Losing coolant
Discussion in '4th Gen 4Runners (2003-2009)' started by dvto2, Feb 23, 2019.
  1. Feb 23, 2019 at 11:17 AM
    dvto2
    dvto2 [OP] New Member
    2005 4runner Sport V6 4.0
    I have been losing small amounts of coolant for several years. I have about 250k on the car. This month i lost about 2.5 cups in 500 miles. I've checked the hoses and don't find any leaks. Am i looking at a head gasket? Suggestions?
  2. Feb 23, 2019 at 11:58 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Have you checked the weep hole on the water pump?
  3. Feb 23, 2019 at 12:08 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
  4. Feb 23, 2019 at 2:30 PM
    dvto2
    I have not! I did not know there was one. What's it for and is there an adjustment?
  5. Feb 23, 2019 at 2:51 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Not adjustable if it continues to leak it’s usually a sign of your water pump needing to be replaced.
    Watt maker likes this.
  6. Feb 23, 2019 at 7:32 PM
    dvto2
    So, since this has been happening for several years, i wonder if it could be a failing water pump, that it would have failed by now. In fact, i would think that most things would have become worse over several years, and maybe it has, but not by much.
  7. Feb 23, 2019 at 7:50 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Check if it is leaking from the weep hole. If it is it’s not like it’s going to hurt the engine to change it. If it’s not there then start looking elsewhere.
  8. Mar 7, 2019 at 3:35 PM
    Toyojay
    Toyojay New Member
    Jay
    ATX
    2009 SE 4WD
    285/70/17 KO2 - Dobinsons 3/2" UCA - 5100s @ 0
    Yeah, check the weep hole and under the W/P. If thats clean I'd get a leakdown test done being its a 2005 V6. Might be the dreaded HG issue.
  9. Mar 7, 2019 at 3:46 PM
    dvto2
    Dreaded indeed.
    Toyojay likes this.
  10. Mar 16, 2019 at 1:56 PM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Check the lower left corner of your radiator near the drain plug. Just did mine a few weeks ago. Kept having to add coolant. Fairly common.
  11. Mar 16, 2019 at 5:34 PM
    dvto2
    What's the fix?
  12. Mar 16, 2019 at 5:41 PM
    Benny123
    New radiator. If youve never had the water pump done, its over due too. Just did mine at the same time. 133000 miles.
    For HG you must do the pressure test 24 hours, have the dealer do it.
  13. Mar 16, 2019 at 7:05 PM
    dvto2
    Ok. Thanks.
  14. Jun 2, 2023 at 11:44 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    What was it?
  15. Nov 9, 2023 at 1:38 PM
    JEDI MASTER YOTA
    JEDI MASTER YOTA New Member
    Nautical Blue 2006 $runner
    Dobinsons Suspension, Falcon Rims
    Shouldn't our coolant be red? I would be cautious using any coolant not toyota approved. I use https://www.valvolineglobal.com/en/zerex-asian-red-vehicle-antifreeze-coolant/ as recomended by the dealer. Using the wrong stuff can crack the case
  16. Nov 16, 2023 at 3:22 PM
    Benny123
    Yeah that was on my 2007. I have since got a 2016. In my younger days I used non OEM Toyota coolant, however that is no longer the case.
