Metal Oil Filter Housing and the “clip”
Discussion in '5th Gen 4Runners (2010-2024)' started by AE1M, Jan 26, 2025.
  1. Jan 26, 2025 at 5:29 PM
    AE1M
    AE1M [OP] New Member
    Bob
    2024 TRD Off-Raod Premium
    The OEM plastic filter housing has a special “fin” for the metal clip that I hear prevents the housing from spinning off. It has a “groove” for the clip in one of the fins.
    The OEM (Toyota 15620-31060) metal housing does NOT have that special fin with a groove. Have guys just forced it onto the metal fin or just leave it off. I found I had to spread the clip a bit to force it onto the metal fin that I don’t think was meant to hold one.
    Hard to believe that if it’s torqued to spec (18ft-lb) it would loosen itself up. Maybe for off-roaders? I don't off-road much except to a few hunting spots in the woods nearby but nothing rough.
    Bob
  2. Jan 26, 2025 at 5:44 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Clip is worthless. I've never heard of a failure from the housing loosening up.
  3. Jan 26, 2025 at 5:45 PM
    The plastic housing is fine, there's really no reason to upgrade to the metal one. There's 12 years and 186k miles on my stock plastic housing.
    Nick B, catbrown357, 2016Pro and 2 others like this.
  4. Jan 26, 2025 at 8:17 PM
    Since we’re talking about the clip … suppose I perform a textbook oil change and torque the plastic housing to the specified 18 ft-lbs., and then take note of the clip’s orientation. Given the nature of the plastic housing and its o-ring, i.e. that the o-ring contacts the mating surface on its side, is it reasonable then on subsequent oil changes to omit the torque wrench and just tighten up the housing so that the clip is in the same orientation?
  5. Jan 26, 2025 at 10:34 PM
    Just snug it with your ratchet using wrist power.
    Captain Spalding likes this.
  6. Jan 27, 2025 at 4:27 AM
    AE1M
    Bob
    Thanks for the reply, but this thread is not about plastic vs metal. Already crossed that bridge. Very few mission critical parts that are a single point of failure are plastic. Any spin on filters you’ve ever seen made of plastic?
  7. Jan 27, 2025 at 4:45 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Correct! It will tighten itself up to the exact same location. Of course, you can apply more force and go a few notches ahead but if you hand tighten it, it will always 'stop' at the same spot.
  8. Jan 27, 2025 at 4:49 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Your plastic filter housing is not going to crack, leak or give away. It's not a poor material choice by Toyota. That is as durable a piece as any. 190k plus miles, still on original.
    Trail Runnah and 2016Pro like this.
  9. Jan 27, 2025 at 5:34 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I don’t see what the big whoop is all about over switching to that metal cap. I bought my 2022 SR5 Premium 4WD Pre-owned-Certified a year ago November.
    I found out doing my first oil change in it that it still had its factory plastic cap, and it still does. Before I bought my T4R, I had been reading this board, including
    many posts about this must have metal cap. So my thinking was ah man that’s the first thing I have to upgrade on any T4R that I may eventually purchase.
    I was already planning to do my own oil changes, so when it came time to do my first oil change, I thought OK, I’m going to have to do battle with removing this plastic cap and see just how bad it is before I go buy the metal cap. Pfffft…. I was able to remove it with no problem. I had purchased the proper cap removal tool in advance, and turned it loose with my breaker bar no problem.
    Upon my first ever inspection of the plastic cap, it looked perfectly fine to me. So I decided to keep using it. I torqued it back on to spec with my torque wrench. I’ve now already done two oil changes on my truck, and that plastic cap is not causing me any grief.
    Conversely, apparently some of these plastic caps have apparently been damaged through the mis-use of over-tightening. Apparently, mine was treated properly prior to my purchasing it. I’ll continue using the plastic cap on mine until it gives me any cause to change it out. Even then, I could very likely go with the standard plastic piece again. So far so good on the plastic one.
    whippersnapper02 likes this.
  10. Jan 27, 2025 at 6:27 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    The one, and only, oil change that I had Toyota do, some jag-off in the service department overtightened my oil filter housing. So much so that I needed a pipe wrench with a breaker bar to loosen it. The MotivX tool rounded out the flat faces. I bought a new plastic filter housing that has been properly torqued for the past 10 years and 150,xxx miles. No problems. To the OP @AE1M if the metal housing helps you sleep better at night, great. Hopefully you bought it at a reputable place, not scAmazon, or Fleabay where OEM fakes are rampant, hard to spot, and negate your mission critical part. If it is genuine OEM, just torque it to 18 ft.-lbs. and call it a day.
  11. Jan 27, 2025 at 6:36 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    My plastic housing broke due to a cheap filter wrench + Toyota techs overtightening the thing.
    It was of course my last "free" oil change by Toyota...
    Upgraded to the OE metal case I bought at a Toyota stealership. Swapped the spring and tube of course.
    I like the aluminum but the plastic one is fine as long as you use a good filter wrench and don't overtighten the thing.
    And yes. I now ignore the safety clip at the top
    nimby and catbrown357 like this.
  12. Jan 27, 2025 at 6:38 AM
    You sort of made it about plastic vs metal by stating "OEM (Toyota 15620-31060) metal housing"... Toyota does not specify the metal housing as OEM for the 4Runner. If it were, one wouldn't have to swap out the center tube & spring.
  13. Jan 27, 2025 at 7:37 AM
    Tino
    Tino New Member
    New York City
    Just accessories
    Hello Glywood. Somewhere on this forum someone mentioned that lexus had a metal one that was a direct replacement with no need to swap out the tube. I had asked for the part number but never received a reply. Do you perhaps know of this part?
  14. Jan 27, 2025 at 8:21 AM
    catbrown357 likes this.
  15. Jan 27, 2025 at 8:31 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    It's more got to do with gaining an additional 2 HP with the metal housing. Also, longer oil change intervals due to the alleged 'superiority' of the metal housing.
  16. Jan 27, 2025 at 8:35 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    That's exactly what I do, minus the initial torquing. I just always tighten it back to where it was when I got it.
  17. Jan 27, 2025 at 12:34 PM
    Yeah, I've heard that rumor also, but I've yet to see anyone who purchased the metal housing, whether from a Toyota or a Lexus dealer, that didn't have to swap the the tube out. I guess Lexus owners don't circulate as much oil, hence the shorter tube...
  18. Jan 27, 2025 at 2:51 PM
    poncho65
    poncho65 New Member
    New England
    Same here. I'm the only one who's changed the oil, since I purchased my rig new from Toyota. I just align the clip to the detent, the exact position as set by the factory.
  19. Jan 27, 2025 at 4:55 PM
    Yes. Just tighten it up to the same spot.
  20. Jan 27, 2025 at 5:15 PM
    Schlappesepple
    2020 ORP
    I'm glad we've all independently arrived at the same arbitrary solution, good work team.
    Texas-Gorilla likes this.
