Morimoto XB Headlights Install Help?
Discussion in '5th Gen 4Runners (2010-2024)' started by spyder918, Jul 24, 2021.
  1. Jul 24, 2021 at 2:12 PM
    spyder918
    spyder918 [OP] 501st Unit: GGG
    2019 TRD ORP MGM
    So I've been watching/reading a few DIYs on this. My question is in regards to the fuse part. 1 article says to install the fuse tap into the 10A INJ port. A 2nd video says to install it in the 10A Mirror Heater Circuit 10A MIR HTR. Anyone know which is correct? Does it matter which one?
  2. Jul 24, 2021 at 8:10 PM
    GrayGhost
    GrayGhost New Member
    Dave
    2020 orp - sold
    The 10A INJ port is hard to tap on 2020 plus runners as they changed the fuse box. Some have left the cover loose but I worried about water getting in when I had a 2020. They make mini taps but the one I tried ruined the fuse block and I had to replace it.
    For 2019 and under its not an issue
  3. Jul 25, 2021 at 10:30 AM
    spyder918
    2019 TRD ORP MGM
    So is it just a matter of placement? Do either of the ports work? No difference?
  4. Jul 25, 2021 at 2:23 PM
    spyder918
    2019 TRD ORP MGM
    So I found the answer from another forum, just in case anyone else is installing these -
    "The INJ fuse is used for the Gen 2 headlights. Both will work, but the nifty start-up sequence is only available if the INJ fuse is used."
    mtnbiker67 likes this.
  5. Jul 25, 2021 at 4:26 PM
    mtnbiker67
    mtnbiker67 New Member
    Scott
    2020 TRD
    Correct.
  6. Aug 4, 2021 at 8:11 PM
    kymira13
    kymira13 New Member
    Good thread. I just ordered the Amber gen2's myself.
    But what if the INJ slot is already being used by my grille raptor lights. Can I use another fuse slot, If want to keep the start up sequence?
    Or is it possible to splice both (headlights and raptor lights) into one to both use the INJ slot?
  7. Aug 5, 2021 at 7:14 AM
    4runnerTRDoffroad
    4runnerTRDoffroad New Member
    2020 White TRD ORP
    Trd Pro wheels with Falken Wildpeak AT3 tires. Ceramic window tint. LED lights. Frontrunner 3/4 roof rack. Alpharex Luxx Headlights. Morimoto XB amber fog lights. Bilstein 5100 shocks front set at 1.75 and rear with a 1" cornfed spacer.
  8. Aug 5, 2021 at 11:57 AM
    kymira13
    kymira13 New Member
  9. Aug 5, 2021 at 12:34 PM
    stunner_4runner
    stunner_4runner New Member
    Raymond
    2020 4Runner SR5 4WD
    Radflo Stage 3 Lift Kit- 2.5 Extended Front & Rear RR Adjustable Coilovers Total Chaos Upper Arms ARB rear medium springs 3” Aiden James Switchback Fog Bezel Lights 4Runner Lifestyle Amber Raptor Grill Lights Trail Standard Offroad Satin/Matte Black TSO Pro Grille with 4Runner Letters Baja Designs WC Amber Fog Lights Baja Designs XL Sport Amber Ditch Lights with Cali Raised Ditch Light Brackets 2 Baja Designs LP6 Amber Behind the grille lights 2 SNS Designs 5" Amber Behind the grille lights N-FAB behind the grill lighting mount Pedal commander Jet Performance Mass Flo Air Sensor 315/70/17 Cooper STT Pro Fuel Rims Custom Magnaflow exhaust with Series 50 Flowmaster Muffler Alpharex Nova Midnight Black Headlights AFE Momentum GT Dry Filter CAI BantamX Touchscreen for Universal with sPOD Alpharex PRO-Series LED Tail Lights Jet Black Mid-Atlantic Off-Roading Full Length Roof Rack Outgear Solutions Low Key Front Bumper 4WDKING 30’ LED Light Bar for the Bumper RSG Front Skid Plate
    Move your raptor grille lights to the ACC fuse slot in the main cabin. Have my grille lights set up there and no problems. As for the issue for the headlights, I am running the Alpharex Nova's in the 10 INJ Fuse slot and T-Tapped my Aiden James Fog Light Bezels to the Headlight DRLs (10 INJ Slot). So, you can always T-Tap your grille lights to your Headlight DRLs and put them in the 10 INJ Slot.
    kymira13 likes this.
  10. Aug 6, 2021 at 3:22 PM
    kymira13
    kymira13 New Member
    Great info! I will try this when I get the Morimoto's in, I'll report back.
  11. Jan 23, 2023 at 8:25 AM
    jmanny86
    jmanny86 New Member
    Metallic Grey 2016 4Runner SR5
    I just recently purchased my 4Runner. I'm looking to upgrade to black rims, black roof rack, black running boards and more
    I just recently installed Morimoto XBs in my 2016 4Runner SR5, but put the fuse tape in a different spot than the standard 10Inj slot. I just ordered raptor lights (cheap shit from china) and they didn't come with a fuse tap, just open ended red/black wiring. Do you think if I somehow spliced the red wire with the morimoto fuse tap, it would work correctly?
