Location of breathers for front diff and transfer case?
Discussion in '5th Gen 4Runners (2010-2024)' started by rmiked, May 27, 2023.
  1. May 27, 2023 at 7:32 AM
    rmiked
    rmiked [OP] New Member
    Fort Mill, SC
    The rear diff breather is easily located. Can anyone tell me where the other 2 are? I’m thinking the tubes terminate in the engine bay. I assume there should be a black tube with a silver vent cap on the end for each component. So there should be 2 tubes unless they connect with a Y type (2 into 1) tube connection. Thanks
  2. May 27, 2023 at 8:08 AM
    Sleestaks
    Sleestaks Shape-shifting Reptilian Alien
    2018 OR, Magnetic Gray
    Tires only
    to the left of the Relay & Fuse box on drivers side -- they're paired together
    kolter45 likes this.
  3. May 27, 2023 at 8:19 AM
    rmiked
    Fort Mill, SC
    I can’t find them? Attached pics. Anyone have a pic? How high up are they relative to fuse box?
  4. May 27, 2023 at 8:28 AM
    Sleestaks
    Tires only
    You got a 5th gen? Should be to the Left/Below the Relay/Fuse box -- here's a couple of pics
  5. May 27, 2023 at 8:38 AM
    rmiked
    Fort Mill, SC
    Yea, I found them. The top of the silver caps were being partially blocked by the bottom of the fuse box. I was looking for your orange cables and realized you must have some power supply modifications. Thanks so much
    Sleestaks likes this.
  6. May 27, 2023 at 8:40 AM
    Sleestaks
    Tires only
    No worries -- glad to help out -- that's one of the things I love about this forum -- all the people willing to help me out with my OCD questions -- LOL
    BTW, no mods on my Runner other than tires.
    Stoney Ranger, 2Toys and rmiked[OP] like this.
  7. May 27, 2023 at 8:51 AM
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    Learn something new every day.;)
    2Toys likes this.
  8. May 27, 2023 at 3:29 PM
    There are actually 4 breathers under the hood. The two shown by the fuse box, and two more behind the motor at about the same height of the first two.
  9. May 27, 2023 at 3:33 PM
    rmiked
    Fort Mill, SC
    Captain Spalding, are the other 2 more easily seen from the passenger side of engine compartment? I’m guessing one is the ADD Actuator and one it transmission?
  10. May 27, 2023 at 3:36 PM
    I could only see the ones behind with a mirror. I think those are transmission and transfer case, and the ones by the fuse box are for the front diff and add. I’ve never actually chased them down to confirm which goes with which.
  11. May 27, 2023 at 3:39 PM
    rmiked
    Fort Mill, SC
    I found then using mirror from passenger side. They are shown as silver caps in attached picture.
    Sleestaks and Captain Spalding like this.
  12. Apr 2, 2024 at 11:03 AM
    H1M72
    H1M72 New Member
    West Columbia, SC
    2024 TRD PRO
    This last pic actually has 3 breathers in it. I believe the white plastic cap looking thing next to the two metal capped breathers you are talking about is actually the transmission breather.
  13. Apr 2, 2024 at 6:07 PM
    Not sure about that.
  14. Apr 14, 2024 at 1:46 PM
    Has anybody checked visually to see if the transmission breather ends on the transmission, or does it terminate in the engine bay?
  15. Apr 14, 2024 at 2:12 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I just changed my spark plugs today and noticed that the breathers for the front diff & trans are located just below the main fuse box.
    But I'll try and make sure that they are the ones after I eat my PB&J sammy.
    edit. I'm wrong.
  16. Apr 14, 2024 at 2:13 PM
    rmiked
    Fort Mill, SC
    I have not traced down the trans breather from under the vehicle. I thought it was one of the 2 silver capped lines behind the engine. But your diagram suggests it could be on top of the transmission. You really can’t tell how long the vent line is from that diagram. I have identified 4 total silver capped breathers under the hood.
  17. Apr 14, 2024 at 5:48 PM
    Thanks for attempting to track it down. Agree that the drawing isn’t necessarily showing the true length, but if it is, then it seems to be pretty low. It’s higher than the stock breather for the rear diff, but still.
    I’ll try to remember to look next time I take my skid plates off.
  18. Apr 15, 2024 at 5:22 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I had to plumb rear line on my Limited. I guess they didn't think soccer mom's would be needing them. I guess they saved $4 to.
  19. Apr 15, 2024 at 5:25 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    Front comes up by fuse box. Transfer case probably on top. I ran my rear up by shock and frame. I will never need to cross anything that deep.
  20. Mar 6, 2025 at 7:31 PM
    lsrlibra
    lsrlibra New Member
    does any one know the parts number for those two breather?
    I tired twice and got the wrong parts...
  21. Mar 7, 2025 at 2:32 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I have a Limited and I only needed a rear breather. I got a Dorman and some 1/4" hose w/clamps. Front and transfer case already have one. I didn't understand the Toyota philosophy of 2/3rds done. Things must be getting tight. This is what I got from Amazon for rear axle breather extension.
  22. Mar 7, 2025 at 4:48 AM
    coachhomer
    coachhomer New Member
    Please excuse the ignorance... what are you guys doing to the breather tubes? Are you extending them to get them out of the way of water?
    OP's engine looks brand new. So this must be an improvement modification?
    Thanks,
    C
  23. Mar 7, 2025 at 5:23 AM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    1/4" vacuum hose and clamps. I ran my rear over frame to rear brake lines over to driver's rear shock and zip tied up between frame and body. I'm never going to be that deep in anything planned.
  24. Mar 7, 2025 at 5:23 AM
    scottiezilla
    scottiezilla New Member
