Morimoto 4 Banger and Switch Pro
Discussion in 'General 4Runner Talk' started by Mr. Snuffleupagus, Nov 22, 2022.
  1. Nov 22, 2022 at 10:56 AM
    Mr. Snuffleupagus
    Mr. Snuffleupagus [OP] Light Runner
    Brandt
    2022 TRD Pro
    Elka 2.5 DC, Sherpa Crestone, C4 Lo Pro, Baja Designs S8, Morimoto 4bangers, Switch Pro 9100, Westcott Designs sliders, Toyo Open Country RT Trail 285 75/R17
    I just finished wiring my Switch Pro 9100 panel and power tray system and Im ready to start wiring up some lights. I'll be running a Baja Designs S8 and Morimoto 4 banger A-pillar ditch lights. Baja sells a specific up fitter harness designed to work with the switch pro (no relay) but Morimoto doesn't appear to have any options. The 4 bangers run a DT 2 pin connector like some other brands. The only non-relayed switch I can find is from Diode Dynamics (link below) and the amperage should be well within spec for this harness. I suspect this will work fine with a direct wiring to my Switch Pro but would love advice from anyone who has switch pro wiring harness experience.
    https://www.diodedynamics.com/oem-auxiliary-switch-dual-output-2-pin-wiring-harness.html
  2. Apr 18, 2024 at 11:56 AM
    Sammck85
    Sammck85 New Member
    Did you ever get this figured out? I’m about to install 4Banger ditch lights with SwitchPros as well :)
