Maxed out Mid-Travel build
Discussion in '5th Gen 4Runners (2010-2024)' started by SmoothOperator, Apr 8, 2025.
  1. Apr 8, 2025 at 11:24 AM
    SmoothOperator
    SmoothOperator [OP] New Member
    2022 2Runner
    Hey all, just creating this thread to document my build. I've been wanting to build a stock width 2wd 4runner for dune/desert use for a while and Im finally getting after it.
    Here it is, prepared to not be stock anymore.
    Ironguy, Kyblack76, Whammo and 2 others like this.
  2. Apr 8, 2025 at 12:24 PM
    It's already in the "Take Off/Launch" position. Nice!
  3. Apr 8, 2025 at 1:00 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Nice, have fun with the build
    SmoothOperator[OP] likes this.
  4. Apr 8, 2025 at 1:43 PM
    SmoothOperator
    2022 2Runner
    8" travel 2.0 Radflo coilovers w/18" 550lb eibach coils.
    Gained 2in of droop and w/ the stock control arms in place. The control arms are definitely the limiting factor at this point with the tie rods not far behind.
    djwantke and hossler1788 like this.
  5. Apr 8, 2025 at 2:45 PM
    SmoothOperator
    2022 2Runner
    I built this jig a few months ago. Allows me to replicate factory geometry, or modify from it. Will build my own upper control arms using this jig.
  6. Apr 8, 2025 at 3:15 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    That's bitch'n. I am putting aside my lunch money to find a 2wd 5th gen for a build like this.
  7. Apr 8, 2025 at 7:24 PM
    SmoothOperator
    2022 2Runner
    1.25" .187 wall DOM. 1in Uniball cups, and 2in .25 wall bushing shells. Put .625" of linear caster into the arms. Offset the tube into the bushing shells, instead of correcting angle at the uniball cup. I'll be running delrin bushings in these.
  8. Apr 9, 2025 at 5:21 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Nice. Out of curiosity, what's the extended length on those front shocks?
  9. Apr 9, 2025 at 6:29 AM
    SmoothOperator
    2022 2Runner
    I don't remember the exact length. If I remember correctly they're about 1.5" longer that the standard "extended length" drop in coilover, but also about 0.5" shorter when fully compressed.
    When I pull them back out I'll give you exact measurements.
  10. Apr 9, 2025 at 9:00 AM
    SmoothOperator
    2022 2Runner
    Giving my little micro lathe a workout.
    McSpazatron and hossler1788 like this.
  11. Apr 9, 2025 at 12:49 PM
    I like where this thread is going. Love to see how people make stuff! Keep it coming!!!
  12. Apr 9, 2025 at 3:54 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
  13. Apr 11, 2025 at 9:38 AM
    Dengland
    Dengland New Member
    Dylan
    2022 T4R ORP
    :cheers: following for this rad build!
  14. Apr 11, 2025 at 10:31 AM
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    Same. Following!
  15. Apr 11, 2025 at 11:20 AM
    Bentwrench
    Bentwrench New Member
    Western Washington
    Are these prototypes, or will they be going on the vehicle? Could you post a close up of the welds?
  16. Apr 12, 2025 at 5:13 PM
    Cool. Curious what you have planned for secondary shocks. :popcorn:
  17. Apr 15, 2025 at 3:52 PM
    SmoothOperator
    2022 2Runner
    Both. These will end up on the vehicle as I play with caster. These will not be the final arms.
    At this point, I don't plan on a secondary, as there isn't enough room without doing a different lower, which is doable but also requires modifying the chassis considerably, which I'm trying to avoid. In working with Radflo, we feel the 2.0 should be sufficient with proper valving and good bump stops. We're also toying with the idea of larger reservoirs if need be.
    I'm also really debating on down the road doing some +1 upper and lower arms which would then give me the room for a larger shock without being super wide.
    We'll see where this goes lol.
