Method 316 + Wildpeaks
Discussion in '5th Gen 4Runners (2010-2024)' started by CK96734, Apr 15, 2021.
  1. Apr 15, 2021 at 11:37 AM
    CK96734
    CK96734 [OP] New Member
    2021 SR5 Premium
    Stock Suspension. Method 316 Gloss Titanium. 265 Wildpeaks. I really like how it turned out and now I'm not sure if I need to add a lift just yet. Hopefully I can wait out this whole "backorder" conundrum we're all living through.
    I am rubbing up front on full lock in reverse on front fender and mudflaps...much to my dismay...guess I have some fender/mudflap modding to do. Also noticed a real "slight" increase in firmness with the wildpeaks which I liked. The runner does feel slightly sluggish with the heavier wheels and tires but nothing major.
    DUSTYDOGDAN, Kfish, hitech and 8 others like this.
  2. Apr 15, 2021 at 11:47 AM
    TXKK626
    TXKK626 New Member
    Fort Wayne, IN
    2021 Venture Edition
    Looks great!
    Considering Wildpeaks from the stock highway-ish tires myself. You're rubbing on stock tire size though? Is it the wheels or the tires that's causing that?
    CK96734[OP] likes this.
  3. Apr 15, 2021 at 11:58 AM
    CK96734
    2021 SR5 Premium
    The tires are stock size 265/70/17. I believe it's the wheels that are causing the rubbing. The Method 316 are 0 offset vs. the stock snowflake wheels at +15 offset (from what I've read online). I don't have exact measurements of the wildpeaks vs. stock Duelers but my guess is the rubbing is primarily caused by the more aggressive offset from the wheels. Hope this helps.
    j4unner likes this.
  4. Apr 15, 2021 at 12:04 PM
    TXKK626
    TXKK626 New Member
    Fort Wayne, IN
    Gotcha. Hows the road noise on the Wildpeaks vs. the Duelers?
    Again, looks great.
    j4unner likes this.
  5. Apr 15, 2021 at 12:15 PM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    same as well, how is the noise..?
  6. Apr 15, 2021 at 12:22 PM
    CK96734
    2021 SR5 Premium
    Thanks guys! Noise is minimal. Like any move from a stock touring tire to an A/T tire some noise is expected. Others on the forums have noted similar comments of minimal noise from the wildpeaks. I did have Toyo Open Country ATII on my previous 2012 and the noise level is about the same. Can't complain with either. While I don't have many miles of experience on my new wildpeaks, it sure feels great on the highway. You also can't beat the price for similar A/T tires and performance. Others I considered were the Toyo ATIIIs (didn't like the sidewall), Nitto Ridge Grapplers (apparently on backorder), and the KO2s but heard some were displeased with the rain/wet performance.
  7. Apr 15, 2021 at 1:47 PM
    Mike6.5x47
    Mike6.5x47 New Member
    2024 4Runner Off-Road Premium - Starting OVER!
    I love the look of the WildPeaks - sad that they're rubbing on you. I may stick with stock wheels for a bit for this reason.
    Trail Runnah likes this.
  8. Apr 15, 2021 at 2:10 PM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    I am surprised that a stock sized tire would rub!
  9. Apr 15, 2021 at 2:26 PM
    4runner95123
    4runner95123 New Member
    Matt
    Los Gatos
    2020 Nebula Gray GX460, 2018 SR5 Premium
    GX:20% window tint, weather tech floor mats, ICON stage one lift kit, 17 inch Fuel Rebel 6 wheels, BFG KO2s 285/70/R17. 4Runner: 265/70/R17 Falken Wildpeaks, Fuel Vapor wheels
    My stock wildpeaks have the same rubbing issue with method 305s and zero offset. Only on the front passenger side at full lock, when backing up. Why do we think that is?
  10. Apr 15, 2021 at 2:34 PM
    YetiMtnBkr
    Frederick, MD
    2021 LR Pro
    None
    Probably a dumb question considering how often I see this: "rubbing at full lock, when backing up", does this mean when the steering wheel is fully turned to the left or right?
  11. Apr 15, 2021 at 2:41 PM
    Mike6.5x47
    That's how I'm interpreting it. As for the reason why, I'm guessing there's either a difference in the wheel backspace and/or offset from stock OR it may simply be that the tire profile near the edge is wider than stock.
  12. Apr 15, 2021 at 2:50 PM
    CK96734
    2021 SR5 Premium
    Yes, it's all about the backspace/offset. If you read through a lot of previous posts, you'll hear others comment on how significant wheel offset can have, even with stock sized tires. Even if you have a lift, there are still rubbing issues as you go more negative offset and larger tires. It's all part of the game.
    Check out this post where a guy is running the same Method 316 wheels, but with stock size BFG KO2s instead of the wildpeaks. He noted no rubbing at all.
    https://www.4runners.com/threads/method-race-wheels-mrw316.15186/#post-170586
    The other option is to go with the TRD SEMA wheels. You'll be moving from the stock +15 offset to what I believe is +4 offset of the SEMA wheels. With 265/70/17 wildpeaks, you probably won't rub. Going to Methods or other wheels with 0 offset (or worse with negative offset) is probably where you get rubbing with stock size tires.
    nimby and T4runner11 like this.
