Losing power
Discussion in '2nd Gen 4Runners (1990-1995)' started by rudyi, Aug 17, 2016.
  1. Aug 17, 2016 at 9:18 PM
    rudyi
    rudyi [OP] New Member
    Hello, just joined today. I heard about this 4runners.com is a great source of information. Well, I have 1994, 4runner, auto, 3.0L, loaded. My runner was running great but lately, it seems like its losing its power in the freeway. I pushed the accelerator all the way down to the floor and it can only go to 60MPH. Also, going up it slows down to 45MPH and the RPM is about 4500. Any idea?
  2. Aug 17, 2016 at 9:46 PM
    jester243
    Dan
    Spokane, WA
    When was the last full tuneup and fluid change done?
  3. Aug 17, 2016 at 9:52 PM
    rudyi
    Just replaced the plugs, wires, rotor and cap recently. I'm in the process of replacing the the transmission fluid/filter. But, I'm having a hard time taking the transmission fluid pan. Took all the bolts but still the pan won't come off.
  4. Aug 18, 2016 at 7:34 AM
    Kyle11863
    Kyle11863 King of the BS
    Big Bear California
    1990 Toyota 4Runner SR5 V6 5 Speed Manual
    Doug Thorley long tube headers and lots of mud
    Maybe the gasket melted to the trans? Not too experienced with autos, but would suggest taking a screwdriver and giving it a little pry. It is possible that someone used rtv in there and if that is the case a little prying will be necessary. Just don't scratch the mating surfaces
  5. Aug 18, 2016 at 8:06 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Not sure on the old 4runners but Toyota likes to use FIPG (Form in Place Gaskets). They are like RTV, but personally I'd try to find the Toyota one because RTV can be hard to get a perfect seal if you haven't use it before. If you're good with it, should be fine.
    Also, check a few other things.
    Throttle Body, clean that out.
    Air Filter, check for restriction.
    Fuel Filters / Pumps.
    Spark plugs / wires / distributor. (oops you already said this)
    Typically engines need Spark, Compression, and Fuel. It's usually one of the three. I count airflow in the compression part, and recently my sister in laws 2003 camry with 300,000 miles was idling rough, dying at low rpms (traffic lights), and it ended up being the thottle body was so nasty that the butterfly wasn't closing or opening right. Cleaned it, and off they went.
    Kyle11863 and jester243 like this.
  6. Aug 18, 2016 at 8:53 AM
    rudyi
    Thanks for the input. Air/fuel filters were replaced early this year. I'll check the throttle body.
  7. Aug 18, 2016 at 9:09 AM
    Kyle11863
    Big Bear California
    Make sure you clean with the correct chemicals. Crc throttle body and intake cleaner works pretty well. Used it on my buddies tacoma and it did the job. Going to be using it on mine later today probably
  8. Aug 18, 2016 at 9:31 AM
    rudyi
    Guys, thanks a lot. I pry the pan with a screwdriver and it is off now. However, I encountered another problem, I can't take the pan all the way out due to the cross bar. Do I have to take the cross bar out? Need some advice.
  9. Aug 18, 2016 at 10:25 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    I had 2nd gen way back in the day. I had similar symptoms on mine and when I took it in they said all the injectors were drawing in dirt from somewhere and getting clogged. If I remember right they replaced all the injectors and fuel rail. That was 12 years and about 3000 beers ago so I'm not 100% sure if remember that all correctly though... good luck!
  10. Aug 18, 2016 at 11:00 AM
    Kyle11863
    Big Bear California
    I have no clue on the cross bar since mine is manual, but it does sound like it needs to be pulled off. Should just be 4 bolts so its an easy removal.
    Only 3000?
  11. Aug 18, 2016 at 11:19 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I'd pull the cross bar. You want to clean that pan out well, and the only way to do it right would be to have access to it on the ground. Just note which screws go where, and if you can't find a manual to note how much torque to put back on the screws when re-installing, then google it. Don't get all paranoid about it, but I want to keep things bolted on while I'm driving :) I use a good bit of blue thread locker, or anti-seize depending on what I want and what the manual calls for.
  12. Aug 18, 2016 at 1:43 PM
    rudyi
    Thank you all for your good comments. I got the cross bar out and cleaning the pan now. I'll change the trans filter and I'll go for a test drive after. I'll let you know the outcome.
    jester243 likes this.
  13. Aug 22, 2016 at 1:07 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Any update on this? How are things doing?
  14. Aug 22, 2016 at 6:02 PM
    rudyi
    It took me a while to put everything back. To summarize all the work that I did, new plugs/wires/cap/rotor. Cleaned the the throttle body. Replaced the MAF and transmission filter/fluid. I conclude that the problem is still there. I don't see/feel any improvements. It is very slow on acceleration. Just a slight inclined road, it is very slow and gas pedal is all the way down and the 4000RPM. Appreciate any suggestion?
  15. Aug 22, 2016 at 7:46 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I'm swinging wildly a bit here but have you checked the compression?
  16. Aug 22, 2016 at 9:11 PM
    rudyi
    I didn't the compression test yet. I'll do that this week-end. In the mean time, I'll put some injector cleaner and see if it will help. The fuel filter that I have in there now, maybe it has 5,000 miles. So I think fuel filter is still OK.
  17. Aug 23, 2016 at 7:48 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    You got a lot of tailpipe smoke? Does your oil in your dipstick look milky? Are you having to refill any fluid regularly, like coolant?
  18. Aug 23, 2016 at 9:36 AM
    brochacho
    ^^Head gasket??
  19. Aug 23, 2016 at 1:04 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    He hasn't responded, just basically yes, I'm asking him to check it. Hopefully that's not the case, but he's checked most everything else.
  20. Aug 23, 2016 at 10:11 PM
    rudyi
    Hi, sorry for the late reply. No, I didn't add coolant for a long time and I always check the coolant. I changed the engine oil lately. When I drained the oil, it was just old oil, it wasn't milky. The head gasket was changed when 4runners had a recall couple years ago. I don't notice black smoke coming from tail pipe. Next move, will check the compression test this week-end like fajitas21 suggested. Some one told me, maybe the igniter is bad. Is '94 4runner has an igniter? Thanks.
  21. Aug 26, 2016 at 7:23 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I honestly don't know, I don't want to give you mis-information so hopefully someone else can pop in.
  22. Aug 26, 2016 at 9:11 AM
    rudyi
    Any ideas/recommendations/comments would be appreciated. Thanks.
  23. Aug 29, 2016 at 11:22 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Did you try the compression test this weekend? Any results? Any particular cylinders not as good as the others?
  24. Aug 29, 2016 at 3:33 PM
    rudyi
    Hi fajitas21, I don't have a compression tester, so my friend will do it on the 2nd week of September. Is 170 - 180 psi is suppose to read?
  25. Aug 29, 2016 at 8:41 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    That's probably in the neighborhood. From what I understand it's more relevant if all 4 or 6 cylinders read near the same PSI, regardless of it. For example if 1, 3 and 4 were at 150, 165, and 158 (respectively), and #2 was at 125, that's not good. The 150 - 165 isn't too bad because it's clumped up, but that 125 being so far off is a sign of a ring not sealing well.
