loud exhaust?!
Discussion in '2nd Gen 4Runners (1990-1995)' started by raceyota95, Mar 16, 2017.
  1. Mar 16, 2017 at 10:57 AM
    raceyota95
    raceyota95 [OP] New Member
    silver 95
    Just got my first 4runner. Running loud so I took it in, guy says the exhaust checks out but its been straight piped. Will an aftermarket catalytic converter quiet this thing down? Or maybe its an issue I haven't considered?
    OvrlandNoob likes this.
  2. Mar 16, 2017 at 4:03 PM
    Stuck CAPS
    Stuck CAPS Truck killer
    Alex
    2007 Nautical Blue Metallic Limited V6 4x4
    ARB Bumper, Some Stuff, Some Other Stuff, and some Stuff.
    If it's straight piped, it's meant to be loud. That means it's headers to a pipe without a muffler. If you want to quiet it down, you can get an exhaust silencer that bolts into the tip to quiet it down, or get a muffler welded into the pipe.
  3. Mar 16, 2017 at 4:21 PM
    raceyota95
    silver 95
    Sorry for the miscomm.
    It has a muffler, it does not have a catalytic converter. Its not crazy loud but I would like it quiet. Muffler guy says aftermarket cat. con." MIGHT" not quiet the thing. Any thoughts?
    And thank you for your response.
  4. Mar 16, 2017 at 4:23 PM
    Stuck CAPS
    Alex
    Aftermarket cats tend to be sub-par quality OR meant to be a high flow cat. Which cat(s) is/are missing? All of them?
  5. Mar 16, 2017 at 4:29 PM
    raceyota95
    silver 95
    I think there was only one catalytic converter on there, now there is none.
  6. Mar 16, 2017 at 4:44 PM
    Stuck CAPS
    Alex
    Could you give me a bit more info into your vehicle?
  7. Mar 16, 2017 at 4:56 PM
    raceyota95
    silver 95
    '95 with 196k
    Just bought it from a guy who said it had a knock sensor issue. Shop says the code is EGR valve, no knock sensor code.
    Decided to wait on the EGR and changed the plugs and wires .Changed the oil and filter checked all the fluids and vacuum lines. One of the plugs had oil on the wire and terminal side of the plug. Runs better now but still loud and maybe missing a little power.
  8. Mar 16, 2017 at 4:59 PM
    Stuck CAPS
    Alex
    v6 or 4?
  9. Mar 16, 2017 at 5:00 PM
    raceyota95
    silver 95
    Sorry, v6 3.0
  10. Mar 16, 2017 at 5:04 PM
    Stuck CAPS
    Alex
    Okay, so the way I see it is if you want it to quiet down to stock, you need stock manifolds.
  11. Mar 16, 2017 at 5:10 PM
    raceyota95
    silver 95
    Cool thanks man . I will look in to that.
  12. Mar 19, 2017 at 12:21 PM
    raceyota95
    silver 95
    That's a big help thank you!