    I haven't made much headway this last week. Been waiting on some parts, and my day job(heavy equipment repair) has been getting in the way. Should make some more progress this weekend.
    hossler1788 likes this.
  18. Apr 16, 2025 at 4:00 PM
    SmoothOperator
    2022 2Runner
    So what i told you prior, I had backwards.
    Compressed these are 14.8". Extended 22.83".
    Got some time to play with the rig today. I actually have .25" more travel with the factory uppers than I do with my tubular arms. Even with quite a bit of caster the uniball cup hits the spring at droop, being much larger than the factory ball joint.
    My options now are to lock the lowers out at their widest, and build adjustable uppers, and/or just bite the bullet and go +1 arms, and heimed steering all in one shot.
    I do find it funny that shops are claiming their uniball uppers are increasing travel, when that's clearly not the limiting factor...
  19. Apr 16, 2025 at 5:35 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    What if you go with a ball joint like jba, Would the spring still hit the ball joint? Even if you rotated the spring does it still hit
    Since most "extended travel" shocks have 6" of travel and these have 8" are you just running into issues.
  20. Apr 16, 2025 at 5:44 PM
    SmoothOperator
    2022 2Runner
    Yes, the extra shock stroke is definitely giving me issues, but I knew it would to a degree. I dont think the chev style balljoint like JBA uses would give me any extra clearance. I'm going to do more playing with it. I'll find a workaround. This is the fun part!
  21. Apr 16, 2025 at 5:51 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I agree the work is the fun part. Any idea of actual travel numbers? On my previous tacoma mild travel build I couldn't go over front 9.15"
    ish of(actual) travel without hitting the frame or uca. Jba uca gave me the best clearance.
  22. Apr 16, 2025 at 6:41 PM
    HazOpRed
    HazOpRed 22' TRDOR
    So what is limiting the suspension droop now? The cv axle?
  23. Apr 16, 2025 at 8:34 PM
    SmoothOperator
    2022 2Runner
    Im going to pull the coilovers out tomorrow so I will measure travel.
    No CV's. It's 2wd. The control arm contacting the coil is the limiting factor. Then the next hang up will be the tie rods.
    HazOpRed[QUOTED] and djwantke like this.
  24. Apr 17, 2025 at 6:19 AM
    SmoothOperator
    2022 2Runner
    11.5" from from contact of spring at droop, to touching the bump stop at compression.
    djwantke likes this.
  25. Apr 17, 2025 at 6:29 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Damn that's a crazy amount! And that's with oem uca? Shit I'd just limit the droop by a 1/4" with limiting straps and move to the rear. What do you plan on doing to the rear suspension?
  26. Apr 17, 2025 at 8:19 AM
    SmoothOperator
    2022 2Runner
    I cant leave well enough alone hahaha. I want to at least get to 12" bumped and strapped. I've got some ideas to get there.
    The rear will be simple. Lower links will be bushed at the frame and uniballs at the axles.
    The driver side upper link will be ditched. The passenger side will be bushed at the frame as well, but heimed at the axle for adjustability, then an adjustable panhard.
    hossler1788[QUOTED] and djwantke like this.
  27. Apr 17, 2025 at 8:32 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    me watching this thread
  28. Apr 17, 2025 at 9:11 AM
    Love the license plate:hattip:
  29. Apr 17, 2025 at 9:43 AM
    SmoothOperator
    2022 2Runner
    That was on my '82 Chev K20 :D
  30. Apr 18, 2025 at 7:49 AM
    SmoothOperator
    2022 2Runner
    Okay, so I've decided on my next move.
    I'm going to make some lockout plates for the LCA's, that pushes them out to max width. Then I'm going to fab new uppers that will have offset heims. This will give me the adjustability for camber and caster, and should give me the clearance I need to hit my 12" mark.
    I probably won't get back to it for a few weeks. I will update as this progresses.
    McSpazatron likes this.
