Mid/long range travel….educate me
Discussion in '5th Gen 4Runners (2010-2024)' started by suaveflooder, Jan 12, 2022.
  1. Feb 12, 2025 at 9:18 AM
    I’m pretty sure the 74weld kit comes with lower control arms. Website says that each side is 3.75 in wider than stock. Wouldn’t that increase total travel at the wheels?
    The kit price seems higher from what I recall, it’s at 20k now. It seems to have everything including new rear axle shafts. It mentions something about single shear or double shear steering options, but I dont know what that means.
    As far as stock geometry on the IFS, what I meant is that it lets you keep the LCAs flat, in the middle of travel range, which theoretically will give you the best articulation.
    I think the kit requires at least 36 in tires, but new brake calipers are included. Presumably they’re better than stock to deal with the larger tire diameter.
    All this said, 20k might get you a nice old Unimog.
  2. Feb 12, 2025 at 10:06 AM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    So Dirt King (2.5 DCA) or Ride Mid travel?
  3. Feb 12, 2025 at 10:23 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I don't believe so. I certainly could be wrong here... The portals push the wheels further out but that does not inherently increase travel. Longer upper and lower control arms together can. But physically pushing the wheel out with spacers or portals does not increase travel.
    You can see this with many custom baja rigs:
    That said, with IFS you are sacrificing available down travel when you lift. Soo the portals do mean you'll keep the factory amount of travel with a 3.88" of lift. So that's certainly something to consider!
    The way I view this is long travel is better for desert running, whoops and extreme articulation while portals are better at maintaining factory geometry while providing lift and superior ground clearance. Pros and cons to everything!
  4. Feb 12, 2025 at 10:29 AM
    10YSON
    10YSON New Member
    Greg
    2021 4Runner
    35s. Dirt King UCA. Eibachs. Body mount relocation. Cargo Molle panel.
    What system you use depends on the type of wheeling you do and your budget. The 74weld portals with their control arms are not going to keep with with LT and bypasses in the desert. If budget isn't a concern run both, the Marlin system is compatible with 74 portals IIRC
  5. Feb 12, 2025 at 10:32 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    I'm sure your truck is awesome, but I just can't see how going long travel on a daily rig makes sense. If you really push your vehicle in the desert, you are bound to break something, which means you probably need to trailer it anyways. Sounds like you spent around $26k for long travel. You can buy a decent used SXS for that price and there is no way a LT Tacoma/4Runner is keeping up with a SXS in the desert.
    Your truck does sound awesome though.
  6. Feb 12, 2025 at 10:37 AM
    1SilverRunner
    Tejas
    I was wondering about that... Has anyone done this?
    74Weld + Long travel?
    I can't imagine someone dumping that kind of money into a 4Runner.
    But I suppose there's an ass for every seat...
  7. Feb 12, 2025 at 10:52 AM
    10YSON
    10YSON New Member
    Greg
    2021 4Runner
    I should have mentioned that I don't daily the Tacoma. I am fortunate to live 20 minutes from the Rubicon and 50 minutes to open desert so investing in a tow rig doesn't make sense for me right now, it's easier to just hop in and go.
    If you're trying to get into off-roading for cheap you can't beat a sXs, especially if you already own a full-size truck.
    coryanderson[QUOTED] likes this.
  8. Feb 12, 2025 at 10:54 AM
    10YSON
    10YSON New Member
    Greg
    2021 4Runner
    Here you go! RCLT with 74Weld portals
  9. Feb 12, 2025 at 2:52 PM
    1SilverRunner
    Tejas
    Where'd you pull that from?
    Interested to learn more. Looks like a full on trophy truck!
    I'll bet my life savings that's no daily driver :cool:
  10. Feb 12, 2025 at 5:37 PM
    10YSON
    10YSON New Member
    Greg
    2021 4Runner
    They're @twc_racing on instagram and I'm pretty sure they ran it in the Everyman Challenge at KOH last year. They have a pretty cool FJ race truck too, they're worth checking out.
  11. Feb 12, 2025 at 6:14 PM
    1SilverRunner
    Tejas
  12. Feb 12, 2025 at 6:47 PM
    1SilverRunner
    Tejas
