Made a Mistake
Discussion in '5th Gen 4Runners (2010-2024)' started by raimieb, Sep 16, 2023.
  1. Sep 16, 2023 at 3:53 PM
    raimieb
    raimieb [OP] New Member
    raimie
    2021 ORP 4x4
    So, I went to shift a spacer from one coil spring to the other and forgot to undo the lower shock bolt. Pulled apart my rubber shock mounts on top. Now I have to order overnight parts from Elka in Canada to fix them. Anyways, now I remember why I undo the lower shock bolt. If you’re working on the back, please don’t do what I did.
  2. Sep 17, 2023 at 6:30 AM
    Dobinson IMS Warn Bumper CaliRaised Sliders 265/70 K02s
    I don’t follow. What was your mistake and what got damaged?
    I changed out rear coils without removing the lower shock bolt. Just undid the shock top bolts and lowered the rear axle with a jack.
  3. Sep 17, 2023 at 6:42 AM
    raimieb
    raimie
    2021 ORP 4x4
    Didn’t undo top or bottom. Just pulled on the shock. :(
  4. Sep 17, 2023 at 8:06 AM
    I don't get it, either - if the shocks were still bolted in top and bottom, how were you able to lower the rear axle?
  5. Sep 17, 2023 at 8:09 AM
    raimieb
    raimie
    2021 ORP 4x4
    Bottle jack in between the axle and the bump stop area. Pushed the rubber shock mounts down and ripped them in half.
  6. Sep 17, 2023 at 8:10 AM
    Oh. Sorry.
  7. Sep 17, 2023 at 8:19 AM
    raimieb
    raimie
    2021 ORP 4x4
    thanks brother. Just thought to share so others don’t follow suit if possible.usually I do better than this but learned this one the hard way.
  8. Sep 17, 2023 at 8:22 AM
    Got any pics of said carnage? I've considered Elka shocks, and am curious how this could happen...
  9. Sep 17, 2023 at 8:42 AM
    raimieb
    raimie
    2021 ORP 4x4
    I will post. Definitely not the shocks fault. The pressure of a jack is way stronger than any shock mount. Actually glad they held up to my stupidity. Overall the shocks are like butter, so smooth.
  10. Sep 17, 2023 at 8:44 AM
    Have you already contacted Elka to see if the mount in question can be replaced?
    Also, did you happen to do a before & after writeup on your installation?
  11. Sep 17, 2023 at 8:46 AM
    raimieb
    raimie
    2021 ORP 4x4
    They open on Monday. Yeah, all rubber mounts can be replaced ;)
  12. Sep 17, 2023 at 10:31 AM
    Ouch! Both sides, or just one? You might want to check the shock mount tabs on the frame itself to make sure you didn’t bend them downward. Hopefully the shock itself is fine, but I’d monitor that once you install it again. They are made to hold the axle’s weight, but not sure if it would stand up to a jack’s pressure.
    Did you disconnect the sway bar links? Check the rubber bushings and mounts on that as well.
    raimieb[QUOTED][OP] likes this.
  13. Sep 17, 2023 at 11:02 AM
    Coupe
    Coupe New Member
    Houston, Texas
    2008 Toyota X-Runner
    All of us have broken something due to stupidity.
    If you haven't, you have been letting someone else wrench on your truck.
    Welcome to the club.
    grizzlypath and Texrun50 like this.
  14. Sep 17, 2023 at 12:29 PM
    raimieb
    raimie
    2021 ORP 4x4
    Will definitely check. Good insights!
  15. Sep 17, 2023 at 9:00 PM
    Haha true!!! Even pros start somewhere.
    raimieb[OP] likes this.