  13. Apr 15, 2021 at 3:21 PM
    4runner95123
    Matt
    Los Gatos
    When my steering wheel is full turned to the left and backing up. However not when fully turned to right when backing up. That’s what I find weird.
  14. Apr 15, 2021 at 3:40 PM
    Joekader
    Joekader New Member
    Joe
    Looks great love my wildpeaks also
  15. Apr 15, 2021 at 4:10 PM
    YetiMtnBkr
    Frederick, MD
    2021 LR Pro
    None
    Is that the spot where a BMC is required to allow 285's on most 4R's. Always interesting that some claim to have 285's on stock set up with no rub and a 265 Wildpeak will rub - perplexing!
    Getting really close to pulling the trigger on a Pro which has a 1" higher front and the narrower TRD SEMA wheels. I would hope it would easily allow a 275 without rubbing.
  16. Apr 15, 2021 at 6:37 PM
    Looks awesome!
    Do the fender liner mod, push your caster up to 3.5 degrees or so and you'll avoid rubbing the mudflap.
  17. Apr 15, 2021 at 6:40 PM
    You'll probably be fine since the Pro comes with the fender liner mod from port.
    If you do have any rubbing, it would most likely be on the mudflap........which can be fixed with an alignment in this scenario.
    YetiMtnBkr[QUOTED] likes this.
  18. Apr 16, 2021 at 9:03 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    This. Both.
  19. May 29, 2021 at 10:14 AM
    Ryan89P
    Ryan89P New Member
    RVA
    '21 SR5P
    that color combo looks great! did you have the factory tpms removed from the stock wheels and swapped over to the 316s? any issues with installing them?
    Thanks!
  20. May 29, 2021 at 4:39 PM
    CK96734
    2021 SR5 Premium
    Yes, factory tpms transferred to the methods with no issues. You can always buy new tpms sensors if you want.
  21. Dec 6, 2021 at 4:54 PM
    Cruf665
    Cruf665 New Member
    2016 MGM SR5
    Just pulled the trigger and ordered the exact same setup for my 16 SR5.
    Stoked! How have you liked the setup so far? Really crazy to hear they're rubbing with a stock size....
    Did you do the fender liner mod?
  22. Dec 6, 2021 at 5:08 PM
    It's the aftermarket wheel. These things are incredibly sensitive to changes in wheel backspace or offset. With the stock wheel, most likely they would not rub.
    nimby likes this.
  23. Dec 6, 2021 at 5:12 PM
    T4Rrunning
    T4Rrunning New Member
    What is everyone running? LT tires or passenger rated?
    Still trying to decide on that for my next tires.
  24. Dec 6, 2021 at 5:16 PM
    I'm running passenger rated on mine, stock size. The jump in weight to the E Rated was fairly large in the tire that I have, and I didn't think it was worth it.
    Maybe if this was strictly an off-road vehicle, or if I carried a lot of weight I would have went with the E Rated. I used to wheel my old Grand Cherokee on P Rated, in the rocks, and I never had any issues.
    Personally I think E is overkill for a daily driver.
    T4Rrunning[QUOTED] and nimby like this.
  25. Dec 7, 2021 at 8:18 AM
    Dohc97
    Dohc97 New Member
    I have the exact same wheels with Continental Terrain Contact AT in 265/70/17 size sitting in my garage now. Did you have to use centering rings on the Method wheels? 3 of my wheels came with rings. Waiting for a ring to be sent by Method wheels. My tires are less aggressive than yours. Also, I have a TRD sport which doesn't have mudflaps. Do you think my front wheels would rub on full lock?
  26. Dec 10, 2021 at 11:52 AM
    Dohc97
    Dohc97 New Member
    Finally got the Method wheels mounted. Tires are Continental TerrainContact AT in 265/70/17. No rubbing on stock suspension.
    08TXRunner, afret and 619T4R like this.
  27. Dec 10, 2021 at 12:32 PM
    619T4R
    619T4R New Member
    2021 SR5P
    Looks nice!
  28. Jan 13, 2022 at 5:50 AM
    midnightorp
    midnightorp New Member
    Tim
    2022 Black 4Runner ORP
    This is the exact same setup I think I want on my 4Runner. Would spacers eliminate the rubbing problem? I saw on TrailBuilt Off-Road's YouTube/Instagram that they ran the same setup fully stock with no rubbing.
  29. Jun 3, 2022 at 7:42 PM
    runnertwin
    runnertwin New Member
    Steve
    2017 SR5, 2021 OR
    Are these wheels matte black or the titanium color. Have the same paint color 4r and trying to decide what color wheel to go with. Thanks.
  30. Jun 4, 2022 at 8:45 AM
    Dohc97
    Dohc97 New Member
    nimby likes this.
