outside of Ann Arbor, so unless you are a hardcore Buckeye fan, you can come up to check it out ;)
  7. Jul 17, 2021 at 10:32 AM
    Deuxdiesel
    SE MI
    '18 SR5P
    Pavo likes this.
  8. Jul 17, 2021 at 11:22 AM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    255's are such a good choice! I love mine. Next tire will be 35x10.50's. Skinnies are the way to go
    Trail Runnah and YetiMtnBkr like this.
  9. Jul 17, 2021 at 12:08 PM
    SendInTheCavalry
    M
    Ohio
    Trd Pro
    Yea, It just gets confusing when looking at Suspension Lift Kit heights, I have to remember to subtract 1" because I am already +1. Ive seen people talk about using the 14" spring for FJs. I wonder if there is a combination of taller spring plus clip setting to get like 2.0-2.4" lift? Ive also hear of people using Wheelers Off Road springs and getting slightly more than advertised. So maybe a Wheelers spring set to 2" clip setting would be more like 2.1-2.3?
    Thats a bummer about Firestone. I am starting to worry about my cam bolts being seized. Ive thought about spraying them with penetrating oil. I might have to look you up. my Outlaws live in Dexter.. pre covid we came up a few times a year... ;)
    Ive also been wondering if the OEM rear Bilstiens could handle the +1" Eibach. I am at 35000k I am willing to bet my Billys are still good. would save me a few bucks...
  10. Jul 17, 2021 at 2:00 PM
    Deuxdiesel
    SE MI
    '18 SR5P
    PM sent.
  11. Jul 20, 2021 at 8:34 PM
    Sounds like a great setup! Also, I'm 100% behind you on your reasoning against 285's.
