Mickey Thompson Baja Boss A/T
Discussion in 'Wheels & Tires' started by PVT Pablo, Nov 24, 2022.
  1. Sep 12, 2025 at 5:47 PM
    #181
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    I'm also thinking about the MT BB for my next set. I would rather have XL than SL or E like McSpaz in the 285. I thought about going down a size to 275, but they no make. I'll probably go with KO3 in C load, unless someone has really good things to say about MT BB in SL in 285. I'll have to go back and re-read this thread.
  2. Sep 12, 2025 at 9:02 PM
    #182
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    Mickey Thompson's load rating and max PSI's are all over the place. Their website indicates only their LT sizes get their extra tough layer. I agree though, they certainly don't make it clear what the hell XL is.
    While not answering your question, and quite anecdotal, I've been running the SL 285's since I made this thread without issue. Again anecdotal, but the only tire sidewalls I've blown out were D's.
    I know we reeeeeeally like to run C+ on 4Runners and Tacomas but I just dont think with modern construction is really applies anymore.
  3. Sep 13, 2025 at 6:16 AM
    #183
    2020 Venture / 2017 Tacoma
    Give them a try and I think you would like them.
    Like many, I also get confused with all the nomenclature and it is clear that there is a ton "marketing" BS in how all the tire manufacturers position their products. Many weird claims and performance this and performance that etc, and funny enough, many of these tires get manufactured in the same plant under different labels and segments - How do I know? A friend works for Goodyear at the top and let me in a few :gossip:. In any event, my take on the MT is that they are very capable offroad. Better than the K02 and AT3 in my case; however, with that comes the extra noise on the HWY. That's just reality there, you get performance in one side but debit on the other one. There is good plot that I can't find to save my life that we use for showing PSI against load C, E, etc and that kind of explains a lot of things. I can't get this stuff right anyway....I always know, the better or tougher it looks the louder this $hit will be. I tell you what.....here is a guy you can ask, and he will give you a solid unbias response. Ask DJ @djwantke. He will tell you what he thinks.:D
  4. Sep 13, 2025 at 10:54 AM
    #184
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    thanks @ChessGuy lol !
    most folks surely are sick of my responses and thoughts.
    but, I’ve never had XL’s (or an SL A/T), but the load E have been brilliant. they get noisier in higher miles like any tire, but a higher level of noise simply because they’re a badass hybrid tread.
    also, I dunno why their website data is all over the place. I wanna know more about SL & XL like @McSpazatron, cuz i want lighter 35s. MT is a good rain tire tho I know that.
    4 years on these, photo today:
    ChessGuy[QUOTED] and RusPro17 like this.
  5. Sep 13, 2025 at 12:23 PM
    #185
    Yeah, I totally get where you’re coming from, and it’s good to get sanity checks on some of the stuff we do, maybe unnecessarily. I like the idea an SL tire, because I know how much unsprung weight affects everything. And I really like the idea of rolling down the road on cushy balloons :D.
    And then there is the legitimate question: Does a higher load rating mean better puncture resistance and tougher sidewalls? I can’t say I’ve seen anything that definitively *proves* that’s the case. But since I drank the Kool Aid and think they are tougher, I’d love to find any actual evidence that fits my narrative lol
    :p:anonymous:
    In my case, I’ve personally witnesses two flats on fairly new K02s Load C tires on somebody else’s 5th gen. Both flats happened on the same day, on the same 4runner, on the same trail I had driven down only minutes before. The trail was paved with football sized granite shards. I was running the same exact tire (besides being 33 vs 32in) with a similar level of wear. That’s the experience that has me locked into not going any lower than a load C. And I won’t go Load E just because I drive this thing too much on paved roads and don’t want to hobble myself with that much unsprung weight.
    Argh!! I kind of feel like I’m right back to where I was last time I looked at this thread. I thought hard about the MT BBs, but just ended up going with a known quantity and got another set of KO2s load Cs again. The second set has been good to me as well, so now it’s even more of a known quantity.
    All my research will probably make me have a mental breakdown. You’ll know it happened if you see me rollin on 34 inch Load E mud tires :p
    Captain Spalding likes this.
  6. Sep 13, 2025 at 1:09 PM
    #186
    Well, I dont think you can get the MT on 34s. So that should help you narrow your dilemma. I think next year I will get on the 34s bandwagon.
  7. Sep 13, 2025 at 2:17 PM
    #187
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Puget Sound, WA
    Honestly I used to be the "steel is real" and E load guy until I just kinda stopped. I know I'm not climbing a volcano, but I still want capability. So far the SL has been totally fine. Whenever I'm driving in a somewhat sketchy area, (shale, tree stumps, etc.) I just kinda take it easy. So far so good!
    If it helps tip the scales for you, I had KO2's on my Tacoma. Great tires, but I I'll be sticking with Mickey's from now on.
    Also, I'm the guy with aluminum bumpers, skids, rock sliders and SL tires so who knows maybe I'm the idiot haha
  8. Sep 13, 2025 at 3:18 PM
    #188
    If MT would make the BBs in standard load 33in, but with the thick side-tread of the load Es, I’d be all over that!
    …well probably….IDK….I’d have to think about it and start my analysis over :p
    :anonymous:
