Low on power at high speed
Discussion in '4th Gen 4Runners (2003-2009)' started by NoSleepCrew, Apr 7, 2022.
  1. Apr 7, 2022 at 6:33 PM
    NoSleepCrew
    NoSleepCrew [OP] New Member
    2007 White SR5
    Icon suspension/drop in high flow air filter
    I had my 4Runner (SR5 V6) in Texas as a “go home” vehicle. Recently I drove it to California and noticed when I was cruising at 75-80mph in the hilly parts, it felt like it took lots of effort to maintain speed. My other cars are a Golf GTI and Mini Cooper S. I know the 4Runner is not going to act like them at all, but it just felt like it was really struggling to go up hills. Mind you, this is at higher speed and only turning around 2300 rpm.
    Does this sound normal? Anything I can do in general to get more power at higher speeds?
    TYIA
  2. Apr 7, 2022 at 7:06 PM
    That's normal. You're driving an almost 5000 lb brick with an engine that doesn't make a lot of power at low RPM.
    And no, short of supercharging there's really nothing you can do to increase power.
    I would say pop the shifter over into sequential mode, that will lock out overdrive (5th gear) so you'll be turning at higher RPM, where there's a little bit more power available.
    PigFarm likes this.
  3. Apr 8, 2022 at 10:30 AM
    NoSleepCrew
    2007 White SR5
    Wamp wamp.
    Don’t know if I’ll put a super charger on it, think I’ll just accept it for now.
    Trail Runnah likes this.
  4. Apr 11, 2022 at 8:01 AM
    PigFarm
    PigFarm New Member
    Waclaw
    2007 V8 4x4
    2.5" Bilstein Leveling kit and KO2s.
    Less oxygen at high altitude. Drop it down to 4th or even 3rd if needed.
  5. Apr 11, 2022 at 8:04 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    @NoSleepCrew @80, I bet the mileage sucked big time too
  6. Apr 11, 2022 at 9:22 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    There is no elevation issue on I-1, 20 or 40 except in nortern NM on I-40.
    This is your issue
