Making sure I have everything for my new lift
Discussion in 'Suspension' started by tuc4r, May 16, 2018.
  1. May 16, 2018 at 8:46 AM
    tuc4r
    tuc4r [OP] New Member
    Todd
    Tucson, AZ
    2018 T4R TRD ORP
    2018 4Runner ORP W/KDSS - ADS coil overs, ADS remote resi rear shocks, Total Chaos UCA's, Icon 2' rear springs, Nitto Ridge Grapplers, FN FX PRO wheels, AVID rock sliders, RCI Aluminum front skid, Bussman Fuse/Relay module, Canvas backs, Accessorides remote start, Rago Mole Panels, HID low beams, LED high beams, Morimoto XB fogs, Ceramic window tint, Ecotechne roof rack,
    I am getting ready to pull the trigger on a new lift, and I want to make sure that I'm not forgetting anything.
    ADS IFS Front Coilovers
    ADS Rear Shock W/Piggybacks
    Total Chaos UCA's
    Rear Coils - Not sure what to get yet, looking at 2 1/2" of lift and want it level.
    Adjustable Track Bar - Not sure if needed, from what I have read doesn't need it.
    Not sure if any trip packers are needed.
    New Rear Bump Stops - Not sure if needed.
    I am coming from the Tacoma side, and I'm a complete newbie on the 4runners. Picking up my new 2018 TRD OR Premium with KDSS on Friday.:bananadance:
    Thanks for any info or advice,
    Todd
  2. May 16, 2018 at 9:20 AM
    Toytec Lifts
    Toytec Lifts New Member Vendor
    Denver, Crawlorado
    Looks like you have everything rockin on the lift!
    For the front end though, is it just coils or full coilovers?
    Rear coils, all depends on what your weight application is going to be, we offer a couple different spring options that yield 2'' over stock, check out the stock weight 2'' spring HERE
    Rear trac bar or "Pan Hard Bar" is a good recommendation, but something that is NOT required to complete your lift.
    Trim packers are a "case by case", all depends on your weight application...
    Rear bump stop extensions are a good recommendation so that way you don't over compress/ extend your shock, we offer a 2'' drop kit that can be found HERE
    Also welcome to the forums!!
    Let me know if you have any questions!
    -David
    Backslider likes this.
  3. May 16, 2018 at 10:42 AM
    tuc4r
    Todd
    Tucson, AZ
    2018 T4R TRD ORP
    Thanks David,
    They are coilovers. I will be looking at your srpings.
    Toytec Lifts likes this.
  4. May 16, 2018 at 10:43 AM
    Toytec Lifts
    Denver, Crawlorado
    Sounds good man!
    Let me know if you have any questions.
